Clay's Build Thread - Page 320 - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Clay's Build Thread
FREE, FREE, FREE EVENT!! Save big on Lockers now till ApriJKS Grand Cherokee WJ, Adjustable Front Trackbar 1"-6Teraflex JK HD Hinged Carrier & Adjustable Spare Tire
Unread 03-30-2013, 09:10 PM   #4786
lucdog
lucdog's Avatar
1980 CJ5
http://www.bigrigchromeshop.com/Merc...UESBFS/UP10959
http://m.gandermountain.com/modperl/...g-Step&i=21111
Screen shot of the gander mountain step.
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7
1989 YJ the CJ to YJ.
lucdog is offline   Reply With Quote Quick reply to this message
Unread 03-30-2013, 09:29 PM   #4787
WNC-84CJ7
Figures they would be EZ to find! When I googled "Jeep step" you can imagine all I got was.....well Jeep sidesteps.
Thanks again Bill.
Chris
"No free man shall ever be debarred the use of arms. The strongest reason for the people to retain the right to keep and bear arms is, as a last resort, to protect themselves against tyranny in government"
-- Thomas Jefferson, 1 Thomas Jefferson Papers, 334
WNC-84CJ7 is offline   Reply With Quote Quick reply to this message
Unread 03-31-2013, 10:30 AM   #4788
lucdog
lucdog's Avatar
1980 CJ5
Here ya go Scotty. The center line of the step is 8.250" back from the center line of the lower door hinge ( the bolts)
The 1/4"x6" body armor drops below the tub to provide enough room for the 1/2"x2" clip to be welded on.
This is how I tied to the frame.
Front ^
Middle, on this one and the rear I welded a angle iron clip to the frame.
Where the steel meets the tub, around the bolt holes, I put a 3/8" bead of black RTV , and let it set up overnight. I then bolted them on.
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1983 CJ7
Unread 03-31-2013, 10:41 AM   #4789
gmakra
Bill dontya think a handicap ramp would be better for the ole geezer?
gmakra is offline   Reply With Quote Quick reply to this message
Unread 03-31-2013, 10:57 AM   #4790
lucdog
lucdog's Avatar
1980 CJ5
I do, but it's Easter, I'm trying to be nice today!
I put these on both sides, I don't use the one on my side, it was just to match the passenger side. ( Miss Vicki is even more vertical challenged than I).
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1983 CJ7
Unread 03-31-2013, 06:24 PM   #4791
Skerr
Thanks, Bill. It's much sleeker than the one I am making!
Geezer??
Kerrdog
Go Fish! <*////><
Skerr is offline   Reply With Quote Quick reply to this message
Unread 04-07-2013, 05:27 PM   #4792
Skerr
Hey Guys.... question, please.
I am investigating the wandering Clay still has in the front of his Jeep. After watching everything move this evening I notice the shackles torque sideways, back and forth. I don't remember seeing this before the steering box brace install. How much movement should there be at this point? The shackle bushings were new bushings that came with the RC 2.5" lift springs. FEW miles on them. Everything else was new at the same time as these bushings. Balljoints, TRE, are confirmed good. Steering shaft is good. The steering box, with new brace, still has a very brief amount of movement. Should it be zero? The shackles are 3/8" lift Performance something-or-other. Tie rod is new. New steering box. Etc, etc... My 7 is much tighter than Clay's 5, and they have identical front ends, literally! Same lift, bushings, shackles, etc., except the shackle bushings on my 7 are poly.
Kerrdog
Go Fish! <*////><
Unread 04-07-2013, 05:46 PM   #4793
MoC
I don't remember Scott, but have you checked the holes in the factory pump mount itself? They wallow out over time and no matter how tight you get them they will move.
MoC is offline   Reply With Quote Quick reply to this message
Unread 04-07-2013, 05:49 PM   #4794
Dadamsnv
1977 CJ5
Your caster is good right?
Cheers!
Dadamsnv is offline   Reply With Quote Quick reply to this message
Unread 04-07-2013, 07:53 PM   #4795
Skerr
No... I haven't checked those, but that makes sense. The bolts go through the mount easily enough.
No... castor is not good. Steering wheel does not return on its own. Forgot about that. Bill's gonna give me a hard time! Sorry in advance, Bill.
Is the side-to-side shackle movement normal?
Kerrdog
Go Fish! <*////><
Unread 04-07-2013, 07:55 PM   #4796
rixcj
rixcj's Avatar
1979 CJ5
I don't think that the steering gearbox should move at all. How can it move unless there's something whacky going on with the brace?
Does the entire gearbox and brace wiggle, or just where the pitman arm attaches?
I forget....do you have power steering?
Rich
'79 CJ5, AMC 360, t-18/d20 twin stick, dana 30/amc20(Mosers), Edelbrock Performer intake, Holley 600, ps/pb, DUI HEI, 'glass tub/1pc. tilt nose, 33x12.50 BFG AT's.
There's a fine line between "hobby" and "mental illness".
rixcj is offline   Reply With Quote Quick reply to this message
Unread 04-07-2013, 08:11 PM   #4797
Skerr
Rich
The entire gearbox moves, the whole unit, sideways, but not as in the bolts are sliding in the holes. More like the frame is bending, torquing kind of movement. The frame is not bending, however. I watched the top two frame holes (adjacent to the grill) in the crossmember, and I could see no flex at that point. The shackle mounting points are solid and not moving (Crabtree shackle hangers). The movement is very slight. Yes, power steering...
Kerrdog
Go Fish! <*////><
Unread 04-07-2013, 08:11 PM   #4798
lucdog
lucdog's Avatar
1980 CJ5
I do know the longer the shackles are the more the chance they will move.
So we have the proper info.
The shackles are moving when you turn the steering wheel.
And, the steering box is also moving, even with the addition of the brace.
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1983 CJ7
Unread 04-07-2013, 08:15 PM   #4799
Skerr
Yes, the shackles move side-to-side when the wheels turn. Keep in mind, the front of the Jeep is on the ground with the engine running, turning lock to lock. The bushings are "pinched" at the top shackle bolt, and the movement is very pronounced where the spring attaches to the shackle. I expect you would HAVE to have SOME movement, being a leverage point, but I was surprised how much is there.
See post above yours Bill for more info on gearbox.
Kerrdog
Go Fish! <*////><
Unread 04-07-2013, 08:38 PM   #4800
Dadamsnv
1977 CJ5
Didn't mean to get you in trouble
My shackles move side to side a good amount, but I don't really have wander, but my shackles are stock length.
Cheers!
1979 , cj5 , fiberglass , rollcage , tailgate
