Quantcast Clocking ring - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Clocking ring
JcrOffroad new Crusader TJ/YJ/CJ Bumpers available!!JKS products - Free shipping! Lowest prices!East Coast Gear Supply- Quality Diff Parts
Old 06-26-2008, 10:03 PM   #1
NWA_CJ7
1983 CJ7
Clocking ring
Anybody have any experience with a clocking ring? Will they work with a t4 tranny, do drive line angles have to be modified, where to get, ect.
83 CJ7 AMC 360, nuttered & team rushed. Dana 44 rear geared & locked, Dana 30 front geared & locked Dana 300 T. Case 4" Tough Country Lift, 1" daystar body lift, 1/2" shackle 35x12.50x15 MT MTZ's on MT classic 2's, Besrk Bumpers, Genright Tube Fenders
NWA_CJ7 is offline   Reply With Quote
Old 06-27-2008, 06:29 AM   #2
gmakra
The clocking ring is 3/8 thick and it should not affect your rear drive line. Depending on how much you rotate your transfer case up you may have issues with your front drive shaft and t case shifter.
gmakra is offline   Reply With Quote
Old 06-27-2008, 12:24 PM   #3
1984CJ
Broke Jeep owner
1984CJ's Avatar
I have a t-5/300 with a Great Lakes Clocking ring(http://www.greatlakeoffroad.com/clock.html). No complaints.
I have my tcase clocked just shy of flat and I had to bend my transfer case shifters to fit.
I did not have to change anything with my drive shafts.
HOWEVER!!!!!
To use a clocking ring with a t-4/5 you will need a speedi sleeve (Chicago Rawhide Speedi Sleeve p/n 99193) for the input shaft of the 300. Without the sleeve the rear seal on the transmission may not seal on the input shaft of the transfer case.
Here is more info on clocking rings and speedi sleeves
http://cjoffroad.com/D300ring.asp
http://www.kutzendoerfer.at/files/speedisleeve.pdf
84 CJ7 258, T5, D300, AMC 20, D30 EZ lockers F&R
33" TSL, 2.5"BDS lift, .5" shackle lift 1" body lift
Originally Posted by ftdranger
You guys on the CJ tech page are a little to tech for me. Must be the leaf springs.
1984CJ is offline   Reply With Quote
Old 06-27-2008, 06:05 PM   #4
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
Another thing.. don't overtighten the studs that go into the clocking ring. They can bottom out on the tranny and actually bend the ring.. ask me how I know this...
'80 CJ5 w/AMC360, T176, D44 w/Detroit 3.73s, RE 4" YJ lift and 35s..
Ground Pounder Fab
Lower 2
Guardrail
Down Schoolbus
Slickrock Tellico
Save
Crozet
More Crozet
BESRK is offline   Reply With Quote
Old 06-28-2008, 12:10 AM   #5
NWA_CJ7
1983 CJ7
thanks guys
Old 07-01-2008, 02:26 PM   #6
84jeepjohn
I'll chime in I've got the kit from JB conversions and it comes with a new input shaft for the D300. VERY easy install, except for the shifter (we had to cut out like 3" and heat and bend to fit) NOT a big deal if you have the correct tools, but FYI.
84 CJ-7 RE 4.5" lift TJ flares and 35"BFG's
4.88's and OX lockers front and rear
2000 Grand Cherokee, 2" lift, BFG AT's (SOLD)
2005 Z71 Suburban with 1.5" rear spacers, and front leveled
84jeepjohn is offline   Reply With Quote
Glock Forum
