Clay's Build Thread - Page 26 - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Clay's Build Thread
New! JK/U skid plate system.FS: Wrangler RGB Multicolor Fog Light LEDs: Awesome EffectIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 09-25-2010, 07:34 PM   #376
Skerr
Originally Posted by TehWicked View Post
I didnt read the whole thread very well...Just curious where you got the axles with disc brakes cause I missed it.
It orginally came with front disc but on NT axles. I swapped them for WT axles. Still stock diffs, just WT.
Kerrdog
Go Fish! <*////><
Skerr is offline   Reply With Quote Quick reply to this message
Unread 09-25-2010, 07:52 PM   #377
243
1978 FSJ Cherokee
The tank looks great, what repairs to you need to make on the body?
Are you going to post pictures?
1978 Cherokee, 360/T400/QT...5.3/4L60E/NP241C in the works...
243 is offline   Reply With Quote Quick reply to this message
Unread 09-26-2010, 06:22 AM   #378
Skerr
Nothing real bad on the body... it's FG. Just some holes and ugly spots to clean up. No cracks, chips, dents, cuts or bruises! Should be straight forward.
Kerrdog
Go Fish! <*////><
Unread 09-26-2010, 06:44 AM   #379
Skerr
Guess what WE're fixin to do??
Kerrdog
Go Fish! <*////><
Unread 09-26-2010, 06:57 AM   #380
Jim1611
Jim1611's Avatar
Looks to me like you're fixin to haul a deer out of the woods on that rack you got there. Nice paint job. Maybe Clay will want to piant the jeep like that.
www.crabtreetool.com (Crabtree Shackle Hangers)
My build thread
http://www.jeepforum.com/forum/f8/ji...build-1093702/
Jim1611 is offline   Reply With Quote Quick reply to this message
Unread 09-27-2010, 05:55 PM   #381
Skerr
I keep discovering things that Clay's Jeep doesn't have... like the canister. I was looking at the Chilton's manual at the emissions section, and the vapor lines go to the liquid check valve and the rollover valve. I probably won't install those parts. Can I just loop the two vent outlets together? Or should I run a line up to the charcoal canister?
Thanks
Kerrdog
Go Fish! <*////><
Unread 09-27-2010, 06:25 PM   #382
Ken4444
Corripe Cervisiam
Ken4444's Avatar
I keep discovering things that Clay's Jeep doesn't have... like the canister....Or should I run a line up to the charcoal canister?
Thanks
I would find a charcoal cannister. This is worthwhile emission control device that absorbs gas vapors from the tank and the carburetor. The vapor is then pulled into the intake system when the engine is running. It seems like a simple and worthwhile technology to use.
"I give you a republic, if you can keep it." - Benjamin Franklin
Ken4444 is offline   Reply With Quote Quick reply to this message
Unread 09-27-2010, 08:08 PM   #383
Skerr
Thanks
I contradicted myself... we don't have a canister. What I should have said was "some kind of vent"!
This Jeep has no emission components on it. What would be needed to get the vapors from the tank to the intake?
Kerrdog
Go Fish! <*////><
Unread 09-27-2010, 08:17 PM   #384
243
1978 FSJ Cherokee
Where are the piggy's
I saw a ragged out Toyota 4x4 flatbed Sunday with two 150+ pounder's on the back. Made me want to go hunting!
Unread 09-27-2010, 09:04 PM   #385
Skerr
No piggies but I missed opps at two 8-pointers Saturday evening.... heart-stopping, knee-shaking, why-can't-I-function opportunities!
Your Avatar looks like ratrod!! Just needs a blower sticking up out of the front!
Kerrdog
Go Fish! <*////><
Unread 09-28-2010, 07:50 AM   #386
Ken4444
Corripe Cervisiam
Ken4444's Avatar
Unfortunately I don't think it's that simple. If you just ran a vent line from the tank to the manifold vacuum, then that would cause all kinds of problems that would stem from the engine sucking in air from the tank which would amount to a vaccum leak as far as the engine was concerned.
Plus, the factory charcoal cannister also connects to the carburetor's bowl vent so that gas evaporating from the bowl has somewhere to go.
So then you start to get back to the factory-installed setup of a charcoal canister and the pressure valve that's in there.
Maybe someone could design something inbetween a single vent line and the factory system, but I don'tknow.
I can understand why people remove the emissions control hardware from old vehicles, but I think it's unfortunate. I think it stems from a lack of understanding about how the things work and what the components are designed to do. From the point of troubleshooting a poorly running vehicle, I can see how a person would want to rip out stuff that's not really essential, but personally I like to leave in place systems like the cat and the charcoal cannister because they generally operate trouble-free and have little impact on performance. I remember removing my computer and all of the related hardware and wiring and it was a satisfying experience, but I also remember going over the remaining vaccum and vent lines and being happy to know that the necessary plumbing was in place to keep things running well and as clean as possible.
If I had a CJ with no charcoal cannister, I would probably get the thing running right as-is, then plan to add the cannister and related plubming later if I could find the parts for a reasonable price.
Unread 09-29-2010, 08:16 AM   #387
Eaglekeeper
I have a cannister, but it looks like the original and have no idea if it's any good. PO disconnected some years past and it's probably shot. Seems these are fairly straight forward devices; anyone know if a cannister from a later model car or truck work? My local salvage yard is full of cannisters at a cheap price.
One eight pointer chance in a weekend is rare. You must have been doing something right to get a chance at two. Sorry to hear no dice though; it happens.
Keep plugging along with the lines; I need you to do the work so I can just follow along with mine.
86 CJ7, 258 Engine, T-177, Dana 300.
[url]http://www.jeepforum.com/forum/f8/let-games-begin-new-build-86-cj7-1046943/[/url]
A ton more pics here.
[URL="http://s1038.photobucket.com/albums/a462/E9Eaglekeeper/"]http://s1038.photobucket.com/albums/a462/E9Eaglekeeper/[/URL]
Eaglekeeper is offline   Reply With Quote Quick reply to this message
Unread 09-29-2010, 06:05 PM   #388
Skerr
I think what we'll do is just vent the tank. In essence, it is nothing more than a gas can, and I don't have canisters on those. I hope we will be able to provide some kind of learning experience for someone. That would make it worthwhile.
The remainder of Clay's parts arrived yesterday. Everything that we need to install the fuel system. A JF member has offered a discounted price on a new crossmember, which I deeply appreciate. So, as soon as we get that handled we'll be able to install the tank and we can proceed. Just trying to tie up loose ends...
Kerrdog
Go Fish! <*////><
Unread 09-29-2010, 06:30 PM   #389
Coiz
1979 CJ7
You can just let it vent to atmosphere, that's how the old ones were. Just be aware that the CJ might sometimes smell like raw fuel and your fuel economy could appear to suck because of the evaporation loss due to sitting out in that nice Florida sun.
The liquid check valve is the hard part to find and the vapor line is the most expensive. The rest of the parts can easily be found at a salvage yard or bought new for reasonable prices. Any 3or 4 port canister you find at a salvage yard would work fine. So I guess I'm with Ken, if you have most of the parts or can get them cheap then put it on, if not run the vent setup.
Mike
My build thread
Coiz is offline   Reply With Quote Quick reply to this message
Unread 09-29-2010, 06:34 PM   #390
Jim1611
Jim1611's Avatar
I agree Scott. Even if you need to go back and correct something you can always do that. Guess you could run a line to the tank for a future vent if you need it so you can plug into it without taking the tank off.
Parts getting there and a crossmember on the way. You all will be putting that together soon enough. Where did you decide to get the crossmember? When are we going to get to see it?
My build thread
1979 , cj5 , fiberglass , rollcage , tailgate
