Clay's Build Thread - Page 352 - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Clay's Build Thread
JKS Grand Cherokee WJ, Adjustable Front Trackbar 1"-6Teraflex JK HD Hinged Carrier & Adjustable Spare Tire FREE, FREE, FREE EVENT!! Save big on Lockers now till Apri
Unread 09-19-2013, 09:35 PM   #5266
Skerr
Originally Posted by EgulAye View Post
It's great to see you got the Jeep running well. Did you ever pull the pistons or crank out of Clay's old block? I'm kinda wondering what they look like. I've been reading the thread a few pages a day since April this year. I've finally read every post. It's quite the saga you've recorded here. Nice work!
Wow, Egul... you're a glutton for punishment! I hope you found some entertainment value in it.
Clay's Jeep is running good. I offered to trade with him, but he isn't having any! His 4.0 is runnig rich, to the point that the exhaust burns your eyes. That seems to be the biggest issue. I will get it up to the shop I use and have them pull the codes. We have several JY sensors in the system.
Clay's old pistons looked ok, but they had so much carbon on the tops that it was flaking off. Cylinders were not alarming, but there was a nice lip at the top. Cam showed some wear. Crank looked okay. Lifters/pushrods looked alright overall. Nothing jumped out that indicated any problems. I sold the block to another Jeeper (a guy I work with) and he is having it built right now. I'm trying to get him to become active on JF.
Kerrdog
Go Fish! <*////><
Skerr is offline   Reply With Quote Quick reply to this message
Unread 09-20-2013, 06:04 AM   #5267
gmakra
Skipper are you running a cat on Clays Jeep?
The only other thing I can think of is the fuel pressure is to high and you dont have a fuel pressure regulator hooked up or its set at the wrong pressure.
gmakra is offline   Reply With Quote Quick reply to this message
Unread 09-20-2013, 08:05 AM   #5268
Skerr
Professor- no cat. The pressure reg is new and factory, on the rail. I haven't tested it yet, however. I will do that and post.
Kerrdog
Go Fish! <*////><
Unread 09-21-2013, 05:23 PM   #5269
Skerr
Fuel pressure is 40# pressurized by the pump. With engine running it is 30.5#. I think everything is as it should be. But the exhaust is very rich.
Kerrdog
Go Fish! <*////><
Unread 09-22-2013, 08:34 AM   #5270
gmakra
Where is your O-2 sensor located?
And I am thinking a Cat would help alot even if you got one from a junkyard.
Unread 09-22-2013, 03:47 PM   #5271
Skerr
O2 sensor is just downstream from the header. OBDI did not have a sensor downstream from the cat.
Kerrdog
Go Fish! <*////><
Unread 09-22-2013, 06:26 PM   #5272
gmakra
Skipper I know that OBD2 have pre and post cat O-2 sensors OBD only has the pre cat.
I wonder if the O-2 sensor is too far downstream to get a good signal, it has to get to 600 degrees to read correctly.
Unread 09-22-2013, 06:42 PM   #5273
SLO_Ken
AFAIK, the O2 sensors in both the OBDI and OBDII setups are all heated. Their position in the exhaust pipe should not have a noticeable effect on their performance.
SLO_Ken is offline   Reply With Quote Quick reply to this message
Unread 09-22-2013, 10:16 PM   #5274
TJ-Joe
IRRC, only 4-wire O2 sensors are heated - the two-wire are not. I thought heated O2 sensors on ODBI were only used for California models ...
TJ-Joe is offline   Reply With Quote Quick reply to this message
Unread 09-23-2013, 02:11 PM   #5275
Cutlass327
Cutlass327's Avatar
1978 CJ5
3 or 4 wire sensors are heated, 3 are rarely used though. Single wire need to be pretty close to the manifold to work properly.
Rick
http://www.jeepforum.com/forum/f8/ri...8-cj5-1223197/
Cutlass327 is offline   Reply With Quote Quick reply to this message
Unread 09-23-2013, 09:27 PM   #5276
Skerr
Well, shoot... I didn't know any of this! I have no idea if it is close enough or not. You can reach it bending over the fender.
Kerrdog
Go Fish! <*////><
Unread 09-23-2013, 10:30 PM   #5277
VACJ7
Hockey Rules!
VACJ7's Avatar
Is it a 2 or 4 wire O2 sensor? Could always buy a heated sensor.
'84 CJ-7 | REBUILD IN PROGRESS
VACJ7 is offline   Reply With Quote Quick reply to this message
Unread 09-23-2013, 11:34 PM   #5278
Kastraelie
1977 CJ7
Wow that's good to know
Building out a Jeep is like trying to smother a fire with twenty-dollar bills. You just never have enough at once to put it out...
My Frame-Off
Kastraelie is offline   Reply With Quote Quick reply to this message
Unread 09-24-2013, 03:28 PM   #5279
Skerr
2, I think, Paul. I'll look into this. How do you connect a power source?
Kerrdog
Go Fish! <*////><
Unread 09-24-2013, 05:10 PM   #5280
VACJ7
Hockey Rules!
VACJ7's Avatar
I will have to look at mine. Assume it is hot-in-run and a ground for the extra 2 wires.
1979 , cj5 , fiberglass , rollcage , tailgate
