"Clicking" noise when driving - sounds like it is coming from the front - JeepForum.com
post #1 of 12 Old 03-03-2008, 07:45 AM Thread Starter
jatepper
I rebuilt my front axle several months back. Seemed fine for a while, and now I hear a "clicking noise" coming from the front. The noise sounds like it is sequential to the tire revolution.
I dont think it has anything to do with the drive line because I have put the tranny in neutral and coasted down the road and the noise is still there.
What do you all think?
I am a little stumped because I made sure to pack the wheel bearings pretty good, so I dont think that is the problem either. I also cant tell if it is coming from the driver side, passenger side, or both???
1986 CJ7 Laredo - Auto 14k miles
1985 CJ7 Renegade - Auto 33k miles
1982 CJ8 Scrambler - T5 T-SPD
jatepper is offline
post #2 of 12 Old 03-03-2008, 08:36 AM
flashawk
flashawk's Avatar
1979 CJ5
Do you have front disc brakes? If so, what kind of shape are you're anti-rattle clips in? I had a similar issue because I left those clips off completely.
Just a thought, anyway.
flashawk is offline
post #3 of 12 Old 03-03-2008, 08:50 AM
ecvMatt
1966 CJ5
It could be the driveshaft u joint, even if its in nuetral, with the hubs unlocked, it can still spin, if you put a TON of grease in there it will spin. However, if it seems to coincide with tire rotation, I'd check the axle u joints too. Nail in the tire?
jack it up and spin em, see if you can't narrow it down a bit. There really arent too many moving parts if the hubs are unlocked. wheel bearings, knuckles and rotors.
Good luck!
ecvMatt is offline
post #4 of 12 Old 03-03-2008, 09:27 AM Thread Starter
jatepper
Good luck!
The front driveshaft could still spin, even in neutral and the t-case not in
4wd? I didnt know that. I will check in on it.
Also, I dont think the axle u-joints are spinning either because if I remember correctly, the wheels are just sitting on the spindle and when 4wd in engaged, that is when the axles spin.
Please correct me if I am wrong, as I am not certain.
As always, thanks for all the help guys.
jatepper is offline
post #5 of 12 Old 03-03-2008, 11:30 AM
ecvMatt
1966 CJ5
As the wheel spins, the grease in the wheel bearings is often enough to get the axles spinning(centrifugal force), then the driveshaft(even with the hubs unlocked), it's doubtfull though, that it would be that consistant.
Jack it up, only one wheel, leave the other on the ground. spin, note what happens. Switch sides, repeat and compare. check tires for balance and wierd wear or bubbles. make sure hubs are unlocking properly.
Does it had a locker or LSD in the pumpkin, they can make noise too. Check fluid level of RnP.
Can you feel it in the wheel or in the brake pedal? try driving it with the clutch foot lightly resting on the brake pedal, can you feel it pulsating with the clicking, this could indicate a problem between the pads and rotor.
there really isn't too much between the Tcase and the tires, take your time, work out to in or in to out methodically and the problem, and hopefully the solution, should present itsself.
ecvMatt is offline
post #6 of 12 Old 03-03-2008, 11:37 AM
Bard
Rock or pebble or nail in the tire?
85' CJ7 Laredo, 383 GM, Turbo 350, NP 203. SOA, 2" frame lift, 34" TSL swampers, Dana 30 open, AMC 20 w/ detroit locker, 4:10's, 1 Piece Mosers, 35" boggers to abuse when needed.
Bard is offline
post #7 of 12 Old 03-03-2008, 12:01 PM Thread Starter
jatepper
Differential is topped with fluid, so I know thats good.
I havent tried riding the brakes quite yet, but will give it a shot this evening. I also like the idea of jacking up each of the front wheels seperately. Wouldnt have thought of that.
Oh yeah, already checked for rocks, etc. and didnt see anything
jatepper is offline
post #8 of 12 Old 03-03-2008, 12:08 PM
nsargeant
1974 CJ5
I had a tapping coming from the front of my wrangler consistent with the wheel rotation. It turned out to be a u joint.
nathan
nsargeant is offline
post #9 of 12 Old 03-03-2008, 12:56 PM
twmattox
It can be a bad wheel bearing too...I had that happen once...
twmattox is offline
post #10 of 12 Old 03-03-2008, 06:51 PM
ky81cj7
1981 CJ7
have you taken your hubs apart and greased them lately? Mine made a clicking sound till I greased them. This should be done every couple years.Use white grease.
ky81cj7 is offline
post #11 of 12 Old 03-03-2008, 08:14 PM Thread Starter
jatepper
Good thought. I will give it a shot this weekend. Thanks
jatepper is offline
post #12 of 12 Old 03-03-2008, 09:41 PM
chiliman77
1981 CJ7
My YJ does the same thing... ill have to check those u joints
'81 CJ7 4.0 "HO", 33" on a 4" suspension lift
chiliman77 is offline
86 CJ7 making loud clicking sounds when driving. siymay Jeep CJ Forum 2 07-16-2009 06:46 PM
30" after driving = stalls? pcg7384 Jeep CJ Forum 2 03-29-2009 12:10 AM
"Clinking" noise with rotation of front whee jatepper Jeep CJ Forum 6 09-02-2008 12:36 PM
"Green Grease" or Lucas "Red N Tacky #2" Curt Reinhardt Jeep CJ Forum 3 07-16-2008 07:09 AM
Hardtop.. "Front Metal STrip"? JarWithLid Jeep CJ Forum 11 06-29-2007 06:39 PM
