Clay's Build Thread - Page 45 - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Clay's Build Thread
FS: Wranger BRIGHT License Plate LED! Just $3! Great valueIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFS: Jeep Fog Light LED Bulbs! Several Brightness Options!
Unread 11-06-2010, 04:25 PM   #661
SonicR1
Prime and paint unless you have some spots you want to smooth out.
[COLOR="Red"]... I guess I'm gonna have to fix that too…….[/COLOR]
[URL="http://www.jeepforum.com/forum/f9/sonics-05-tj-build-1168663/#post10985489"][COLOR="yellow"]The TJ[/COLOR][/URL]
2005 Wrangler X 4.0/6 speed, Dana 30/Ford 8.8--4.88--Eaton E-Lockers, 35" MT/R, Smittybilt bumpers/rockers/winch, SonicFab tire carrier, RE 3.5 springs, Zone 1.25 BL, FullTraction 3 link upper rear, RE super flex lower rears, UCF ultra high skid and lo/pro mount, brown dog mml.
[URL="http://www.jeepforum.com/forum/f8/sonics-74-cj5-build-1106795/"][COLOR="DarkOrange"]1974 CJ5 BUILD THREAD[/COLOR][/URL]
SonicR1 is offline   Reply With Quote Quick reply to this message
Unread 11-06-2010, 04:37 PM   #662
FamillyCJ7
1983 CJ7
Originally Posted by Skerr View Post
Clay started working on his dash today. He stripped the few gauges and started wire-wheeling it. It has a few "bumps" in it to knock out, and a little surface rust on the backside, but that's about it. He has new gauges coming for Christmas (he doesn't know about them- from Meemaw and Papa), so he needs to get it ready.
Do we need to apply a filler to the dash or just prime and paint?
Thanks
With sheet meal it could look nice and straight until you put paint on it and then the "waves" come out. I would apply a skim coat of filler once the high spots are knocked down and sand it smooth.
'83 CJ7 258I6 4-Speed Father Daughter Project - Using Monstaliner/Chassis Saver and Products from CrabTreeTool
NorthEastFL4x4.com - Local 4x4 Enthusiasts website, join up now!
FamillyCJ7 is offline   Reply With Quote Quick reply to this message
Unread 11-06-2010, 07:47 PM   #663
Skerr
Clay got it finished and it was dark when i got out of the woods, I'll check it out tomorrow. We may have to go with a skim coat.
Kerrdog
Go Fish! <*////><
Skerr is offline   Reply With Quote Quick reply to this message
Unread 11-06-2010, 08:02 PM   #664
Skerr
What about this? It's a little smaller than the HF, but I bet it continues to operate.
Ingersoll Rand Dual-Piston Straight-Line Sander - TP Tools & Equipment
Kerrdog
Go Fish! <*////><
Unread 11-06-2010, 08:06 PM   #665
benullman
1981 CJ7
this ones a little cheaper:
TP Tools® ProLine Straight-Line Sander - TP Tools & Equipment
TP tools makes good stuff. Its what I am going to be ordering as my 'personal' Xmas gift. A nice set of air tools.
Ben
benullman is offline   Reply With Quote Quick reply to this message
Unread 11-06-2010, 08:16 PM   #666
FamillyCJ7
1983 CJ7
Ingersoll Rand makes quality products, you won't be disappointed.
Unread 11-06-2010, 08:26 PM   #667
benullman
1981 CJ7
I agree completely. I just wanted to show him a little cheaper alternative. If I had the $$ i would buy IR EVERYTHING. they got good stuff!
Ben
Unread 11-06-2010, 10:24 PM   #668
Skerr
Ben
Man I hate to say it, but that one looks EXACTLY like the one I turned into a boat anchor! Notice the last 4 words of the description... imported for TP Tools. All the specs are identical.
Kerrdog
Go Fish! <*////><
Unread 11-07-2010, 06:11 AM   #669
gmakra
Clay you continue to shoot yourself in the foot with a AK47 in full auto and reloading several times.Get the Ingersol Rand 8 inch gear driven DA Sander also known as a Mug Hog with 40 grit paper. That will calm your seas down quite a bit. Its much faster than a air file and is less likely to give you waves. Then hit the panel with your Dura Block sanding blocks, otherwise you are really making things much harder on yourself.
Ingersoll Rand Heavy Duty Air Geared Orbital Sander with 8 Inch Pad, Model 328
Dura-Block® Sanding Blocks - TP Tools & Equipment
gmakra is offline   Reply With Quote Quick reply to this message
Unread 11-07-2010, 07:06 AM   #670
243
1978 FSJ Cherokee
I would agree Scott, a good quality DA would be far more useful than an air file.
1978 Cherokee, 360/T400/QT...5.3/4L60E/NP241C in the works...
243 is offline   Reply With Quote Quick reply to this message
Unread 11-07-2010, 08:13 AM   #671
gmakra
243 Actually my name is George but Ill answer to any pronoun or adjective.
Unread 11-07-2010, 09:31 AM   #672
benullman
1981 CJ7
Skerr:
http://www.jeepforum.com/forum/f8/my.../#post10411437
Ben
Unread 11-07-2010, 09:37 AM   #673
243
1978 FSJ Cherokee
I will call you George except when I am agreeing with you and talking to Scott
Unread 11-07-2010, 09:52 AM   #674
Skerr
OWWWWWW! You would use the DA over surfaces with curves, or on flat surfaces onnly?
I already have one, but I was worried that I would remove TOO MUCH material, causing valleys. What PSI do you guys recommend?
"I will hold him and pet him and I will call him George!"
I will call you George except when I am agreeing with and talking to Scott
George... I'm Scott, the guy that does the posting. Clay is my son who actually owns the Jeep (I gave it to him), and Dave is one of my Texas connections!
Kerrdog
Go Fish! <*////><
Unread 11-07-2010, 10:08 AM   #675
benullman
1981 CJ7
Scott, the DA is used on pretty much everywhere. I set mine at 100 PSI (8cfm) andI vary the speed with the actual lever. Just feel it out you will get used to it.
Ben
1979 , cj5 , fiberglass , rollcage , tailgate
