Clay's Build Thread - Page 311 - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Clay's Build Thread
BDS 4-1/2" Suspension Lift Kit - Jeep Wrangler YJRough Country Lift Kits and Parts!FREE, FREE, FREE EVENT!! Save big on Lockers now till Apri
Unread 11-18-2012, 08:31 PM   #4651
Skerr
Real men go to the river!
Big day today. Baptism for my 13 YO. The water is COLD!! And some fun pics of Clay "wheeling"! Notice the mighty flex and the incredible hill climb!!
Kerrdog
Go Fish! <*////><
Skerr is offline   Reply With Quote Quick reply to this message
Unread 11-18-2012, 08:42 PM   #4652
lucdog
lucdog's Avatar
1980 CJ5
Congrats to Fallon. We need to find Clayton se bigger hills!
And here, just for you is a river song
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7
1989 YJ the CJ to YJ.
lucdog is offline   Reply With Quote Quick reply to this message
Unread 11-21-2012, 10:50 AM   #4653
Skerr
Clay's Jeep is leaking... a lot! I am keeping an eye in the oil level, but it doesn't seem to be going down. I know the oil leak is engine oil, and I believe it is coming from the pan gasket. I installed one, and I had a shop install another, but still it leaks. It seems to be coming from the front of the pan. Is there some kind of union between the timing cover and the oil pan? I did not remove the timing cover when we did this build. I can hear the timing chain inside when it is running, and I assume the engine would benefit from replacing it, but I didn't want to get into engine work if I didn't HAVE to. If I go through that hassle of changing gears/chain, can I expect to fix this leak?
Also have a rear axle seal leaking, so I have that to do too.
Kerrdog
Go Fish! <*////><
Unread 11-21-2012, 05:22 PM   #4654
Skerr
Will a shifter boot for a T150, T14, T15 fit a T18?
Kerrdog
Go Fish! <*////><
Unread 11-21-2012, 05:37 PM   #4655
gmakra
Skipper if you do replace the timing chain replace the pan gasket with a Victor Rienz one piece pan gasket its much better than a Felpro. I never had one leak Car Quest sell Victor Rienz and I would replace the timing chain at the same time cheap insurance.
gmakra is offline   Reply With Quote Quick reply to this message
Unread 11-21-2012, 05:58 PM   #4656
Dadamsnv
1977 CJ5
Yup. I bought mine from quadratec and it was labled for a t150 I believe.
Cheers!
Dadamsnv is offline   Reply With Quote Quick reply to this message
Unread 11-21-2012, 07:25 PM   #4657
Turtle71
1983 CJ7
Not sure if this is the problem with the leak, but I remember reading about someone else having the same issue after replacing their oil pan gasket. I believe it was MoC but not sure. Anyway, all they did was check and tighten some of the oil pan bolts. Doesnt take much though.
My 83 CJ7 Build:[url]http://www.jeepforum.com/forum/f8/turtle71s-83-cj7-project-1136836/[/url]
Turtle71 is offline   Reply With Quote Quick reply to this message
Unread 11-21-2012, 07:40 PM   #4658
Skerr
Using a one piece gasket, but not the one George recommends. I have tightened the bolts twice, and no difference. I am wondering if I have a small hole in the pan. There is a pretty good ding there where the PO hit something.
Kerrdog
Go Fish! <*////><
Unread 11-21-2012, 08:14 PM   #4659
VACJ7
Hockey Rules!
VACJ7's Avatar
Scott, I used a felpro one-piece and have zero leaks. The one thing that comes to mind is they should have put a small dab or RTV where the pan gasket goes from the flat to curved surfaces. Four places total. Two front where it meets the timing cover and two rear where it meets the rear crank bearing. You should be able to see if they did this because it will squeeze out some when you torque the pan.
'84 CJ-7 | REBUILD IN PROGRESS
VACJ7 is offline   Reply With Quote Quick reply to this message
Unread 11-21-2012, 08:22 PM   #4660
8pitcher
8pitcher's Avatar
On mine I used non hardening gasket sealer between my felpro multi piece gasket and it doesn't leak. But then again I haven't gotten my engine on the frame yet.
Built Not Bought #640
8pitcher is offline   Reply With Quote Quick reply to this message
Unread 11-21-2012, 08:26 PM   #4661
Dadamsnv
1977 CJ5
I used an 1/8" bead of RTV on both the pan and block along with a 4 piece gasket. No leaks. haha no kill like overkill
Cheers!
Unread 11-21-2012, 11:01 PM   #4662
8pitcher
8pitcher's Avatar
Haha exactly.
Unread 11-22-2012, 09:11 AM   #4663
rixcj
rixcj's Avatar
1979 CJ5
I've found that if you put silicone on both sides of a gasket, it can cause the gasket to "blouse out", or slide out sideways , in certain spots, when tightening down the bolts..
An engine builder friend of mine told me to either just use silicone, The Right One, etc. (no gasket), or just a gasket...not both.
So now, I used Permatex Hi Tack on the block, and the block side of the gasket, just to glue the gasket to the block. Then I bolt the oil pan to the bottom side of the gasket. It doesn't "blouse out" this way.
Putting the sealant at the corners IS necessary, though.
'79 CJ5, AMC 360, t-18/d20 twin stick, dana 30/amc20(Mosers), Edelbrock Performer intake, Holley 600, ps/pb, DUI HEI, 'glass tub/1pc. tilt nose, 33x12.50 BFG AT's.
There's a fine line between "hobby" and "mental illness".
rixcj is offline   Reply With Quote Quick reply to this message
Unread 11-22-2012, 09:24 AM   #4664
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
Scott,
I'd get busy with some degreaser and power-washer, and get the under-side squeaky clean. That way you'll be able to isolate the leak, easily, after a short drive.
I'd hate to see you chase the wrong problem.
If I had to guess, I'd agree with VACJ7, the 4 corners of the oil pan probably didn't get RTV'd as they should.
Matt
Matt1981CJ7 is offline   Reply With Quote Quick reply to this message
Unread 11-22-2012, 10:56 AM   #4665
Dadamsnv
1977 CJ5
I had a couple "blouse outs" that broke the gasket. But it still sealed because of all the sealer. I felt like a meathead the whole time I was doing the pan. Next time ill be less sloppy. It's only by gods grace that it sealed so well
Cheers!
1979 , cj5 , fiberglass , rollcage , tailgate
