Clay's Build Thread - Page 234 - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Clay's Build Thread
Ruffstuff 10 year saleBDS 4-1/2" Suspension Lift Kit - Jeep Wrangler YJRough Country Lift Kits and Parts!
Unread 07-09-2012, 10:32 AM   #3496
lucdog
lucdog's Avatar
1980 CJ5
As promised here's your pictures.
Flat side towards the tub.
About the Waggy with no top, tell Beth real women don't need no stinking tops.
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7
1989 YJ the CJ to YJ.
lucdog is offline   Reply With Quote Quick reply to this message
Unread 07-09-2012, 10:36 AM   #3497
lucdog
lucdog's Avatar
1980 CJ5
Originally Posted by gmakra
Skipper you can catch those nasty lil elfs/gremlins that cut your bolts to short with no pest strips! But it sounds like you will need a lot since you probably have a colony of them.
Scott, you should see the size of the pest strips in Chicago. And I just happen to have a picture of one.
The tape measure is for size comparison.
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1983 CJ7
Unread 07-09-2012, 12:39 PM   #3498
243
1978 FSJ Cherokee
I love my Stihl, it blows which is not the same as sucks!
1978 Cherokee, 360/T400/QT...5.3/4L60E/NP241C in the works...
243 is offline   Reply With Quote Quick reply to this message
Unread 07-09-2012, 12:58 PM   #3499
Skerr
Bill
I'm NOT telling her that! You CRAZY!?!?
Attachment 429650
As a single man you probably need that!
Kerrdog
Go Fish! <*////><
Skerr is offline   Reply With Quote Quick reply to this message
Unread 07-09-2012, 01:25 PM   #3500
lucdog
lucdog's Avatar
1980 CJ5
I had to look at the picture, i'm like Stihl doesn't make tape measures. Then I saw it in the shadow . Thats the baby one, we have more trees than grass so a BR400 back pack blower is a necessity.
Tell her George said it. Bill would NEVER say that, just do this
Being single, he probably see's more action than you!
Your pal, Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1983 CJ7
Unread 07-09-2012, 05:38 PM   #3501
gmakra
Bill Thanks a lot, I get in to enough trouble by just existing I dont need any help in that department!
And here old buddy your throwing me under the bus!
gmakra is offline   Reply With Quote Quick reply to this message
Unread 07-09-2012, 06:35 PM   #3502
MoC
Classic! I like that!
MoC is offline   Reply With Quote Quick reply to this message
Unread 07-10-2012, 12:55 AM   #3503
Skerr
I worked on the Jeep until nearly 4:00 yesterday morning. I just couldn't put it down! I pulled out the wiring harness, spread it across the floor, and started IDing some things, and that actually went better than I expected it to. Clay bought a box of goodies from a JFer, and he included his complete harness, and I do mean complete! Now, the PO harness is a totally different story! My PO apparently had some woodpile family members, and his previous Jeep work proves it. I CAN say this... it doesn't take a lot of wiring to make a Jeep run well! He proved that too!
So after coffee this morning, and a wake up text from Bill, I got busy... again. I'm really gonna hate going back to work on Wednesday, but I gotta do that work thing.
Pulled the master cylinder to extend the pushrod. Got it cut, threaded for a coupling nut, and it's good to go. LOTS of brake pedal. I pulled the PO bellcrank parts out of the box and began working on that. Marvelous imagination our PO has. I have to give him credit... he is probably kin to MacGyver! I made a tub mount for that end (whatever you call it- tub-mounted pivot?) and got it so the bellcrank is level, plumb, straight, good to go. Now it is closer to the tub than before, so we cut the clutch rod to shorten it. Clay measured twice and cut once (had to remove an inch and a quarter) so he could weld it to the correct length. he shold have measured three times!! As if I haven't been there. You know... it doesn't matter how many times you cut something when it is too short. It's STILL too short! So we threaded it and installed a coupling nut on it too! After Wifey ran errands for me! I didn't have the correct die for cutting threads. the clutch rod is too fat for my stuff, so I got out my BIG metric set and cut the rod down using consistently smaller metric dies. Once it was the proper diameter we were able to get a 1/2" SAE die on it. Not the BEST thread job I've ever done, but it will work. Once it was all assembled on the frame/tub we connected the pedal and it pretty much sank to the floor! Whoa. Then I discovered the rod was worn terribly at each 90. So Clay will weld that up and grind it down again. However, just working the whole assembly by hand I can see a LOT of play in the entire bellcrank mechanism. The bellcrank arm is fine. the two pivot ends are worn. I think the bushings are gone?? Without replacing everything, what parts can I/should I replace to get it tightened up? The whole kit is a little over $100. Clay is getting to the point that he wants to stop spending money with no return! I can understand that!! I priced the parts I think I need on Morris, Qtec, and 4wd. 4wd was cheapest, but they don't show the pivot that mounts on the bellhousing.
Sorry for the ultra-long post. Here is a short post for Bill, who has trouble remembering things. The rest of you ignore it. Ready Bill? Pay attention. Read slow...
There once was a boy named Tony. He wanted a pony. He said, "Dad, can I have a pony?" And his dad said, "No, Tony, you may not have a pony!"
The boy doesn't get the pony, Bill. It's a long book so I thought I would tell you how it ends!
Here's a pic of MoC's dash and where we are with it right now. Got it boogered up some working on it. I'm looking for a trim ring to go around the speedo bezel as the hole has some gaps showing. Any ideas?
Kerrdog
Go Fish! <*////><
Unread 07-10-2012, 05:11 AM   #3504
gmakra
Skipper I have done some calculations (again) and I dont think its all the POs fault. According to my calcs its the CO and him putting his nasty Swannee Swamp feet up on the front crossmember of the Minnow. This is a sign of disrespect in most areas of the world!
Also that Swannee toe jam is some potent stuff it has the ability to disinigrate copper (which is why the harness looks like its missing some stuff) It will also shrink steel, so thats why the bolts are too short.
Luckily any assembled items will shrink at the same rate so you should be good.
Unread 07-10-2012, 05:40 AM   #3505
Gido
1980 CJ7
How in the world did u get out of bed after holding the jeep UP all night. All those tools you have been sending mrs Kerr after, y don't you see if she can get you some jack stands so all you have to do is pick it up and set it back down? Hahahaa
"At first you don't succeed, get a bigger Hammer!"
in memory of Jimmy Smith - a wise man
Gido is offline   Reply With Quote Quick reply to this message
Unread 07-10-2012, 09:28 AM   #3506
lucdog
lucdog's Avatar
1980 CJ5
Did you put the clutch pedal return spring underneath the dash. Don't forget the spring that goes between the bell crank and the clutch arm.
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1983 CJ7
Unread 07-10-2012, 09:33 AM   #3507
MoC
The dash looks great!! Y'all are making great progress and should feel really good about what u have gotten done.
Unread 07-10-2012, 10:05 AM   #3508
Skerr
Yu gots to r'membr... doun thisa way weez slepes wid ar jepes. weez prity klose, an towjam aint no prob'm. Weez eets it ever morning... Yu wont mabee I shood sent yu a jar?
Oh ha ha! Just because I can hold my Jeep, and you can't! When you actually gonna come over this way? I'll show you what I know. Watch closely.
No springs under dash yet. I have some springs... don't know if they are correct. Can't figure out where they go, because when I install them the pedals do not return to the top. My 7 is different. Yes, bellcrank has the spring in place. I can see no better place than where the PO has it installed, but I would not call it correct
Did you notice your tweeter hole!? It's got a tach in it!!
Thanks MoCarooni.
Kerrdog
Go Fish! <*////><
Unread 07-10-2012, 10:07 AM   #3509
MoC
Thanks MoCarooni.
I saw that and it worked out great. Nice how the bump out covered the other one as well!
Unread 07-10-2012, 10:12 AM   #3510
Gido
1980 CJ7
I was actually thinking of a visit. I will be off next Monday and little man will be at daycare so, I might be able to swing it. Will let you know when it gets closer. I love that pop out on the dash. That's sweet! Coming along nicely! Put on the sunglasses the lights getting brighter!
1979 , cj5 , fiberglass , rollcage , tailgate
