Clay's Build Thread - Page 343 - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Clay's Build Thread
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineWIN a Rough Country Forged Track Bar - ExtremeTerrain!1987-2016 Wrangler Jammock Black 2.0 Jeep Hammock (YJ, TJ
Unread 07-17-2013, 09:26 PM   #5131
lucdog
lucdog's Avatar
1980 CJ5
Originally Posted by 243
But I am proud of ya, way to stick to it with the 4.0
I couldn't agree more with this.
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7
1989 YJ the CJ to YJ.
lucdog is offline   Reply With Quote Quick reply to this message
Unread 07-17-2013, 09:59 PM   #5132
Jim1611
Jim1611's Avatar
Another pump shotgun well worth owning and less money is the Mossberg 500. I bought one 30 years ago and it's still just as reliable as the 870.
So Clay should be driving his Jeep pretty soon huh, that's great.
Jim1611 is offline   Reply With Quote Quick reply to this message
Unread 07-17-2013, 10:10 PM   #5133
lucdog
lucdog's Avatar
1980 CJ5
I'm liking this one. 9, 2.750" shells.
B
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1983 CJ7
Unread 07-18-2013, 05:42 PM   #5134
Skerr
wellllllllllllllll............ Beth came home! She says "What? It's just a shotgun?" "You don't need another shotgun!"
On another note... I already have 500s and 870s. Your preaching to the choir!
Kerrdog
Go Fish! <*////><
Skerr is offline   Reply With Quote Quick reply to this message
Unread 07-18-2013, 07:52 PM   #5135
Skerr
Installed the XJ steering box on the CJ. The gear box bolts up to the CJ bracket using all 3 holes instead of the 4 that a CJ has. The XJ box has a factory drop pitman arm. It places the draglink slightly BELOW level... just opposite the slightly above with a 2.5" lift. The CJ steering shaft bell coupler has a larger spline shaft than the XJ making it so the CJ shaft will not firmly slide onto the XJ gear box. Not even lossely for that matter! Was thinking about using a piece of 1/2" EMT as a bushing to weld around the XJ shaft, then slide the CJ bell coupler over that. THEN we discovered the XJ telescoping steering shaft is the same shape as the CJ telescoping shaft. I separated the XJ shaft and slid it into the upper CJ shaft, but it is too short to reach the gearbox. SO... we will cut off ~3" of CJ shaft and weld it to the XJ shaft. That should do it.
Dad-Gone Mosquitoes!
Kerrdog
Go Fish! <*////><
Unread 07-18-2013, 09:26 PM   #5136
lucdog
lucdog's Avatar
1980 CJ5
No Mosquitoes in Missouri at the lake, just family, boats and fun!!!
Good call nixing the EMT.
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1983 CJ7
Unread 07-19-2013, 08:22 AM   #5137
Skerr
Bill
Mehhh... it's one of those rambling thoughts you get when you say to yourself... "I wonder if..."
The mosquiteos around here, right now, are indescribable! Even with the floor fan blowing you don't want to be on the creeper under the Jeep!
Just a side thought... a box (50) Blazer .9mm is $45!!!! Up from $9.95!
Airsoft battle tomorrow, Fallon turns 14 today, big party. Gotta mow grass, trim hedges, burn the burn pile, FIX THE JEEP, cut okra... I feel so old.
Kerrdog
Go Fish! <*////><
Unread 07-19-2013, 04:37 PM   #5138
Skerr
Well, Boys... this has been one 'O dem days where you get a LOT of stuff done! My kids were rocking. We are ready for the BD party tomorrow, and I didn't have to do anything!
Here are some pics of the XJ/CJ steering shaft mod. In a nutshell... we have the 4.0 in the 5. The power steering does not easily bolt up like I expected... involving bracket and pulley mods. So with the serp belt we used a factory XJ pwr steer pump. This changes the fitting to the CJ gear box from flared to O-ring. So the gear box is changed to XJ. The XJ box has only 3 mounting holes, whereas the CJ has 4. I hope it holds up. The XJ box will use the CJ bracket with no mods. The XJ gear box has a smaller diameter input shaft than a CJ, so the CJ bell coupler will not just slide on and clamp down. Also, the XJ steering shaft is shorter than a CJ. The lower (I don't really know WHAT to call it, but it is the lower part of the telescopic steering shaft) steering shaft of an XJ and a CJ are the same. I cut about 4" off a CJ lower steering shaft and welded it to the lower XJ shaft, making it long enough and compatible to the XJ gear box. Now I am bending/shaping the metal lines to reach the gear box. Looks like this might actually work!
The first pic is the stub cut from the CJ shaft, and then I'm showing how I welded it and ground it down. I wirewheeled it, prepped it, and painted it. It is installed and in working order. This was not a hard mod. I don't think it is worth doing unless you are in the same position as we are. For a CJ steering improvement I would just buy a rebuilt gear box.
Oh yeah... the last pic is showing the rebent hard lines for the pump.
Kerrdog
Go Fish! <*////><
Unread 07-19-2013, 05:13 PM   #5139
lucdog
lucdog's Avatar
1980 CJ5
Scott, is there any rubber line between the pump and steering box? There should be.
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1983 CJ7
Unread 07-19-2013, 05:57 PM   #5140
mvigo
mvigo's Avatar
Bill
great catch Bill...after looking at his picture it does look like there is one rubber line but not 2?
1985 CJ-7, fuel injected 258, 2.5" Rubicon Express Extreme Duty Lift, 1" Body lift, Crabtree Shackle Hangers, T-5, Dana 300 w/ 4:1 Teralow kit, Dana 30, AMC 20 w/1 piece axle, 3.73 's with Detroit Truetrac front and rear, riding on 32x11.5x15" Cooper Discoverer STT mud terrains
mvigo is offline   Reply With Quote Quick reply to this message
Unread 07-19-2013, 07:58 PM   #5141
Skerr
Yep. The pressure and return lines are combo rubber/steel lines just like a CJ. I had to bend the preshaped metal parts to get the lines to point between the pump and gear box. You can actually see the return line under the pressure line in the last pic. The return line attaches to the back of the pump.
Kerrdog
Go Fish! <*////><
Unread 07-19-2013, 08:09 PM   #5142
lucdog
lucdog's Avatar
1980 CJ5
10-4 good buddy!
B
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1983 CJ7
Unread 07-20-2013, 12:37 AM   #5143
Dadamsnv
1977 CJ5
Nice welds Scott
Is that welder the one I saw at Home Depot? How do you like it??
Cheers!
Dadamsnv is offline   Reply With Quote Quick reply to this message
Unread 07-20-2013, 11:02 AM   #5144
Jim1611
Jim1611's Avatar
Scott I don't think I'd trust that steering shaft the way you all welded it. Those are short welds and that means not much heat got into the weld. Better to have been tigged. If it were me I'd have ground the ends almost to a point then welded it with the mig. Just my opinion but it is what guides the thing and at times there can be allot of twisting pressure on that shaft. Get a tire up against a rock, in a rut or against a curb and try to turn the wheel it could break. Worse yet it cracks then breaks at speed on the highway later.
Unread 07-20-2013, 01:27 PM   #5145
Dadamsnv
1977 CJ5
I agree, I was thinking you could weld a sleeve over the joint or a couple fish plates or something. If you cut a tube in half long ways and welded the two halves over the shaft joint you'd reform the sleeve and weld it to the shaft.
Cheers!
1979 , cj5 , fiberglass , rollcage , tailgate
