Quantcast clutch clicks when pedal pushed in - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > clutch clicks when pedal pushed in
The Original 3/8" Ruffstuff Diff Cover!Ruffstuff Axle Simple Swap Kit!RUBICON EXPRESS Lift Kits and Accessories Available at Bas
Old 03-29-2009, 03:09 PM   #1
chiliman77
1981 CJ7
Almost every time I push in my clutch pedal I get a clicking sound from inside the bellhousing that I can hear inside the jeep. Anyone know what this is from? I have a t5 to 4.0 combination, and I think it is a centerforce II clutch. The noise happens just about when the pedal is pushed all the way down.
I don't know too much about the clutch area and just dont want it to be something that may let go...any help would be appreciated. Thanks.
'81 CJ7 4.0 "HO", 33" on a 4" suspension lift
chiliman77 is offline   Reply With Quote
Old 03-29-2009, 05:37 PM   #2
1986cj
My 86 (I6 T5) does the same thing sometimes. I think it is the fork moving on the ball stud as the spring is the only thing holding it in place unlike a older one that the fork clips to the ball stud and it drives me crazy too. Anyone with any ideas I would sure like to here them too.
1986cj is offline   Reply With Quote
Old 03-29-2009, 06:59 PM   #3
computertech
1974 CJ5
It's the throwout bearing. This is the bearing that rides on the clutch fork and tranny input shaft. You have to pull the tranny and bellhousing to get to it. If this has gone out, it's probably time for a new clutch and pilot bushing. Don't forget to have the flywheel turned too!
computertech is offline   Reply With Quote
Old 03-30-2009, 03:19 PM   #4
chiliman77
1981 CJ7
If it is the throwout bearing, wouldn't it make a more constant noise, at least when the clutch is pressed in? This is a one time click at the moment the pedal is pressed...if I am wrong, could you explain to me why it happens this way? Thanks.
Old 03-30-2009, 03:25 PM   #5
happydog
Probably not the throw out bearing. Check the linkage from the firewall back to the transmission. My was doing that. I had a broken engine mount bracket and the linkage was fouled up. Get under the Jeep and have someone press the pedal.
"I don't do things, I give advice." by an old geezer in the movie "Milagro Beanfield War"
"After all, it is the slave who thinks himself a free man who makes the best slave." (Unknown)
“A closed mind is like a closed book; just a block of wood”. Chinese Proverb
happydog is offline   Reply With Quote
Old 03-30-2009, 04:18 PM   #6
chiliman77
1981 CJ7
I did do that because I thought that was the problem, and it sounded like it was within the bellhousing. I still doubt it is the throwout bearing, maybe 1986cj is on to something.
Old 03-30-2009, 04:38 PM   #7
rkbell
1977 CJ5
1986cj, I think you're the closest. Could also be the return spring attached from the bell housing to the clutch TOB fork snapping or snagging against the bell housing. I agree with happydog that you'll probably figure it out from under the Jeep while someone else pushes in the clutch pedal.
"We and the world will always be at war. Retreat is impossible. Arm yourselves for the conflict." Leif Enger
rkbell is offline   Reply With Quote
Old 03-31-2009, 07:19 PM   #8
chiliman77
1981 CJ7
This shouldnt really be a problem though, correct? Just annoying with a little more wear probably? Thanks.
Old 05-13-2009, 12:18 AM   #9
choptoe
mine is doing the same. i just told myself it was the ring holding the weights on the centerforce. did you figure it out? i hate this clutch!
choptoe is offline   Reply With Quote
Old 05-13-2009, 06:05 AM   #10
Mike Romain
Off Road Forever
Location: Off the Grid in Chester Grant, Nova Scotia, Canada
Did you change over the pilot bearing for the T-5's pilot bushing when you swapped engines? They are different sizes and I have heard of noises happening there after if not swapped.
Mike
86/00 CJ7 Laredo, 33x9.5 BFG AT's, 'glass nose to tail in '00, 'New' frame,wires and plumbing in '09. Carter BBD Carbed 4.0 HO in '10. Some Canadian Bush Jeep Runs and Build Photos: http://mikeromainjeeptrips.shutterfly.com (10 new albums added Sept 16/10)
Mike Romain is offline   Reply With Quote
Glock Forum
