Clay's Build Thread - Page 354 - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Clay's Build Thread
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineNEW ZJ Grand Cherokee Tube DoorsGibson WK HEMI 3" Catback - 5 Day Special!
Unread 11-01-2013, 05:36 PM   #5296
gmakra
Ken the pressure switches you are talking about are in series with the clutch. The Low Pressure one stops the compressor so that you do not go into a vacuum and draw air into the system. The High Pressure shuts the compressor off before you burst the refrigerant lines also wired in series with the clutch.
gmakra is offline   Reply With Quote Quick reply to this message
Unread 11-01-2013, 05:55 PM   #5297
SLO_Ken
Right. Scott said the computer was throwing a code and he though it may be related to the fact that it was looking for switches that are not there, since he doesn't have AC on his rig. Those switches are integral to the proper function of an AC system, and should not be bypassed on a working system.
California 4.0 OBDII Engine Swap
http://www.jeepforum.com/forum/f8/california-4-0-obdii-swap-1530716/
SLO_Ken is offline   Reply With Quote Quick reply to this message
Unread 11-01-2013, 06:33 PM   #5298
Skerr
I have an A/C relay in place, so that won't do it. This stuff is waaay beyong my thinking ability! Let me try measuring the resistance, as Ken mentions. But I sure like the idea of twisting wires together!! Thanks, Ken, for following up on this. I intend to install a CEL on Clay's dash, but there's no point if it is always going to be on.
Kerrdog
Go Fish! <*////><
Skerr is offline   Reply With Quote Quick reply to this message
Unread 11-02-2013, 05:35 AM   #5299
gmakra
Skipper look at the bottom of the diagram in the middle you will see what is called a AC sense switch, that's the dohickey you need or simulate it.
Unread 11-02-2013, 07:11 AM   #5300
Skerr
But I don't have anything from the dash panel? I have only the under-hood stuff. Should I try to locate that sensor under the dash?
Kerrdog
Go Fish! <*////><
Unread 11-02-2013, 12:39 PM   #5301
Skerr
Clay picked these up at auction today...
Kerrdog
Go Fish! <*////><
Unread 11-02-2013, 12:47 PM   #5302
ScroungerLee
What will he use them for? Something Jeep related?
ScroungerLee is offline   Reply With Quote Quick reply to this message
Unread 11-02-2013, 01:23 PM   #5303
Skerr
You see him smiling? He planned to put the big medical box in the back of his Jeep, but it doesn't fit with the rollcage bars back there. You should have seen his lip hit the ground! But he got re-energized when he realized it will fit on his hitch mounted cargo rack!!
He also got these rusty 'ol nasty things...
Kerrdog
Go Fish! <*////><
Unread 11-02-2013, 01:28 PM   #5304
ScroungerLee
They look almost like giant pipe cutters, but I don't think they are, therefore I will give up and ask. What are they?
Unread 11-02-2013, 04:45 PM   #5305
Skerr
If you had guessed giant pipe cutters you would have been correct! Ridgid brand. Oldies but goodies... for cutting tubing, DOM, etc...
Kerrdog
Go Fish! <*////><
Unread 11-02-2013, 07:34 PM   #5306
ScroungerLee
Bah humbug
Unread 11-07-2013, 10:45 PM   #5307
lucdog
lucdog's Avatar
1980 CJ5
Scott, Being realistic I doubt you could expect any better gas mileage from Clays Jeep, than what you posted in SloKens thread. Our ,94 YJ with the 4.0, automatic, 3.07 gears,stock tires, tuned up, and no lift, only got 16 mpg at 70 mph/2000rpm, this was with a light right foot, and me being overly conscious of mpg's. add in Clay's lift and oversized tires, I think your lucky to be getting 14/16 mpg's, and you can't be certain of the mileage, because its a guessing game because you haven't corrected the speedo. I would guess your getting closer to 12/13 mpg's.
The best combined mileage I've Calculated with the '05 Rubicon , with a cautious right foot is 17.2 mpg's. this is with a lock-up torque converter, and a overdrive tranny. Tires are 245.75.16.(30.5.9.50 tire) with 4.10 gears.
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7
1989 YJ the CJ to YJ.
lucdog is online now   Reply With Quote Quick reply to this message
Unread 11-29-2013, 05:12 PM   #5308
Skerr
You won't believe what he has done. I can't even speak about it! I don't feel so good.
Kerrdog
Go Fish! <*////><
Unread 11-29-2013, 06:00 PM   #5309
Scott3140
Junior Member
Scott3140's Avatar
Please tell, please tell.
Scott3140 is offline   Reply With Quote Quick reply to this message
Unread 11-29-2013, 07:10 PM   #5310
Cutlass327
Cutlass327's Avatar
1978 CJ5
Talk about suspense!
Rick
http://www.jeepforum.com/forum/f8/ri...8-cj5-1223197/
Cutlass327 is offline   Reply With Quote Quick reply to this message
1979 , cj5 , fiberglass , rollcage , tailgate
