Clay's Build Thread - Page 341 - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Clay's Build Thread
BDS 4-1/2" Suspension Lift Kit - Jeep Wrangler YJRuffstuff 10 year saleRough Country Lift Kits and Parts!
Unread 07-14-2013, 08:43 PM   #5101
WNC-84CJ7
A running engine?! My jealousy knows no bounds. We visited another (closer) church today. What a great message on meekness- apparently something I could use a good dose more of. Like Jim said, remember the things we did at 19? Great job Scott and Clayton. I'll call you this week- I start my new job this week STAY AT HOME DAD!!!!!!!!!! Yes!!!!!!!!! CJ here I come!
"No free man shall ever be debarred the use of arms. The strongest reason for the people to retain the right to keep and bear arms is, as a last resort, to protect themselves against tyranny in government"
-- Thomas Jefferson, 1 Thomas Jefferson Papers, 334
WNC-84CJ7 is offline   Reply With Quote Quick reply to this message
Unread 07-14-2013, 09:24 PM   #5102
Scott3140
Junior Member
Scott3140's Avatar
Ok lets get her slinging some of that mud you have after all that rain!!!! Way to go!!!!
Scott3140 is offline   Reply With Quote Quick reply to this message
Unread 07-14-2013, 10:09 PM   #5103
Dadamsnv
1977 CJ5
Cheers!
Dadamsnv is offline   Reply With Quote Quick reply to this message
Unread 07-14-2013, 10:11 PM   #5104
mvigo
mvigo's Avatar
by far one of the happiest moments of my JeepForum life...
1985 CJ-7, fuel injected 258, 2.5" Rubicon Express Extreme Duty Lift, 1" Body lift, Crabtree Shackle Hangers, T-5, Dana 300 w/ 4:1 Teralow kit, Dana 30, AMC 20 w/1 piece axle, 3.73 's with Detroit Truetrac front and rear, riding on 32x11.5x15" Cooper Discoverer STT mud terrains
mvigo is offline   Reply With Quote Quick reply to this message
Unread 07-14-2013, 10:32 PM   #5105
Skerr
Humility is one of the toughest lessons we will ever learn, if we're lucky enough to learn it! It takes a lifetime. Looking forward to your call. We'll see just how much time you get with the CJ!!
Believe it or not, the sandy hill that I live on perks the water right on down. 22" of rain this year, at one time, and in an hour after it was over it was all gone! But I sure would like to have it where it COULD sling some mud! Trying to decide if I am going to pursue this more or take it to the shop I use and let them finish it up. Time is an issue.
Originally Posted by Dadamsnv View Post
Thanks, Dada!
You and me both! Thanks, Mike.
Here's a cigar for each of you. A good Monte Cristo...
Kerrdog
Go Fish! <*////><
Skerr is offline   Reply With Quote Quick reply to this message
Unread 07-15-2013, 05:51 AM   #5106
243
1978 FSJ Cherokee
Great job Team Kerr
Timing? The TBI requires static timing to be set to "zero" and the ECM handles it from then on...is the 4.0 the same?
1978 Cherokee, 360/T400/QT...5.3/4L60E/NP241C in the works...
243 is offline   Reply With Quote Quick reply to this message
Unread 07-15-2013, 10:04 AM   #5107
SLO_Ken
Originally Posted by Skerr View Post
Checked my notes. I see ground. Ground!? What's a ground? I don't need no stinkin' ground... it's SITTING on the ground. It says "Check PCM ground". So I did. There are three of them. NONE of them was connected. So I connected them. Guess what? I HAVE A SPARK AT THE PLUGS!!!!! THANK YOU, JESUS! You get the Glory.
I. AM. SO. HAPPY!!!!
Isn't that the 5th wire of the "five wires to fire?" Good job! Now I've got to get mine running so I don't fall too far behind
SLO_Ken is offline   Reply With Quote Quick reply to this message
Unread 07-15-2013, 07:15 PM   #5108
Skerr
Originally Posted by 243 View Post
Great job Team Kerr
Yep... it works the very same. Miscalculating on the CPS location could really play havoc with it too, and it was all Clay's baby! Went out there tonight, plugged up some large vacuum leaks. Battery had been charging. Tied up the wiring a to neaten it up a bit. Turned the key. VRROOOOOM! AHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAH AHAHA.....................................
5TH, 6TH, 7TH, AND 8TH, I think! Without your input, Ken, I wouldn't be AHEAD OF YOU!! Sorry, Dude. I'm not racing. Your help was integral!
Eating supper and then going to go listen to the Jeep run for a bit. Radiator is now connected.
Kerrdog
Go Fish! <*////><
Unread 07-15-2013, 07:40 PM   #5109
lucdog
lucdog's Avatar
1980 CJ5
Awesome!
B
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7
1989 YJ the CJ to YJ.
lucdog is online now   Reply With Quote Quick reply to this message
Unread 07-15-2013, 08:27 PM   #5110
Dadamsnv
1977 CJ5
What a beautiful sound it is I'm sure
Cheers!
Unread 07-15-2013, 08:29 PM   #5111
VACJ7
Hockey Rules!
VACJ7's Avatar
Video or it never happened.
'84 CJ-7 | REBUILD IN PROGRESS
VACJ7 is offline   Reply With Quote Quick reply to this message
Unread 07-15-2013, 10:27 PM   #5112
Skerr
You have to go back to the future Paulie! It's on the previous page. You can disregard the second video. I have that figured out now.
Kerrdog
Go Fish! <*////><
Unread 07-16-2013, 06:51 PM   #5113
VACJ7
Hockey Rules!
VACJ7's Avatar
This post? It takes me to photobucket but no video. Guess I don't get to hear or see it running. Very sad....
Unread 07-16-2013, 07:53 PM   #5114
Skerr
Yeah, dang... works for me! Anybody else have a problem with the video??? Maybe it needs more time to load???
Me'n Clay were working on it this evening, and I removed the rubber boot from the TB. Found we had stuffed a paper towel down inside. YIKES!! Thankfully it was still in one piece!
Got the power steering pump installed, but I broke the pulley! Can't get the center bolt loose to remove it!!! I assume you can buy the pulley separately?? Maybe have to get another JY pump. Other than that it is ready for a belt and a real run test.
Kerrdog
Go Fish! <*////><
Unread 07-16-2013, 08:05 PM   #5115
lukenicwalker
1982 CJ7
Yep. Watched it. Did a little dance.
ldw
lukenicwalker is offline   Reply With Quote Quick reply to this message
1979 , cj5 , fiberglass , rollcage , tailgate
