Clay's Build Thread - Page 272 - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Clay's Build Thread
The Original 3/8" Ruffstuff Diff Cover!Ruffstuff Axle Simple Swap Kit!The Ruffstuff NOT Universal 4 Link Kit!
Unread 08-29-2012, 04:54 PM   #4066
Dadamsnv
1977 CJ5
didja ever get a vac gauge?? how many turns out are your idle screws??
Cheers!
Dadamsnv is online now   Reply With Quote Quick reply to this message
Unread 08-29-2012, 05:32 PM   #4067
Skerr
Nope- completely forgot about that. I will do it (if you remind me!), but it will have to wait a couple of weeks. Mix screws are out 3 turns each.
Kerrdog
Go Fish! <*////><
Skerr is offline   Reply With Quote Quick reply to this message
Unread 08-29-2012, 05:36 PM   #4068
243
1978 FSJ Cherokee
Originally Posted by Skerr View Post
If you only knew how bad I need a couple of Shiners, and I ain't talking about the butt-whipping kind! We probably wouldn't get much done. Probably end up fishing!!
Yo iz wun krazee ol gote!!!!!!!!
Duuuuude!!!!
You could bush hog my neighbor while you are here, just for fun even though she probably needs it being the liberalhippytreehuggingvegetarian type, hell, I will man the video camera and get ya a keg o' Shiner when you finish
1978 Cherokee, 360/T400/QT...5.3/4L60E/NP241C in the works...
243 is offline   Reply With Quote Quick reply to this message
Unread 08-29-2012, 06:57 PM   #4069
Dadamsnv
1977 CJ5
Originally Posted by 243 View Post
Duuuuude!!!!
Cheers!
Unread 08-29-2012, 07:11 PM   #4070
spward
spward's Avatar
You should have told Clay that power steering is for little girls and deal with manual. See, problem solved with tough love.
Scott
USN Hull #227
spward is offline   Reply With Quote Quick reply to this message
Unread 08-30-2012, 01:41 PM   #4071
Skerr
Armstrong Steering! Yep. Had to deal with that in my day!
Kerrdog
Go Fish! <*////><
Unread 08-30-2012, 01:44 PM   #4072
Dadamsnv
1977 CJ5
skerr is alive!
Cheers!
Unread 08-30-2012, 01:47 PM   #4073
Skerr
Feeling pretty BIG today, and I had to post this up.
Just for kicks and giggles, I fabbed up a bracket for the throttle cable. Now we're running off the gas pedal, which makes it MORE like a Jeep! I putzed around in 1st and 2nd gear in the yard. I proved to myself that a T18 does NOT have a synchroed 1st gear! I had no troubles starting in 2nd gear with 3.54 and 33" tires. I wanted to go fast! But I don't have everything "tight" yet. It was killer.
Heading out to start on windshield install.
Kerrdog
Go Fish! <*////><
Unread 08-30-2012, 02:22 PM   #4074
Skerr
Ho Ho Ho... Brown Truck Santa delivered Green Box Goodies. I can't believe you guys didn't even ask "What's in the box?" Ya'll are just mindless zombies! I have to bring it to you!
And LOOK! Hashbrown made the cover of 4Wheel magazine!
Kerrdog
Go Fish! <*////><
Unread 08-30-2012, 02:42 PM   #4075
Dadamsnv
1977 CJ5
BrAiNsSsSsS.... uh I mean... Look at all that cool stuff you got!
Cheers!
Unread 08-30-2012, 02:43 PM   #4076
Jim1611
Jim1611's Avatar
You got them seats installed yet? Gas pedal is fixed and no seats makes for a bad ride. Seat belt too. Hurry up and leave that neighbor alone. I saw where he posted somewhere that he could whip you any day of the week with both hands tied behind his back. You better get to Montana before he starts.
www.crabtreetool.com (Crabtree Shackle Hangers)
My build thread
http://www.jeepforum.com/forum/f8/ji...build-1093702/
Jim1611 is offline   Reply With Quote Quick reply to this message
Unread 08-30-2012, 04:23 PM   #4077
Skerr
That's an azz-whipping I would just have to take!!
Started on final windshield install, and I discovered I gots issues! This is going to be significantly difficult as it is warped beyond any time dimension Rod Serling ever imagined! I might have to drive it fast under a low-hanging limb. Should clear it right up.
So I started working on bleeding the brakes. Got the two "little-bits" out there to help me. One adding brake fluid, one pumping brakes, me under the rig. With brake fluid dripping on my forehead! Got a bad connection with new lines! Had it apart a couple times to "check it out", but no go. This is the rubber line that screws to the rear axle. It divides to both sides. It is leaking where it attaches to the hard line up under the gas tank. No joy in Mudville!
Wish I had a couple of Shiners.
So I loaded up the two squirts and hauled their little butts around the yard. Got it up to third gear! YEE-HAW!! RODEO, BABY!!!!!!!!
Seats is last Jimbo. Don't wanna half to crawl over them to finish stuff up. And by the way we have scratched this thing up, we would probably make them dirty as a peanut harvester!
Think I'll go wander aimlessly around the yard for awhile...
Kerrdog
Go Fish! <*////><
Unread 08-30-2012, 04:37 PM   #4078
Jim1611
Jim1611's Avatar
You don't sound like you're in too good a mood. Windshield is warped huh. How so?
My build thread
Unread 08-30-2012, 05:38 PM   #4079
lucdog
lucdog's Avatar
1980 CJ5
I went back and looked at the picture of Clay driving the Jeep. It looks like the windshield is to low on the drivers side. Is there any adjustment on the body portion where you can move it up?
Take a straight edge and lay it across the glass, top corner to bottom corner. see if its flat. CJ frames are flimsy, it shouldn't be difficult to tweak it a bit. I wouldn't do with the glass in.
Pictures? brake line also.
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7
1989 YJ the CJ to YJ.
lucdog is offline   Reply With Quote Quick reply to this message
Unread 08-30-2012, 05:45 PM   #4080
Skerr
Probably because of all the NOOBIE welding we had to do on it! We didn't no nuthin when we started this project. AJ straightened it as well as he could! I will mount the soft top and figure where the WS is supposed to be. SOMEHOW, we'll attach the top of it to the A pillar. That will pull it in. But it likely won't be easy to fold down, if he ever wants to...
I ain't in a bad mood, just apathetic!!
AJ taking most of the warp out of it.
Kerrdog
Go Fish! <*////><
1979 , cj5 , fiberglass , rollcage , tailgate
