Clay's Build Thread - Page 316 - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Clay's Build Thread
Tactical Recovery Equipment Soft Shackles!!!50% Off Sale at KrawlOff-Road.com50" LED CREE Light Bar Pair With Wiring Kit
Unread 01-17-2013, 04:53 PM   #4726
Bojon
1981 CJ5
Sounds to me like your rings are shot. As far as what you do about it, I have a lovely 258 you can buy . Depends on how much money you want to sink into the project. Using the 258 out of your 7 is basically free, but might give you problems in the future. If you did an engine swap you might as well rebuild whatever motor you drop in, and I would expect the conversion to be a bit more expensive then you plan. I think the easiest/cheapest route would be to rebuild the 258. I got all the parts and machining for around $700. If you took this route you could throw some rtv on the engine in the 5 to get the leak to stop, and rebuild the 258 in your 7. Then you wouldn't be down a vehicle.
[URL="http://www.jeepforum.com/forum/f8/1981-cj5-frame-up-1141648/"]My CJ5 Build[/URL]
Jered
Bojon is offline   Reply With Quote Quick reply to this message
Unread 01-17-2013, 05:32 PM   #4727
lucdog
lucdog's Avatar
1980 CJ5
You need the vehicle for Clay, I'd pull the engine from your 7, and put it in Clays 5. A weekend job.
Sounds like a lot of blow by, (normally blue smoke) Clays is white ( steam) from what you said. Any oil in the water or vice-versa?
Reasoning on your 258. Budget, minimal down time, your 7 isn't going to be a driver for a least 6 months or better.
Another idea , transfer the license to the XJ along with the insurance. I know it's Fallon's jeep, but you need three vehicles. This will give you some time for the swap.
Also a compression check on Clays 5, to see where your at.
The 4.3 swap requires, as you know , the bell housing,radiator, flywheel (unless the 4.3 comes from a S10 with a standard tranny), motor mounts ,a new manifold if carbureted, or figuring out the wiring ,with Fuel injection, along with a $100 fuel pump. The 5 speed would be nice, however, you might not be able to adapt the Dana 20 to it, or finding a Dana 300 and then the adapter ($500. )The 5 speed tranny and the TC that would come with it would need a slip yoke eliminator ($350.) And the driveshaft would still be really short.
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7
1989 YJ the CJ to YJ.
lucdog is offline   Reply With Quote Quick reply to this message
Unread 01-17-2013, 06:14 PM   #4728
8pitcher
I got a 258 you can take off my hands only thing is youd have to come up here to get it. Its in pieces. You know you could fly back up here on Sunday with my mom and my sis
[URL="http://groups.jeepforum.com/built-not-bought/"][COLOR="Black"]Built Not Bought #640[/COLOR][/URL][/FONT][/SIZE][/COLOR][/CENTER][/COLOR]
8pitcher is online now   Reply With Quote Quick reply to this message
Unread 01-17-2013, 06:14 PM   #4729
8pitcher
Originally Posted by Skerr
For whatever reasons I have always wanted to put a 4.3 in a CJ. I have plans to do that to my 7. I got to thinking I would do that on Clay's 5 as well. My local JY quoted me $250 for a running 4.3 and $250 for a 4X4 5-speed tranny. I'm pretty sure the 5-speed won't fit a 5 (although I will research it), and worst case scenario I bolt one up to the T18. Which means an adaptor, which is, what... another $500?? MoC suggests installing a 4.0 from a JY Cherokee, but he also suggests pulling my 258 out of my 7 and installing it into Clay's Jeep. That would be the simplest thing to do. Then I could put the 4.3 in my 7 as planned. If I go that route then I'll do a complete rebuild on the 7 (which I WASN'T planning to do now). I have a lot to think about.
Choices, choices...
I degreased Clay's 5 earlier today with Purple Power. Sprayed it all over the place with my pump-up sprayer. Broke out the pressure washer only to find, after 18 years of faithful service, it has retired. So washed everything off with a nozzle and the garden hose. Not squeaky clean, but not dripping oil anymore. Started it up and ran it for 30 minutes. I have oil dripping from the front of the pan, and coming out of the dip stick tube. The pan leak is coming from between the pan and gasket. No idea WHY it's coming out of the tube! Pulled the PCV out the whole time it ran, venting into the atmosphere, so no pressure built up.
The front of the pan has a stripped bolt by the PO. Clay and I tapped it out to a larger size and tightened it down as far as we dare. That is where the leak appears to be.
After removing the PCV from the valve cover I have a TON of blowby. White smoke comes out of the hole in quantity. No smoke out the tailpipe that I can see, however.
WhatdoIdo?WhatdoIdo?WhatdoIdo?
Have Jim mill out an adapter I'm sure he could do it. Haha
Unread 01-17-2013, 07:52 PM   #4730
WNC-84CJ7
Sorry Scott. I have nothing to offer but a sympathetic ear, some useless moral support, no automotive knowledge whatsoever.
"No free man shall ever be debarred the use of arms. The strongest reason for the people to retain the right to keep and bear arms is, as a last resort, to protect themselves against tyranny in government"
-- Thomas Jefferson, 1 Thomas Jefferson Papers, 334
WNC-84CJ7 is offline   Reply With Quote Quick reply to this message
Unread 01-17-2013, 08:37 PM   #4731
lucdog
lucdog's Avatar
1980 CJ5
Originally Posted by WNC-84CJ7
Sorry Scott. I have nothing to offer but a sympathetic ear, some useless moral support, .
Sometimes that's all it takes.
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1983 CJ7
Unread 01-17-2013, 11:39 PM   #4732
mvigo
mvigo's Avatar
Was it over when the Germans bombed Pearl Harbor? Nooooooo!!! Git 'er done Scott, you know you can, I know you can and so does the rest of this forum. Now, the good news for us? This thread is active again!
1985 CJ-7, fuel injected 258, 2.5" Rubicon Express Extreme Duty Lift, 1" Body lift, Crabtree Shackle Hangers, T-5, Dana 300 w/ 4:1 Teralow kit, Dana 30, AMC 20 w/1 piece axle, 3.73 's with Detroit Truetrac front and rear, riding on 32x11.5x15" Cooper Discoverer STT mud terrains
mvigo is offline   Reply With Quote Quick reply to this message
Unread 01-18-2013, 06:57 AM   #4733
lucdog
lucdog's Avatar
1980 CJ5
:-) , Japan?
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1983 CJ7
Unread 01-18-2013, 07:42 AM   #4734
WNC-84CJ7
I was letting that one go, hoping he was joking!
Unread 01-18-2013, 07:55 AM   #4735
VACJ7
Hockey Rules!
VACJ7's Avatar
Originally Posted by lucdog View Post
:-) , Japan?
Bill
He was doing a line from the movie Animal House.
'84 CJ-7 | REBUILD IN PROGRESS
VACJ7 is offline   Reply With Quote Quick reply to this message
Unread 01-18-2013, 07:56 AM   #4736
mvigo
mvigo's Avatar
:-) , Japan?
Bill
Ahhh, come on guys! that is a movie line! Somebody out there knows what I am talking about!?!?! give me the answer!
Probably one of the greatest motivational speeches in all of cinema!!!!
Unread 01-18-2013, 07:58 AM   #4737
mvigo
mvigo's Avatar
DING, DING! Thank goodness Paul!
A classic!
there might be an ad but you will see Bluto in the 1st 30 seconds or so...
Unread 01-18-2013, 07:58 AM   #4738
lucdog
lucdog's Avatar
1980 CJ5
Thanks Paul , I've only seen bits a pieces of that movie.
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1983 CJ7
Unread 01-18-2013, 07:59 AM   #4739
VACJ7
Hockey Rules!
VACJ7's Avatar
Unread 01-18-2013, 08:07 AM   #4740
lucdog
lucdog's Avatar
1980 CJ5
Thanks Paul,
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1983 CJ7
1979 , cj5 , fiberglass , rollcage , tailgate
