Clay's Build Thread - Page 315 - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Clay's Build Thread
Ruffstuff 10 year saleBDS 4-1/2" Suspension Lift Kit - Jeep Wrangler YJRough Country Lift Kits and Parts!
Unread 12-31-2012, 08:12 PM   #4711
Dadamsnv
1977 CJ5
I got mine at the local sewing/fabric store. A craft store may have it.
Cheers!
Dadamsnv is offline   Reply With Quote Quick reply to this message
Unread 01-16-2013, 05:48 PM   #4712
Skerr
We are dealing with substantial leakage! NOW, I wish I HAD gone through the engine. I'm not sure, but I still believe it is leaking around the oil pan. If you remember, I had pulled it off to replace the RMS. Then, our mechanic pulled it off to install a new gasket, because that's where HE thought it was leaking. So its had TWO new 1-pc gaskets since we put it on the road. I don't think it ever got the RTV, though. The RMS does NOT seem to be leaking, and it's definitey NOT the valve cover (also new gasket and carefully sealed). Also, the steering gear box is leaking around the pittman arm shaft. That ain't good.
Clay told me last night that it suddenly began dumping oil. He went through a quart alone yesterday. I pulled it into the shop at 12:30, and by 3:30 I had pools on the concrete!! The bottom of the Jeep is virtually covered in oil. I can't describe the sense of disappointment I have after so much labor to make this Jeep nice. Ready to put it out of its misery
Kerrdog
Go Fish! <*////><
Skerr is offline   Reply With Quote Quick reply to this message
Unread 01-16-2013, 07:04 PM   #4713
Jim1611
Jim1611's Avatar
PCV valve working okay?
www.crabtreetool.com (Crabtree Shackle Hangers)
My build thread
http://www.jeepforum.com/forum/f8/ji...build-1093702/
Jim1611 is offline   Reply With Quote Quick reply to this message
Unread 01-16-2013, 07:09 PM   #4714
Bojon
1981 CJ5
Sorry to hear about your troubles. If I'm correct you gutted out the PCV valve right? I had an interesting read a few nights ago, and it stated that the purpose of the PCV valve is to close off when there is too much vacuum, so you don't create a vacuum in the crank case, which can be bad for seals. Probably not pertinent, just found it interesting.
[URL="http://www.jeepforum.com/forum/f8/1981-cj5-frame-up-1141648/"]My CJ5 Build[/URL]
Jered
Bojon is offline   Reply With Quote Quick reply to this message
Unread 01-16-2013, 07:15 PM   #4715
gmakra
Skipper the gasket you used was a Felpro? I like the Victor Reniz gasket since it has wide flanges that fit over the oil pan on the front and back and can not squish out which is probably what happened to you. You can get Victor Reniz from Car Quest BTW Victor Reniz is a Dana Corp sothier stuff is good.
gmakra is online now   Reply With Quote Quick reply to this message
Unread 01-16-2013, 07:36 PM   #4716
MrBeast
1980 CJ7
I am going to go with your crank seal on the timing cover is suspect, oil will leak out of it, and get blown back by the fan.
My suggestion is yank the balancer and the timing cover, drop a new timing chain and crank seal, it will mean doing the pan again, but it will make it right.
[I]"He used to be a pretty nice feller, now he's a welder"[/I]
[URL="http://www.jeepforum.com/forum/f22/1980-cj7-first-jeep-build-1243620/"]80 CJ7 "The Kraken" - a project 25 years in the making[/URL] AMC 304 V8, NV4500, Dana 300, Dana 44, 9 inch, M.O.R.E. SRS, YJ tub.
AT3 US Navy 1999-2003
[B][SIZE="3"] Cum catapultae proscriptae erunt tum soli proscript catapultas habebunt[/SIZE][/B]
[SIZE="1"](When catapults are outlawed, only outlaws will have catapults)[/SIZE]
MrBeast is offline   Reply With Quote Quick reply to this message
Unread 01-17-2013, 11:15 AM   #4717
MoC
Chin up high Scott. Yall did a top notch job on this Jeep and still should be VERY proud of what you did. Even more important are the memories and knowledge you shared with Clay on this.
This is just another one of those things to get though. Clean it up and find the leak. I know you can!
MoC is offline   Reply With Quote Quick reply to this message
Unread 01-17-2013, 11:42 AM   #4718
MrBeast
1980 CJ7
Yes simple green is your friend!
Unread 01-17-2013, 02:20 PM   #4719
Skerr
Well... no. It ain't got one! Not really. It is hollow. I took it apart and gutted it.
You are correct. Now it is simply acting as a crankcase vent.
Yep. Felpro... the blue 1-pc. I will look for the Victor gasket. No Carquests around here though.
This is very suspect as it has been leaking from the front of the pan since installing the gasket the first time, hence the reason I took it into a shop after finishing the build. Probably going here!
Give me a hug! You know just what to say!!
In stock!!
Thanks Guys.
BTW- I was notified by one of you about some kind of Malware attached to my post about the oil leaking. I hope there is nothing there, but apparently something WAS attached to it. It was sent to Admin for clean up, which they did, and I don't understand it, so beware. For piece of mind, I'M not doing it!!
Kerrdog
Go Fish! <*////><
Unread 01-17-2013, 04:25 PM   #4720
Dadamsnv
1977 CJ5
If you are leaking oil as the jeeps sits with the motor off, wouldn't that mean it would have to be your drain plug or a pinhole in the pan?? After all, that's where all the oil is when it's off.
Or is the puddle happening while its running?
Cheers!
Unread 01-17-2013, 04:30 PM   #4721
MrBeast
1980 CJ7
Not necessarily oil will build up on things then drip down.
Unread 01-17-2013, 04:35 PM   #4722
FLynes
FLynes's Avatar
1976 CJ5
Don't give up now buddy you've come way too far!
Fred
Retired Army Guy
High Plains Drifter
1976 CJ-5
Lime Green
Black Wellington Vinyl Bench Seats
258 I-6 1bbl
T-150 3-Speed
3.54:1 Open Gears
Grammar Test
FLynes is offline   Reply With Quote Quick reply to this message
Unread 01-17-2013, 05:04 PM   #4723
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
It looks like a father and son engine build may be brewing.....
Good luck, Scott, the challenges make the rewards even sweeter.
Matt
Matt1981CJ7 is offline   Reply With Quote Quick reply to this message
Unread 01-17-2013, 05:31 PM   #4724
243
1978 FSJ Cherokee
So drink a beer and throw the bottle caps into the neighbor's yard! My personal favorites are poached cats and shrimp heads, but that's not for everybody. Get some life going, Dude. I just learned tonight I need a new vacuum cleaner, and we wants a ride-on!
243 is offline   Reply With Quote Quick reply to this message
Unread 01-17-2013, 05:45 PM   #4725
Skerr
For whatever reasons I have always wanted to put a 4.3 in a CJ. I have plans to do that to my 7. I got to thinking I would do that on Clay's 5 as well. My local JY quoted me $250 for a running 4.3 and $250 for a 4X4 5-speed tranny. I'm pretty sure the 5-speed won't fit a 5 (although I will research it), and worst case scenario I bolt one up to the T18. Which means an adaptor, which is, what... another $500?? MoC suggests installing a 4.0 from a JY Cherokee, but he also suggests pulling my 258 out of my 7 and installing it into Clay's Jeep. That would be the simplest thing to do. Then I could put the 4.3 in my 7 as planned. If I go that route then I'll do a complete rebuild on the 7 (which I WASN'T planning to do now). I have a lot to think about.
Choices, choices...
I degreased Clay's 5 earlier today with Purple Power. Sprayed it all over the place with my pump-up sprayer. Broke out the pressure washer only to find, after 18 years of faithful service, it has retired. So washed everything off with a nozzle and the garden hose. Not squeaky clean, but not dripping oil anymore. Started it up and ran it for 30 minutes. I have oil dripping from the front of the pan, and coming out of the dip stick tube. The pan leak is coming from between the pan and gasket. No idea WHY it's coming out of the tube! Pulled the PCV out the whole time it ran, venting into the atmosphere, so no pressure built up.
The front of the pan has a stripped bolt by the PO. Clay and I tapped it out to a larger size and tightened it down as far as we dare. That is where the leak appears to be.
After removing the PCV from the valve cover I have a TON of blowby. White smoke comes out of the hole in quantity. No smoke out the tailpipe that I can see, however.
WhatdoIdo?WhatdoIdo?WhatdoIdo?
Kerrdog
Go Fish! <*////><
1979 , cj5 , fiberglass , rollcage , tailgate
