Clay's Build Thread - Page 282 - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Clay's Build Thread
Only 2 Days left to win $3,800 Jeep Parts!Count Down to KOH Sale!Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 09-17-2012, 05:30 PM   #4216
MoC
Jeep looks GREAT Scott.
I am curious about the paint. I remember a page or so ago you said it was scratching really easy and not the dust thing. Any ideas whats going on with that. Maybe a hardener issue?
MoC is offline   Reply With Quote Quick reply to this message
Unread 09-17-2012, 05:32 PM   #4217
TJ-Joe
Originally Posted by Skerr View Post
... If I had a vehicle today I would borrow a trailer and get it into the alignment shop.
Save the money and align it yourself - you and Clay could do it in an hour! All it takes is a couple of 4' boards, a couple of bungees, and a tape measure. Jack up the front end until the tires clear the ground (best to use jack stands for safety). Strap the boards horizontally to the front tires with the bungees, so some sticks out to the front and some to the rear. Use the tape to measure the distance between the boards just in front of and just behind of the tires. The front should be 1/8" narrower than the rear (toe in). Loosen the clamp bolts on the tie rod and then use a pipe wrench to rotate the tie rod to lengthen or shorten it until the toe in is correct, then tighten the clamp bolts back down (use a rag between the pipe wrench's teeth and the tie rod to protect the paint). You can then lengthen or shorten the drag link to get the steering wheel straightened.
TJ-Joe is offline   Reply With Quote Quick reply to this message
Unread 09-17-2012, 07:18 PM   #4218
Skerr
Skerr's Avatar
Originally Posted by 8pitcher View Post
Can't wait to see that tire carrier finished I need some more ideas.
Clay ran into a roadblock this evening. He needs a 1 3/4" metal hole saw, and he was headed to Lowes to get one, but he has a Trig test Wednesday, so Mom put the kibash on the trip. It will have to wait until after Wednesday.
I'm thinking hardener too. Although I followed the directions on the label, it is not hard. If you remember, I had the same issue with the frame paint. Could be me. Could be humidity. Could be both??
Thanks, Joe. That's clear as a bell. Here is what I discovered...
Tightened everything down in the front end related to steering. I found I had not torqued the ball joints. I can't get to the lowers, but the uppers are torqued properly. I had three or four good pulls before they reached torque, so I have to assume I left the lowers the same... just sort of tight. I now have the tires aligned as best as I can get them. I took it down the road. The steering felt so much better just heading out of the driveway. I got up to 30 MPH on the hardtop, and it would suddenly dive to the side, left or right. Not vaguely wander, or ease off to one side, but suddenly try to shoot across the road! Wow! Drew my nuts completely inside my body cavity!! Turned around, stayed at 20 MPH, and pulled back into the shop. Got Clay to turn the wheel while I watched up front and discovered the whole steering box is moving significantly. Which is very bizarre, considering I torqued it down using new grade 8 bolts. I found one bolt completely missing... so maybe I missed it, and the related captured nut is not present in the frame. Great. I guess a brace is in order. Is the diving issue related to the steering box, ball joints, or a combo? Also, the Jeep has a defined "limp" while going down the road. Maybe a bent rim, out of balance, etc. Gotta get the new rims on.
Kerrdog
Go Fish! <*////><
Skerr is offline   Reply With Quote Quick reply to this message
Unread 09-17-2012, 07:19 PM   #4219
Skerr
Skerr's Avatar
But it was SO FRIGGIN' COOL going down the road with the lights on!
Kerrdog
Go Fish! <*////><
Unread 09-17-2012, 08:02 PM   #4220
Turtle71
1983 CJ7
I looks great!!! The new wheels and tires will be icing on the cake.
My slow 83 CJ7 Build:[url]http://www.jeepforum.com/forum/f8/turtle71s-83-cj7-project-1136836/[/url]
Turtle71 is offline   Reply With Quote Quick reply to this message
Unread 09-17-2012, 08:11 PM   #4221
FLynes
FLynes's Avatar
1976 CJ5
I hate that nuts-in-the-body-cavity feeling...I used to get it, every time I jumped out of a helicopter. It is a helluva rush though, I gotta admit.
I envy you guys....mine is still in a million pieces.
Fred
Retired Army Guy
High Plains Drifter
1976 CJ-5
Lime Green
Black Wellington Vinyl Bench Seats
258 I-6 1bbl
T-150 3-Speed
3.54:1 Open Gears
Grammar Test
FLynes is offline   Reply With Quote Quick reply to this message
Unread 09-17-2012, 08:21 PM   #4222
lucdog
lucdog's Avatar
1980 CJ5
Ok Scottie, 2 choices.
1. Turn the wheels to the outside , see of you can tighten the lowers with a open end wrench.
2. The preferred method, take everything apart , caliper, hub and rotor,and spindle, pull the axle shaft. And torque the nut (s).
Steering braces are around $60 . Clay could make 1, I'm making one for myself . Tomorrow. For about free.
This is what I'm starting with.
The last 2 pictures are A store bought one.
If you have the 2.250" ID tube it would take a couple hours.
Bill
1957 WILLYS pickup, needs work.
1973 J 4000,
1978 CJ7 DD.
1979 CJ7 360, TH400/Quadratrac trail Jeep.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7 pretty weekend and sometimes to work Driver in the summer, My first rebuild, if the Q-trac and 5 are broke, this one is the one to take. its just as capable as the other 2, except nice paint.
1984 Grand Wagoneer, 1 ton axles, great 360/727, and a big a$& tree fell on it .
1989 YJ the CJ to YJ conversion.
2005 TJ Rubicon.
2011 Grand Cherokee Laredo 4x4, Mrs. LUCDOG's DD.
Lots of parts not for sale, i'm a hoarder.
lucdog is offline   Reply With Quote Quick reply to this message
Unread 09-17-2012, 08:50 PM   #4223
VACJ7
Hockey Rules!
VACJ7's Avatar
I dunno Scott.... if Clay is gonna take it on the highway I think i would take a few steps back and tear it down and check the torque on all front end components.
'84 CJ-7 | REBUILD IN PROGRESS
VACJ7 is offline   Reply With Quote Quick reply to this message
Unread 09-17-2012, 09:07 PM   #4224
lucdog
lucdog's Avatar
1980 CJ5
Did you torque the sleeve ( the proper name escapes me) under the top nut to the proper torque?
I think you need to check every bolt pertaining to steering, stopping, suspension, and driveline before driving.
My $.02
Bill
1973 J 4000,
1978 CJ7 DD.
1979 J20
2005 TJ Rubicon.
Unread 09-18-2012, 12:09 AM   #4225
Skerr
Skerr's Avatar
Thanks Turtle. I'm looking forward to the icing!
You'll get there Grasshopper... patience! We all have to have something to do when we finish, so we'll be watching yours.
Attachment 474308
Attachment 474311
Attachment 474313
Bill
2 1/4" ID tubing?? That's hefty! I was thinking 1" EMT??
My $.02
Bill
Yeah, yeah... I know.
Kerrdog
Go Fish! <*////><
Unread 09-18-2012, 12:11 AM   #4226
TJ-Joe
Could be a number of things, but my bet is alignment. If this happened when driving straight on a smooth surface, It's most likely improper toe in - if the front is wider than the back, it will get awful squirrelly, especially as you speed up - try aligning it as I described.
The steering box flexing on the frame could make it worse - you definitely need to have all all the bolts attached - if not, it could easily tear off the frame (ask me how I know, LOL). Personally, before I made a brace, I'd buy a M.O.R.E. heavy duty steering box mount, or have Clay weld up one like it.
As for the ball joints, jack it up, grab the tire on top and bottom and try to tilt it up and down - if it moves, the ball joints are shot or loose. Even it they don't move, I'd follow Bill's advice to torque the lowers. I'd also torque and lube everything on the front end, including the spring u-bolts.
Unread 09-18-2012, 12:45 AM   #4227
Skerr
Skerr's Avatar
Thanks, Joe. Looks like that will be tomorrow's project.
Does anybody have a pic of the their steering box mount installed. I'm talking about the heavy duty aftermarket mounts. If so, would you post up a pic?
Kerrdog
Go Fish! <*////><
Unread 09-18-2012, 06:06 AM   #4228
lucdog
lucdog's Avatar
1980 CJ5
The heavy duty steering box mount goes on exactly like the factory mount , with the exception of 1 extra bolt that goes in the frame cross member . 1 hole needs to be drilled, approx. between the 2 existing bolts.
The 2.250" tube is the part that goes around the steering box on The round part just above the pitman arm. That's the 2 pieces of 1/2 tube in my picture. 4 tabs will be welded to the 1/2 tube for the bolts.
I wonder if Jim has a pattern for the mount, he was thinking of making them.
Bill
1973 J 4000,
1978 CJ7 DD.
1979 J20
2005 TJ Rubicon.
Unread 09-18-2012, 06:54 AM   #4229
lucdog
lucdog's Avatar
1980 CJ5
This is my mount on my 5.
And a better picture of the brace that goes on the box.
Haha, good morning sunshine. Get busy, you have a boat load of stuff to do today.
On edit, that's good about the breast. .
Bill
1973 J 4000,
1978 CJ7 DD.
1979 J20
2005 TJ Rubicon.
Unread 09-18-2012, 07:09 AM   #4230
8pitcher
Bill
Do you have manual or power steering? Or does it matter for the brace?
[URL="http://groups.jeepforum.com/built-not-bought/"][COLOR="Black"]Built Not Bought #640[/COLOR][/URL][/FONT][/SIZE][/COLOR][/CENTER][/COLOR]
8pitcher is offline   Reply With Quote Quick reply to this message
1979 , cj5 , fiberglass , rollcage , tailgate
