Clay's Build Thread - Page 6 - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Clay's Build Thread
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFS: Wranger BRIGHT License Plate LED! Just $3! Great valueFS: Jeep Fog Light LED Bulbs! Several Brightness Options!
Unread 07-12-2010, 06:14 AM   #76
Exposed
Exposed's Avatar
1981 CJ5
Dave, that is what you use all your spare I-Beams that you have lying around for......
Calvin
Follow My CJ5 Build
81 CJ5, Ford 331 EFI, AX15, D-300, Dana 44 (Detroit Locker)....
When there are more people voting for a living than working for a living,
We are DONE as a Country!!!!!!
Newly Acquired 2014 Grand Cherokee Summit
Exposed is offline   Reply With Quote Quick reply to this message
Unread 07-12-2010, 07:48 AM   #77
Jim1611
Jim1611's Avatar
Hope your family is feeling better. That looks like a heavy duty trailer, it will come in handy for lots of things! Thanks for posting the pictures and the progress.
www.crabtreetool.com (Crabtree Shackle Hangers)
My build thread
http://www.jeepforum.com/forum/f8/ji...build-1093702/
Jim1611 is offline   Reply With Quote Quick reply to this message
Unread 07-12-2010, 07:46 PM   #78
Skerr
Originally Posted by 243 View Post
That is a beast of a trailer!
Indeed! I was happily surprised how well it pulls... couldn't tell it was back there. Deck looks like firewood, but I think if I pressure wash it it will look much better... still solid for the most part. Needs fenders and ramps, which AJ said he would build. It is an "afterJeep" project. I have a home farm/garden business and I can haul around my little tractor. YAY!
Kerrdog
Go Fish! <*////><
Skerr is offline   Reply With Quote Quick reply to this message
Unread 07-12-2010, 08:10 PM   #79
Skerr
Thanks for the kind words guys. I really get excited about these crazy Jeeps! It's a Gotta... Gotta... Gotta thing!
Well... me and Clay went over to AJs this evening. We hauled the frame over there between rainstorms. His wife was working so we had the shop to ourselves... just me, Clay, AJ, and the dog! I figured it was going to be a long night getting this done, but AJ chose to break it into 2 evenings... smart man! He went over the frame with chalk to mark everything that needed attention. One of the things that I thought remarkable was the poor quality factory welds. Keep in mind that I had already finished this frame once with a bedliner material. You can see that experience in this thread http://www.jeepforum.com/forum/f8/be...-paint-774919/ . If it hadn't been for the coating coming off I would be sending my son down the road in this thing! I encourage anyone, who is doing a frame restoration for the first time, to really spend some time going over the frame and looking at everything. After grinding the frame down a second time I really saw the problem areas, and with AJs help things became obvious. AJ prepped these areas with a wire wheel that takes a man to wield! No problem! Some of the nutserts were gone from the front shackle hangers and the bellypan, and he installed new ones. He has a technique that I have never seen before. Of course, I have never seen anyone do a nutsert before, so maybe I am easily impressed! He welded up bad factory welds, cracks, and nutserts tonight. I should have "finished" welding pics tomorrow. Here are some pics from our progress tonight.
ajs-shop.jpg   finding-problems.jpg   factory-weld.jpg   thats-wire-wheel.jpg   sadie-wonder-dog.jpg
Kerrdog
Go Fish! <*////><
Unread 07-12-2010, 08:14 PM   #80
Ken4444
Corripe Cervisiam
Ken4444's Avatar
Originally Posted by Skerr View Post
Well... me and Clay went over to AJs this evening. We hauled the frame over there between rainstorms. His wife was working so we had the shop to ourselves... just me, Clay, AJ, and the dog.....
Impressive shop, that's for sure. And that wire wheel would probably make quick work of anything.
"I give you a republic, if you can keep it." - Benjamin Franklin
Ken4444 is online now   Reply With Quote Quick reply to this message
Unread 07-12-2010, 08:22 PM   #81
Skerr
Nutsert repair
Since I was so amazed by how AJ fixed the nutserts, I thought I would highlight that by itself. For anyone who is interested...
The area he is working on is one of the bolt holes for a front shackle hanger. The nutsert broke out and the PO drilled a large hole on top of the frame and bolted the hanger through the frame. He tightened it down so much that it cracked the frame around the hole. The metal is a little thin here so the repair was easy to do. Other areas, like the crossmember for the tranny where the metal was in better shape, it wasn't as easy!
AJ took a nut and bolt of the proper size and placed it over the hole.
He then took a Sharpie and marked each lobe of the nut.
Then with a cold chisel he notched each lobe.
He then took the bolt/nut combo and placed them properly over the notched hole, and with a BFH he knocked it into the hole. Go slow... the edges will take the shape of the nut and it won't spin. Don't hit it too hard and knock it into the frame! Once he set the depth he welded it up. I forgot to get a pic of that, but I will once I grind down the weld. It looked very good. I hope someone finds this useful.
Kerrdog
Go Fish! <*////><
Unread 07-12-2010, 08:26 PM   #82
Ken4444
Corripe Cervisiam
Ken4444's Avatar
So what's AJ's history, training, background? It sounds like he's done all of this before. Let me guess, he started out in the Navy?
Unread 07-12-2010, 08:26 PM   #83
Coiz
1979 CJ7
Slick idea! I like it.
Mike
My build thread
Coiz is offline   Reply With Quote Quick reply to this message
Unread 07-12-2010, 09:06 PM   #84
Skerr
I won't go into a lot about AJ, but he worked all his life. No military... he was in a biker gang! He learned by the "Hard Knocks" school. During his career he built race cars, bikes, and got into machining. He as traveled the world with the International Formula Car racing circuit, built and raced sprint cars, and he has a couple of patents pertaining to sprint cars. He is very congenial these days and can do/build virtually anything. A very, very great neighbor!
A couple of fun pics of things he built to help out around his house!
A pull behind mower from lawn mower parts and a wagon. He pulls it behind his Big Red 3-wheeler.
Simba... his homemade tractor. Chevy 350 powered!
And a grinder/sander disc. He used this tonight on Clay's frame. He cut it into a star shape to get into a crack! Worked great!
Kerrdog
Go Fish! <*////><
Unread 07-12-2010, 09:50 PM   #85
Ken4444
Corripe Cervisiam
Ken4444's Avatar
So what's your plan on prepping the frame? Are you going to go with the Marine Clean/Metal Ready/POR-15? From what I gather from reading POR-15's website, it's designed to be used over a properly prepared rusty surface, so you shouldn't need a rust converter. Are you going to prep the inside of the frame too?
Unread 07-12-2010, 10:25 PM   #86
VACJ7
Hockey Rules!
VACJ7's Avatar
That nutsert process is genious! But I guess you always have to go up to a larger nut to do it.
And that angle grinder/wire wheel is a monster. If that was me running it without a full face shield I would have wires embedded in my face! Just the way my luck goes....
VACJ7 is offline   Reply With Quote Quick reply to this message
Unread 07-13-2010, 06:02 AM   #87
Skerr
I was planning on that very process. In fact, already bought the kit. AJ says not to use it... that the POR needs rust to activate it, and if there is no rust it won't stick. I guess he feels that there is not enough rust to be confident with the bond. He says to use the Marine Clean and Metal Ready, but to coat it with Chassis Black. So that's what I'll do and save the POR for the underside of my tub.
You don't necessarily have to go to a larger nut. We did in this case because the PO drilled the hole out for a large bolt. Surprisingly, the wire was not flying off the wheel. I was thinking maybe it is the difference between cheap chain-store production tools and true commercial quality. I know all he had to do is bump the trigger on that monster and he cleaned an area.
Kerrdog
Go Fish! <*////><
Unread 07-13-2010, 11:07 AM   #88
yellow85cj
Up shift Light
As best I can tell from the 84-86 wiring diagram, there is an up shift switch and the light that are connected to the EEC and the diagnostic connector. So looks like the EEC got info somehow.
If you have downloaded the FSM it is on the instruments and instrument panel illumination page on the far right.
Currently in pieces - all of them
yellow85cj is offline   Reply With Quote Quick reply to this message
Unread 07-13-2010, 08:24 PM   #89
Skerr
Thanks for doing that research. I have downloaded the FSM and I'll check it out.
Kerrdog
Go Fish! <*////><
Unread 07-13-2010, 08:33 PM   #90
Skerr
We have returned! I feel like I'm cheating since we're not actually doing the welding, and so many of you have, but if it progresses the build with little cost, I'll do it! Here is AJ patching the rotted part of the frame. He repaired several boogered areas that the PO did... for some reason. It would be interesting to know the history of this Jeep! We plan to sandblast this weekend (uhhh... again) and then prime and coat. The goal is to do everything in one day. Already prepped Clay for a l-o-n-g day! Enjoy the pics...
Kerrdog
Go Fish! <*////><
1979 , cj5 , fiberglass , rollcage , tailgate
