Clay's Build Thread - Page 8 - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Clay's Build Thread
WIN a Rough Country Forged Track Bar - ExtremeTerrain!FREE, FREE, FREE EVENT!! Save big on Lockers now till ApriJKS Grand Cherokee WJ, Adjustable Front Trackbar 1"-6
Unread 07-15-2010, 06:03 AM   #106
Skerr
Originally Posted by Ken4444 View Post
What does AJ say? He seems to know about this stuff.
AJ says to use a material called Prepaint Prep. It contains Heptane and Toluene. He has a can in his shop... maybe NAPA carries it. He says don't use Acetone; don't use denatured alcohol; don't use POR-15 unless you (I) have more rust. He says use a good automotive primer, scuff, then apply chassis black. There are a lot of guys on here that are going to disagree with these comments. I've seen too many builds using POR that I was impressed enough to buy it myself. Now I'm told not to use it. I feel like AJ is wrong in this case, but I have too much respect for him to disagree. I know his way will work. It has for many years, but I also know that someone else has a successful method. I just want to get it right this time!
Kerrdog
Go Fish! <*////><
Skerr is offline   Reply With Quote Quick reply to this message
Unread 07-15-2010, 05:38 PM   #107
Skerr
I was wanting to mount up Clay's 2100 to the intake. The studs are in the way! The adapter kit comes with hex head bolts that recess down into the adapter. I need the studs to BE GONE! I tried double-nutting them and backing them out, but both nuts turn. I know I can weld a nut to the top, but I was worried about it in case I can't get them out... then I've ruined the existing stud. Any suggestions??
Thanks
Kerrdog
Go Fish! <*////><
Unread 07-15-2010, 09:01 PM   #108
243
1978 FSJ Cherokee
Scott,
I would spray some PB Blaster or similar product on the studs and let it soak overnight at least. The dissimilar metals will corrode and it's possible to strip the aluminum threads when you remove the studs. And when you double nut and they spin, make sure your wrench only grabs the lower nut. And use some anti-seize on the new bolts that thread into aluminum.
1978 Cherokee, 360/T400/QT...5.3/4L60E/NP241C in the works...
243 is offline   Reply With Quote Quick reply to this message
Unread 07-15-2010, 10:17 PM   #109
jeepwhore
Small pipe wrench will take 'em out with ease.
'84 CJ-7: Yota axles (spartan locked front, e-locked rear) 4" BDS, 1" Daystar & 3/8" shackle lifts, 35" X-Terrains on steelies, YJ Tub & family roll bar, heater blower upgrade, 4.2L w/MC2100 & Team Rush, Warn 8274. Rebuilt 4.2/4.0 hybrid, AX15 and twin sticks/clocking ring waiting to go in.
The advertised position for a topless, dirty jeep girl has been filled......by my wife. Thanks to all that applied.
<------------and yes, that is her.
:-D
jeepwhore is offline   Reply With Quote Quick reply to this message
Unread 07-15-2010, 10:18 PM   #110
Ken4444
Corripe Cervisiam
Ken4444's Avatar
If you need more help removing the studs, you could try heating the manifold with a blow torch. Try to avoid heating the studs. This might cause enough expansion of the manifold to allow the studs to be turned. Be careful about the PB Blaster though... It's probably flamable.
"I give you a republic, if you can keep it." - Benjamin Franklin
Ken4444 is offline   Reply With Quote Quick reply to this message
Unread 07-15-2010, 10:21 PM   #111
Ken4444
Corripe Cervisiam
Ken4444's Avatar
There's more than one way to skin a cat. I suspect that AJ has been around long enough that he has seen fine results without having to use any of the more recent products on the market.
Unread 07-16-2010, 12:25 AM   #112
Coiz
1979 CJ7
^^^ What Dave said and heat is also very effective like Ken said.
Mike
My build thread
Coiz is offline   Reply With Quote Quick reply to this message
Unread 07-16-2010, 06:03 AM   #113
Skerr
Having sons is one of the three greatest blessings in my life, but they are hell-on-wheels with tools! I can't find some of my wrenches. I know they're in the shop, but no idea where. I can't believe that a 3/8 combo wrench could hide so well. I said, "Clay, where's my 3/8 Craftsman"? and he said, "Uh... uh... don't know." !! When this is all done I'll get all my tools back... if the Tool Troll hasn't stolen them!
Thanks for the suggestions on removing the studs. All of them ideas I should have thought to do myself, but all I can say is that I had a Brain Fart! I have the Blaster, the heat, and the pipe wrench. Can't wait to get home from work and go at it.
Y'all have a good day... "see ya" this evening.
Kerrdog
Go Fish! <*////><
Unread 07-16-2010, 07:37 AM   #114
Jim1611
Jim1611's Avatar
Hope you got the studs out without breaking them Scott. If all else fails you may need to drill them out. If you have access to a vertical mill that's the best place to do it. You can do it with a hand drill if you're careful to center punch the stud before drilling and start out with a much smaller drill than the tap drill size. I think those studs are 5/16, but not sure if they're fine or course thread. 5/16-18 takes a letter "F" drill (.257) and 5/16-24 takes a letter "I" drill (.272)
Thanks for the updates and I'm enjoying the build!
www.crabtreetool.com (Crabtree Shackle Hangers)
My build thread
http://www.jeepforum.com/forum/f8/ji...build-1093702/
Jim1611 is offline   Reply With Quote Quick reply to this message
Unread 07-16-2010, 07:03 PM   #115
Skerr
Dead-On! They came out easy just like you said. Thanks for the tip.
Thanks, Jim, for the suggestions on the drill bits. I didn't want to drill them out... I almost blew it on the exhaust manifold! Glad I didn't have to go that route.
Kerrdog
Go Fish! <*////><
Unread 07-16-2010, 07:10 PM   #116
Skerr
A couple of questions... I have a phenolic gasket that would fit between the carb and the adapter plate. It's about 1/2" thick. I also have an ordinary paper gasket for that same application. Is there any advantage to lifting the carb up a half inch? If I go this route, I have to buy longer bolts.
I would like to replace the bolts and washers (at least the washers) used to attach the manifolds. The bolts have that big washer that pulls down on the shoulder of both manifolds as it tightens to the block. I have searched several websites but I can't find them. Is there a direct replacement (a complete set), or do I need to come up with something? If available, where should I be looking?
Thanks
Kerrdog
Go Fish! <*////><
Unread 07-16-2010, 07:45 PM   #117
Skerr
Here is a pic with the manifolds in place (not tightened up yet) and a poser shot of the MC2100. Clay and I found that we've lost a manifold bolt... one of the small ones, with the heavy washer, that goes on either end. It's my fault as I am the one that removed it, to attach a chain, so we could pull it out of the frame.
Tomorrow is F-Day... Frame Day! From start to finish... unless someone is throwing up!!
Thanks everybody for your input on each issue. I cold not do this without my EJeep Maintenance and Repair Teachers!
Kerrdog
Go Fish! <*////><
Unread 07-16-2010, 08:39 PM   #118
yellow85cj
Did you check the chain for the bolt? Usually where I find bolts.
Engine looks great. Red fan makes it. One thing, maybe paint a one inch or so silver or red line around the top of the oil pan. Would make a leak easier to spot ( not that 258's ever spring a leak )
Currently in pieces - all of them
yellow85cj is offline   Reply With Quote Quick reply to this message
Unread 07-16-2010, 09:11 PM   #119
Skerr
Good thinking, but it's not there. It was too short for a chain, so I took it out and put a longer bolt in. I put in a place so I wouldn't forget it, but I forgot it!
Painting a stripe is a good idea, but if it ain't killing the grass, then I ain't gonna worry about it! In truth, I thought you were going to suggest a stripe around the tip of the fan... I've been thinking some about that.
Kerrdog
Go Fish! <*////><
Unread 07-16-2010, 09:12 PM   #120
243
1978 FSJ Cherokee
Team Kerr is on a roll...looks great!
1979 , cj5 , fiberglass , rollcage , tailgate
