Clay's Build Thread - Page 347 - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Clay's Build Thread
FS: Jeep Fog Light LED Bulbs! Several Brightness Options! *STOP UNWANTED LIGHT BAR NOISE* with Pandemic LED Light BaRuffstuff 10 year sale
Unread 08-07-2013, 09:51 AM   #5191
lucdog
lucdog's Avatar
1980 CJ5
Originally Posted by Matt1981CJ7
Guys,
The stand-off is solid with a concave depression for the ball to sit in.
Has anyone considered modifying the fork, somehow?
What a PITA!
Matt
I have, I was just talking to Jim1611 about that 5 minutes ago. We both think it may be the best route.
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7
1989 YJ the CJ to YJ.
lucdog is online now   Reply With Quote Quick reply to this message
Unread 08-07-2013, 10:01 AM   #5192
243
1978 FSJ Cherokee
I posted about the fork earlier, the problem as I see it, is I don't see it.
No pictures of the fork in relation to the bellhousing are posted to assist in understanding the problem.
KISS, what is the path of least resistance?
Go back and look at this post and tell me why the clutch fork is notched?
http://www.jeepforum.com/forum/f8/cl...l#post15749882
And this one too...
Originally Posted by Skerr View Post
The top clutch fork is for a T150. In the article, the author states that it is factory punched to clearance a bolt head. He goes on to say that if you don't clearance the fork on the T18 it may not allow the pressure plate to release. That isn't our problem. Our fork is hitting the housing. I didn't get to talk to Warren this afternoon, so I don't know how far he got. Now we have to wait until Monday. Never thought about clearancing the fork... that may have been all we needed to do. Also, if Warren hasn't already fixed it, I will look into the TO bearing for the 4.0 clutch set. Thanks, Dave.
I don't understand this, "clearance a head bolt".
1978 Cherokee, 360/T400/QT...5.3/4L60E/NP241C in the works...
243 is offline   Reply With Quote Quick reply to this message
Unread 08-07-2013, 10:37 AM   #5193
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
243,
As I understand it, the 4.0 flywheel is thinner than the 258, and the CJ clutch fork doesn't have enough travel to disengage the disk from the flywheel.
Someone please correct me, if I'm wrong.
Matt
Matt1981CJ7 is offline   Reply With Quote Quick reply to this message
Unread 08-07-2013, 11:32 AM   #5194
lucdog
lucdog's Avatar
1980 CJ5
243,
Matt
This is correct Matt.
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1983 CJ7
Unread 08-07-2013, 11:56 AM   #5195
lucdog
lucdog's Avatar
1980 CJ5
I've mocked up a Jeep T18, bell housing, lever and throw out bearing.
From Scotts info the clutch arm is hitting the bell housing. This picture shows the clutch arm touching the bell.
And the location of the throw out bearing with the arm still touching the bell.
As you can see the bearing is at the end of the tranny bearing retainer. I can only guess Clays Jeep looks the same.
What I'm seeing is even with the stand off for the ball moved, or the clutch arm modified by 1/2", the TOB will come off the end of the retainer. Not good!
I don't see a way around this, yet.
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1983 CJ7
Unread 08-07-2013, 12:24 PM   #5196
243
1978 FSJ Cherokee
The ball pocket can be cut out and relocated to correct the fork alignment, and the other end could be lengthened to keep the same OAL.
Unread 08-07-2013, 12:30 PM   #5197
Matt1981CJ7
1981 CJ7
Forgive me, if I missed this....why can't Scott use the 258 flywheel and starter, then move the CPS to the balancer?
Matt
Unread 08-07-2013, 12:33 PM   #5198
lucdog
lucdog's Avatar
1980 CJ5
I agree Dave, but that doesn't solve the issue of the TOB possibly coming off the end of the bearing retainer.
B
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1983 CJ7
Unread 08-07-2013, 12:37 PM   #5199
jeepwhore
Matt
I'm guessing because the hesco damper kit is $$$.
'84 CJ-7: Yota axles (spartan locked front, e-locked rear) 4" BDS, 1" Daystar & 3/8" shackle lifts, 35" X-Terrains on steelies, YJ Tub & family roll bar, heater blower upgrade, 4.2L w/MC2100 & Team Rush, Warn 8274. Rebuilt 4.2/4.0 hybrid, AX15 and twin sticks/clocking ring waiting to go in.
The advertised position for a topless, dirty jeep girl has been filled......by my wife. Thanks to all that applied.
<------------and yes, that is her.
:-D
jeepwhore is online now   Reply With Quote Quick reply to this message
Unread 08-07-2013, 12:48 PM   #5200
lucdog
lucdog's Avatar
1980 CJ5
Matt
That is one of the options, look for a text message.
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1983 CJ7
Unread 08-07-2013, 12:50 PM   #5201
Matt1981CJ7
1981 CJ7
True. But in these cases, I figure time and lack of frustration are also worth something.
It still blows me away that no one has ever run into this problem before.
Matt
Unread 08-07-2013, 12:51 PM   #5202
243
1978 FSJ Cherokee
B
Moving the pivot pocket would move the forks under the bearing. This may require lengthening the opposite end to keep the same OAL.
KISS!
Unread 08-07-2013, 12:52 PM   #5203
Jim1611
Jim1611's Avatar
Can there be a spacer between the throw out bearing and pressure plate? Moving the bearning back towards the clutch arm the 1/2" distance that seems to be the problem. Bill wouldn't that solve the problem of the bearing going off the retainer?
Jim1611 is offline   Reply With Quote Quick reply to this message
Unread 08-07-2013, 01:11 PM   #5204
243
1978 FSJ Cherokee
Unread 08-07-2013, 01:27 PM   #5205
Matt1981CJ7
1981 CJ7
Damn, Jim, I was thinking the same...like a 1/2" thick washer between the thrust bearing and pressure plate. Right?
Matt
1979 , cj5 , fiberglass , rollcage , tailgate
