Clutch bolts - JeepForum.com
post #1 of 7 Old 02-22-2012, 08:00 PM Thread Starter
driver007
1981 CJ5
Clutch bolts
I am changing out a clutch on a 81 cj5. And the shoulder bolts bottom out on the shoulder of the fly wheel. This leaves space between the pressure plate and flywheel. Did they have lock washers on them from the factory. I was thinking of putting on a set of grade 8 lock washers to take the space up so the plate snuggs down. Thanks
driver007 is offline
post #2 of 7 Old 02-22-2012, 09:05 PM
mopar346
Yes, I believe they did. I usually replace mine with Mr.Gasket replacement bolts with washers.
Careful your character's showing
mopar346 is offline
post #3 of 7 Old 02-22-2012, 09:28 PM Thread Starter
driver007
1981 CJ5
I am not faimliar with mr gasket bolts. Could you elaberate?
post #4 of 7 Old 02-22-2012, 09:42 PM Thread Starter
driver007
1981 CJ5
Did the Google search I did not know they did bolts thanks.
post #5 of 7 Old 02-22-2012, 11:55 PM
BagusJeep
1981 CJ7
They came with washers only on the 2.5 and diesel. There are a number of different bolts listed, have you got the ones that came with your flywheel? The 258 and 304 used the same bolts.
BagusJeep lives in Bali.
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
BagusJeep is offline
post #6 of 7 Old 02-23-2012, 04:47 PM Thread Starter
driver007
1981 CJ5
The ones that were on it were shoulder bolts. Could not get Mr gasket but have some arp coming in.
post #7 of 7 Old 02-23-2012, 06:36 PM
mopar346
Cool, the flywheel threads are usually a little inset for machining, it is possible that it has machined to the point were it has bought the threads to the edge. ARPs are first rate so good choice. The parts house usually has Mr. Gs in stock is why I use them, they are probably made by ARP but I don't know that for sure.
Good luck.
mopar346 is offline
Flywheel and Clutch Bolts TimothyPaul Jeep CJ Forum 0 07-18-2011 12:40 PM
lost clutch bolts - what size are suppose to be? mike06X Jeep CJ Forum 1 03-16-2010 10:50 PM
Tightened Manifold Bolts - and it Fixed Clutch? nazdackster Jeep CJ Forum 1 04-27-2009 08:41 PM
Crazy clutch bolts? Hybrid Jeep Jeep CJ Forum 7 02-28-2008 08:31 PM
Clutch Pressure Plate Bolts sefh Jeep CJ Forum 1 08-31-2006 05:16 PM
