Clutch disc thickness - JeepForum.com
post #1 of 2 Old 04-23-2007, 07:48 PM Thread Starter
wwhitby
1979 CJ5
I had to pull the engine on my CJ to replace the bell housing and other parts. I had hoped to put a new clutch disc, pressure plate and T/O bearing in while the engine is out, but I've spent my budget to replace the parts I needed and everything else that i've found wrong.
Having said all that, does anyone know what the minimum thickness for a CJ clutch disc is? Mine only has about 20K-25K miles on it, and looks pretty good. I just want to completely check it out before I put it back in.
Thanks,
Warren
Warren Whitby
1979 CJ-5 "Big Blue"
Real Jeeps have rust
Just Empty Every Pocket
wwhitby is offline
post #2 of 2 Old 04-23-2007, 11:45 PM
only in a jeep cj
You should be OK, I get 60 to 80 K out of a disk so unless your just riding the hell out of it, just inspect it for broken/loose springs or cracks and clean it real good. If the clutch worked smooth before, you should be OK on the flywheel as well. Inspect it for hot spots, grooves, etc and resurface if needed. Some do it each time, but I only do it when needed and it has worked for me....
Ed
1975 CJ-6 1983 CJ-8
1986 CJ-7 Laredo 1986 TJ-7 Trail Jeep
2003 Inca Gold TJ Rubicon
only in a jeep cj is offline
New clutch disc Mike1084 Jeep CJ Forum 3 08-31-2009 06:53 PM
D30 rotor thickness jeepwhore Jeep CJ Forum 1 03-27-2008 09:46 AM
metal thickness? lewis09 Jeep CJ Forum 3 07-16-2007 02:34 PM
clutch disc question tera1298 Jeep CJ Forum 1 07-18-2003 05:23 PM
clutch disc direction ? mwbell Jeep CJ Forum 3 02-05-2003 09:26 AM
