clutch fork removal help needed 78 CJ5 - JeepForum.com
post #1 of 3 Old 07-22-2007, 10:53 PM Thread Starter
hansw3
1978 CJ5
I have not been able to pull the clutch fork on my 78 cj5. How can you separate the fork far enough from the throwout bearing to get the two pins out of the bearing? With the boot removed I can see the throw out bearing. I've put various size screw drivers and pry bars in there. I've also tried inserting them with a come-along disengaging the clutch by pulling the fork back. No luck. I'm pulling my hair out on this one. Surely somebody has a solution short of pulling the entire tranny and bellhousing out in one piece. Then I could pull the fork out with the bearing stuck to it. I really don't want to do that! Any ideas are appreciated.
hansw3 is offline
post #2 of 3 Old 07-23-2007, 01:30 AM
T18A
1977 CJ5
T18A is offline
post #3 of 3 Old 07-23-2007, 10:43 AM Thread Starter
hansw3
1978 CJ5
fork removal
Plan B is to pull the tranny as you mentioned.
I have to remove some material from the clutch fork. It is contacting the Chevy pressure plate. I have advance adapters bellhousing w/Chevy V8 and T-150 put together. I noticed the jeep fork contacting the pressure plate when I first set the thing up and removed some material to get clearance. Since then it has started hitting again, either the fork settled into place or something is bending.
hansw3 is offline
Stumped and need help - clutch fork not going in! CJfreak Jeep CJ Forum 20 06-09-2009 12:32 AM
T15 Shifter Fork Removal/Tips??? CJ5 Rookie Jeep CJ Forum 3 05-06-2008 10:35 AM
Clutch fork T5 Wolf359 Jeep CJ Forum 1 07-28-2007 07:09 AM
Clutch fork springs sefh Jeep CJ Forum 1 08-27-2006 09:03 PM
T5 clutch fork lord_byron Jeep CJ Forum 3 08-08-2004 09:52 PM
