cleaning engine compartment fuse panel? - JeepForum.com
post #1 of 4 Old 08-16-2009, 02:38 AM Thread Starter
littleturner76
1984 CJ8
Still working on my 8 and I want to spend some time cleaning up the electrical wires that are hanging and dangling under the dash. For some reason after I replaced the windshield frame assy the heater blower motor quit working so I am going to trace this down at the same time. Anyway my question is would it be ok to use electrical connector cleaner and a paint brush on the engine bay side of the fuse panel? Mine is covered in so much crud it is hard to tell what is what. I know unplug the battery.
1984 CJ8 Scrambler, 258, MC2100, daystar 1", 4" Skyjacker Soft Ride, 31X10.5 on stock wheels, raptor lined.
littleturner76 is offline
post #2 of 4 Old 08-16-2009, 02:55 AM
babytank31
1978 CJ5
I cleaned mine up using either. Disconect your light harness at the bulkhead so you can hold the contact side up and spray down blowing all the crud out. You may be better of using some kind of approved terminal cleaner. I used the either because for one it was on hand and two it cuts through grime and dries fast, worked for me.
babytank31 is offline
post #3 of 4 Old 08-16-2009, 03:24 AM
OldSailor
1977 CJ7
I'd use a regular electronic contact cleaner. Be careful in using other solvents, because they may harm the plastic part of the panel. Also, after cleaning, blow out all the solvent and loose crud with compressed air.
1977 CJ7, AMC360 V8 w/ headers, DUI HEI, Edelbrock intake, Holley 4150 carb, , TF999, D300, D30 front and AMC20 rear with 4.56 gears and lockers both ends, 4" susp lift, 2.5" body lift, 35" BFGs, ARG steering, 8000-lb winch, etc.
OldSailor is offline
post #4 of 4 Old 08-16-2009, 05:02 AM Thread Starter
littleturner76
1984 CJ8
thanks for the help. I get off of work in about an hour. I figure 3.5 hrs sleep and then it is beer/jeep 30. I think I'll try the electrical connection cleaner, I have it on hand.
Fuse Panel Problems ??? Stan99 Jeep CJ Forum 14 02-02-2010 03:20 PM
Picture request of the fuse block back in the engine compartment gmakra Jeep CJ Forum 7 06-21-2009 07:14 PM
Fuse Panel Diagram '72 Cj5 whizerd Jeep CJ Forum 21 10-20-2008 12:09 AM
CJ Fuse Panel Chrisfol82 Jeep CJ Forum 4 06-24-2008 07:40 PM
Fuse Panel Rebuild RetiredSERE Jeep CJ Forum 3 01-06-2008 12:15 PM
