Clay's Build Thread - Page 246 - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Clay's Build Thread
TJ BDS 2" suspension lift!! FINALLY a GREAT 2" l50% Off Sale at KrawlOff-Road.comTactical Recovery Equipment Soft Shackles!!!
Unread 07-24-2012, 04:33 PM   #3676
Turtle71
1983 CJ7
I saw this and thought it was a pretty cool idea for soldering.
http://staceydavid.com/articles/tips...ing-clamp-4075
My slow 83 CJ7 Build:[url]http://www.jeepforum.com/forum/f8/turtle71s-83-cj7-project-1136836/[/url]
Turtle71 is offline   Reply With Quote Quick reply to this message
Unread 07-24-2012, 05:19 PM   #3677
cjdogtoy
1976 CJ5
there you go duct tape the spray cap to the inside of the dash or fire wall to hold things still.
[url]http://www.jeepforum.com/forum/f8/tell-me-what-you-think-about-new-project-1133483/[/url]
cjdogtoy is offline   Reply With Quote Quick reply to this message
Unread 07-24-2012, 05:24 PM   #3678
Dadamsnv
Dadamsnv's Avatar
1977 CJ5
genius!
Sell me your Scout II Dana 300!!!
I'd prefer one with a manual bull gear, but I'd consider buying one with an automatic bull gear for the right price.
Dadamsnv is offline   Reply With Quote Quick reply to this message
Unread 07-24-2012, 05:49 PM   #3679
Skerr
That's pretty cool! I'll see if I can do it under the dash, upside down! Thanks!
Kerrdog
Go Fish! <*////><
Skerr is offline   Reply With Quote Quick reply to this message
Unread 07-24-2012, 06:00 PM   #3680
pman
pman's Avatar
Originally Posted by 243 View Post
Scott,
Getting the upper main seal out may be a bear, if you have to punch it out make sure you don't use a steel punch or you can damage the crank.
Skipper-
You DID remove the top piece of the RMS didn't you (what 243 is referring to)? I might be reading your post wrong, but it sounded like you just replaced the seal in the bottom bearing cap. The top one should be replaced while you are in there.
If you didn't, heed 243's advice and use a brass punch so you don't scratch the bearing surface.
88 Wrangler Laredo 258-999-NP231
81/76 CJ5 304-t150-Spicer 20
82 Wagoneer 360-727-NP208
82 CJ8 Scrambler 258-t5-Dana 300
http://www.jeepforum.com/forum/f8/cj...-lulu-1350563/
pman is offline   Reply With Quote Quick reply to this message
Unread 07-24-2012, 09:35 PM   #3681
Skerr
Originally Posted by pman View Post
Skipper-
Yeah, sorry... didn't mean to mislead anyone. We had company, and I was trying to listen and type at the same time! Clay and I replaced both pieces of the RMS. I got the top piece out in whole condition, although it was brittle. I was careful to not scratch any of the bearing surface. I am, however, worried about the open condition it is in right this moment (oil pan is still off). I could not button everything up, as I said, we had comapny! So the bottom of the engine is open. I want to clean out the burned-in gunk that I see "up in the corners" of the block. Is it reasonable to spray it all down with brake cleaner or carb cleaner? Some kind of flush to get all the gunk out?
My Chilton's says, as near as I can tell, that the torque specs for the bearing cap is between 75-85 ft/lbs. Can anyone confirm this is correct?
Thanks, All...
Kerrdog
Go Fish! <*////><
Unread 07-24-2012, 09:41 PM   #3682
8pitcher
Yes 75-85 ft lbs
[URL="http://groups.jeepforum.com/built-not-bought/"][COLOR="Black"]Built Not Bought #640[/COLOR][/URL][/FONT][/SIZE][/COLOR][/CENTER][/COLOR]
8pitcher is offline   Reply With Quote Quick reply to this message
Unread 07-24-2012, 10:08 PM   #3683
Dadamsnv
Dadamsnv's Avatar
1977 CJ5
I've heard 100 ft lbs. I hate to make it confusing :/ I did mine to 100
Unread 07-24-2012, 10:11 PM   #3684
8pitcher
I looked in my manual.
Unread 07-24-2012, 10:12 PM   #3685
8pitcher
100 for 304
Unread 07-24-2012, 10:16 PM   #3686
Dadamsnv
Dadamsnv's Avatar
1977 CJ5
Originally Posted by 8pitcher
100 for 304
Touché
Unread 07-25-2012, 06:36 AM   #3687
Jim1611
Jim1611's Avatar
Catching up with what's going on. Not likely to hurt having the pan off for a short while Scott. My biggest concern would be the wind blowing sand up in there though, you have talked about that problem in the shop before. You sure don't want any gritty material in there. Diesel fuel would make a pretty good flush for the inside of the block. They make stuff for the outside, like gunk, but that needs to be flushed with water and you can't do that for obvious reasons. Brake cleaner might attack the seals too so maybe you need to stay away from that.
www.crabtreetool.com (Crabtree Shackle Hangers)
My build thread
http://www.jeepforum.com/forum/f8/ji...build-1093702/
Jim1611 is offline   Reply With Quote Quick reply to this message
Unread 07-25-2012, 06:58 AM   #3688
gmakra
Skipper a picture is worth a thousand words and we only had 250 words yesterday.
So I gotts to eat me words of wisdom I gave to you yesterday. The guys is correct thats yer oil pan gasket fro a four piece now Ya ll now have a one piece.
As Jim said its not really a big deal if you have the crankcase open for a few days, I would just change the oil or as Ya ll say earl after the first run to flush any crud out.
BTW the word CRUD comes from the nuclear field they built one of the first reactor on Chalk River and when they opened it up there was an unidentified deposit in the bottom, so they called it Chalk River Unidentified Deposits.
gmakra is offline   Reply With Quote Quick reply to this message
Unread 07-25-2012, 10:45 AM   #3689
Turtle71
1983 CJ7
I guess I didnt fully understand the predicament you are in. I guess that's what I get for reading too fast
Unread 07-25-2012, 12:29 PM   #3690
Cutlass327
Cutlass327's Avatar
1978 CJ5
I just usually slip the heat shrink over the one wire, strip 1/4-1/2" of each wire, mate them end-to-end with a little overlap, then twist them around each other so that they are inline (not twisted like a twisty-tie would be around the bread bag). This gives a solid mechanical joint, then a dab of flux if it is older wire and a good heating with the soldering iron while holding the solder to the other side of the wire. I may sometimes put a dab of solder on the tip of the iron (more than you wold when tinning it) which seems to help the heat transfer to the wire.
Rick
1978 CJ5 258/T177/D300, '86 D30/D44 WT axles, 'glass tub windshield frame, and fenders, 31x10.5 BFG A/T, TDK galv'd frame - DD and weekend toy
http://www.jeepforum.com/forum/f8/ri...8-cj5-1223197/
Cutlass327 is offline   Reply With Quote Quick reply to this message
1979 , cj5 , fiberglass , rollcage , tailgate
