Clutch Fan - JeepForum.com
post #1 of 14 Old 03-03-2009, 12:30 PM Thread Starter
Donobrew
Clutch Fan
Should I keep the clutch fan or go with something else? If I go with something else any suggestions on fans would be great...
Thx
TD
Donobrew is offline
post #2 of 14 Old 03-03-2009, 12:33 PM
VACJ5
I got a 2 speed ford taurus fan.... picked it up at a local auto yard for 30 bucks. AWESOME!
79 CJ5 Silver Anniversary Edition... revived & sold *sniff
91 YJ 4.0 L, with some stuff bolted to it...
91 2 door Cherocar... in progress
Custom CNC cut Jeep parts & more
VACJ5 is offline
post #3 of 14 Old 03-03-2009, 12:35 PM
scottymac62
1979 CJ7
I gave my clutch up for a 575 Flex-A-Lite electric fan and have been very happy with my choice. I got mine off of Ebay for less than $200.
scottymac62 is offline
post #4 of 14 Old 03-03-2009, 12:58 PM
Dubl0Vert
When I got my cj PO had taken off the clutch and put on the direct drive........ just don't do that to yours! My waterpump sings to me everytime I start it up. I'd replace the clutch or go electric..... great for water crossings!!
Dubl0Vert is offline
post #5 of 14 Old 03-03-2009, 01:09 PM Thread Starter
Donobrew
Maybe my clutch fan isn’t working right. Should the fan spin when its cold (starting up in the morning) My fan does… The longer I drive at highway speed the temp gauge keeps creeping higher. I have about a 15 mile commute to work and 10 of those miles are highway. I go about 60-70mph The only time I see my temp go up is those 10 mile on the highway.
Donobrew is offline
post #6 of 14 Old 03-03-2009, 01:32 PM
Dubl0Vert
it should spin slowly when cold and then as the thermostat in the clutch warms it should "catch up" to the water pump speed, if not it needs a new clutch...
post #7 of 14 Old 03-03-2009, 01:32 PM
80cj
80cj's Avatar
1980 CJ5
How high does the temp go? I would keep the clutch fan. maybe the clutch just needs replacing.
I have the fan clutch test procedure in PDF file. I'll gladly email it to you if you pm me your email address.
80cj is offline
post #8 of 14 Old 03-03-2009, 01:57 PM Thread Starter
Donobrew
The temp goes up to the middle between Cold & Hot then once I'm off the highway its goes back down closer to Cold mark
Donobrew is offline
post #9 of 14 Old 03-03-2009, 02:01 PM Thread Starter
Donobrew
Its seems to spin at the same rate as the engine.
Donobrew is offline
post #10 of 14 Old 03-03-2009, 02:10 PM
Dubl0Vert
I wouldn't worry too much about that, my thermostat doesn't open till a little past that middle mark. If anything, your jeep might be running a little chilly.
What's the ambient temp during your drives?
post #11 of 14 Old 03-03-2009, 02:20 PM Thread Starter
Donobrew
Mornings 50-60, afternoons 70-80
Donobrew is offline
post #12 of 14 Old 03-03-2009, 02:34 PM
80cj
80cj's Avatar
1980 CJ5
I have a 180 degree thermostat in mine and the temp gauge sits constantly at slightly past center. I think you're in good shape assuming your temp gauge is operating properly (we're talking stock Jeep gauge). You might check your thermostat. Sounds like you may not have one, one that's stuck open or one that is set for too low a temperature.
80cj is offline
post #13 of 14 Old 03-03-2009, 03:17 PM
Dubl0Vert
I second that motion counselor... thermostat could be stuck or out, maybe a little flush and fill too.
post #14 of 14 Old 03-03-2009, 04:05 PM
80cj
80cj's Avatar
1980 CJ5
Counselor?
80cj is offline
hydraulic clutch - clutch won't disengage kercher Jeep CJ Forum 13 10-24-2009 12:27 PM
t150 clutch/t15a need correct clutch kit? speediemb Jeep CJ Forum 1 02-05-2009 10:52 PM
Which Clutch? Fropleyqk Jeep CJ Forum 10 05-02-2007 06:21 PM
Clutch works but I hear a whirring when I press the clutch pedal to the floor? part.changer Jeep CJ Forum 12 04-10-2007 03:31 PM
Clutch sdcannon Jeep CJ Forum 1 09-13-2006 05:16 AM
