Clay's Build Thread - Page 331 - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Clay's Build Thread
WIN a set of Mammoth Boulder Wheels at ExtremeTerrain.com!Savvy Aluminum Gas Tank SkidTruck & Jeep Fest 2015 - Edmonton
Unread 06-01-2013, 10:19 AM   #4951
Skerr
[QUOTE=243;15505516]Dude, my cousin-out-law had a WRX and I rode with him from my Mom's place over the causeway to Galveston to pick up some odds and ends, I have to say that son-of-a-bisquit was blindingly fast; in fact, I think that flat-four WRX pulled harder than any street car I have been in in my life.[/QUOTE]
nuff said...
Kerrdog
Go Fish! <*////><
Skerr is offline   Reply With Quote Quick reply to this message
Unread 06-01-2013, 10:37 AM   #4952
Skerr
After ALL THESE YEARS OF READING. Reading things that didn't make ANY sense at all! Thinking, "I need to understand", but never really getting it. IT HAS ALL COME CRASHING TOGETHER IN A CULMINATION OF JEEP KNOWLEDGE NEVER BEFORE EXPERIENCED BY ANY HUMAN! Yep. It's true. I wouldn't lie. You KNOW me! Sooo, you wanna know what happened this morning?? C'mon... guess. Yep. I GOT IT!
PILOT BUSHING REMOVAL
Pilot bushing, you say? You want to know what a pilot bushing is, and what it does?? I don't have any idea! I just know you need it, AND I know WHERE IT GOES, and HOW TO GET IT OUT! Thanks to the members of this heer forim.
You can see, in the pics that follow, the 258 block sitting quietly, although without grace, in the trailer.
Then, you can see the pilot bushing with my indispensible can of Sili-Kroil... compliments of a friend in Illinois.
Then some bread. Yeah, yeah, I was a might peckish.
Fill the hole with bread.
Drive in a large bolt. Add more bread, if needed.
And, DEWD! IT COMES RIGHT OUT!
That is the coolest thing I have ever experienced. Even better than a WRX gittin it over a causeway!
Too bad the pilot bushing for a T18 DOES NOT FIT A 4.0L! Going to have to get it turned down. The new one is aluminum? Why is the brass one so chewed up? Which one should I use? Delays, delays...
Kerrdog
Go Fish! <*////><
Unread 06-01-2013, 10:47 AM   #4953
Jim1611
Jim1611's Avatar
I've used grease in place of the bread. Amazing that an old way of doing things is still around. You'd think the obd1 would be able to take that out for you, even though it is in the 258. Computers.....well let me just say they can't replace the human brain. Did you have any bread left over for a sandwhich? Aint you glad Papa Billy is so old and knows this stuff?
Jim1611 is offline   Reply With Quote Quick reply to this message
Unread 06-01-2013, 12:16 PM   #4954
jeepwhore
Hair puller xtraordinaire
jeepwhore's Avatar
Sorry Scott, I forgot all about the wiring stuff for the 4L.
Turns out I told a half truth, .
The bulkhead info I have is for a '94 XJ. But I have a pin out for the ECM connection as well and it is for '91 through '93. I can only assume the bulkhead connector will be the same through those years as far as the main terminals go......and I haven't found anything to contradict that assumption......yet.
I stole these pics from other threads but they show the cavities you need.
'79 bulkhead:
12A is your main power feed
13B is your ignition crank, and
14B is your ignition crank & run
'94 bulkhead (ignore the text regarding the YJ wiring):
12A should be spliced to E4 on the donor harness (Ignition switch feed-10G red).
13B should be spliced to H2 on the donor harness (Engine starter relay-14G yellow)
14B should be spliced to B6 on the donor harness (Ignition start/run-12G dark blue)
The only thing I haven't addressed is the fuel pump. Near as I can tell you just use cavity C4 on the donor harness to trigger the fuel pump relay.
'84 CJ-7: Yota axles (spartan locked front, e-locked rear) 4" BDS, 1" Daystar & 3/8" shackle lifts, 35" X-Terrains on steelies, YJ Tub & family roll bar, heater blower upgrade, 4.2L w/MC2100 & Team Rush, Warn 8274. Rebuilt 4.2/4.0 hybrid, AX15 and twin sticks/clocking ring waiting to go in.
The advertised position for a topless, dirty jeep girl has been filled......by my wife. Thanks to all that applied.
<------------and yes, that is her.
:-D
jeepwhore is offline   Reply With Quote Quick reply to this message
Unread 06-01-2013, 12:18 PM   #4955
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
Sandwich?!? Are you kidding me? Did you see the feed-bag Scooter put on this morning?
Now I'm getting hungry....
Matt
Matt1981CJ7 is offline   Reply With Quote Quick reply to this message
Unread 06-01-2013, 12:40 PM   #4956
lucdog
lucdog's Avatar
1980 CJ5
Matt
Tape worm, probably see its head when he yawns.
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7
1989 YJ the CJ to YJ.
lucdog is offline   Reply With Quote Quick reply to this message
Unread 06-01-2013, 01:05 PM   #4957
Matt1981CJ7
1981 CJ7
Bill, dude, you've been tearing it up, lately.
Matt
Unread 06-01-2013, 02:00 PM   #4958
Skerr
If you use grease you end up getting... greasy. And you know how I like to stay clean when I work!
'79 bulkhead:
Beautiful! Just what I needed. Thanks so much, JW.
Matt
Matt
Yeeeeesssssss, he has, hasn't he!? But you just wait... he'll post up pizza and beer within the next 2 days. Betcha...
I can't help it. This comment made me laugh until I had snot running down my chin! And you captured your one intellectual thought on the world wide web. Freakin' miracle.
Kerrdog
Go Fish! <*////><
Unread 06-01-2013, 04:00 PM   #4959
lucdog
lucdog's Avatar
1980 CJ5
Matt
Keep feeding me,
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1983 CJ7
Unread 06-01-2013, 04:08 PM   #4960
Matt1981CJ7
1981 CJ7
Keep feeding me,
From shooting blanks, to Peep shows, to tape worms....ahhh, I love the JF.
Matt
Unread 06-01-2013, 05:13 PM   #4961
Skerr
I was installing the new 258 water pump on the 4.0 block. Clay had it painted up. The vanes on the pump hit the cylinder sleeve! The old 258 pump doesn't hit. The 4.0 pump doesn't hit. The new pump hits!
Kerrdog
Go Fish! <*////><
Unread 06-01-2013, 05:37 PM   #4962
jeepwhore
jeepwhore's Avatar
The 4L bore is .125 larger but i wouldn't think that would make the vanes hit the cyl wall.....but you made sure to get the 4.2 pump for a serp belt, right?
Actually, why use a 4.2 pump at all?
:-D
Unread 06-01-2013, 07:10 PM   #4963
Skerr
Not doing the serp belt. That would be cool, but I am keepig everything 258 that I can, because I have it already. Using the 258 water pump, I keep the 258 cooling system, and I have no need for an electric fan. At least... I think!
Kerrdog
Go Fish! <*////><
Unread 06-03-2013, 09:05 PM   #4964
Skerr
Ordered a pilot bushing from Novak today. $28!!! Yelp!@%#.
Still fussing with motor mounts, Crank Position Sensor, and water pump.
Will this thing EVER go into the Jeep?
Kerrdog
Go Fish! <*////><
Unread 06-04-2013, 07:40 PM   #4965
Skerr
Clay's eyeball at the ER the other day...
Kerrdog
Go Fish! <*////><
1979 , cj5 , fiberglass , rollcage , tailgate
