Clay's Build Thread - Page 233 - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Clay's Build Thread
Tactical Recovery Equipment Soft Shackles!!!50% Off Sale at KrawlOff-Road.com50" LED CREE Light Bar Pair With Wiring Kit
Unread 07-08-2012, 06:33 PM   #3481
lucdog
lucdog's Avatar
1980 CJ5
My day went great
You typed so much I can't remember it all, except throwing stuff. Stop that!
Anyway , I'm glad you had a "good" day, and got some things completed.
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7
1989 YJ the CJ to YJ.
lucdog is offline   Reply With Quote Quick reply to this message
Unread 07-08-2012, 06:53 PM   #3482
243
1978 FSJ Cherokee
Originally Posted by Skerr View Post
Putting things back together. Installed pedal assembly, dropped it from the firewall to the tub floor first... had to ding the glass and paint. Couldn't leave it looking pristine.
Then installed the dash (mocked up), and scratched the door sills, cage, and cowl to pieces. Didn't want the floor to be alone. Then bolted down the cage, but now the bolts aren't long enough (????????). I think someone snuck inside my shop and cut the bolts short.
Must be what happened, no other reason for it. The cage is wracked and 2 mounts/bolts don't line up, and it doesn't sit flat anymore. I think whoever snuck inside my shop ran over the cage to be ugly. HAS to be what happened. I was looking at the mis-fitting cage and I said, "Would you look at that?" Really... I said that. "Just look at it", I said. Clay looked sleepy. Clay got his steering shaft apart and primed, also worked on his battery box.
I have the steering gearbox installed and plumbed, master cylinder installed and plumbed (forgot to bench bleed!), threw my sunglasses at the yard, but nothing happened to them, so I went out and got them and threw them at random things inside the shop until they came apart. That made me feel... somewhat... better.
It's hot outside. MoC's dash is textured and painted, and now sitting in the house awaiting gauge install. Dang... acme out good.
I was cleaning up one of the two speedos I have, wirewheeling the rust. Disassembled completely. The chrome housing ring caught the edge of the bench grinder/wire wheel and the wheel pulled it out of my hands and jammed it into the wheel housing, slightly altering the shape so it more closely resembles an egg. I couldn't throw the grinder, so I threw the ring. It was already messed up. Then I went and got it and straightened it out. Put it back together and put it on the shelf. It can stay there. Stoopid speedo. Gotta go eat now.
Misery loves company bud, my day was just as sweet and productive
1978 Cherokee, 360/T400/QT...5.3/4L60E/NP241C in the works...
243 is offline   Reply With Quote Quick reply to this message
Unread 07-08-2012, 07:05 PM   #3483
VACJ7
Hockey Rules!
VACJ7's Avatar
Sorry to hear all the troubles today Scott but dang that was funny reading! Take a break and don't let it discourage you. You guys have come a long way as Dave has reminded you. But then again, probably should not listen to me. I launched my intake manifold across the garage and down the driveway.
'84 CJ-7 | REBUILD IN PROGRESS
VACJ7 is offline   Reply With Quote Quick reply to this message
Unread 07-08-2012, 07:22 PM   #3484
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
Scott
Dude, reading that just made my day.
It's been one fiasco, after another, on my 360 build, so I can whole-heartedly relate.
In the end, I think these little frustrations are what make it soooo satisfying when you complete the project.
Matt
Matt1981CJ7 is offline   Reply With Quote Quick reply to this message
Unread 07-08-2012, 07:22 PM   #3485
Skerr
Originally Posted by lucdog View Post
My day went great
Bill
I'm still irritated. But just finished the gauge install on Clay's kicker. Gotta trim here. Gotta trim there. Need a black ring to go around the speedo bezel for appearances (anybody know if there is such an animal?). Can't find the switch cluster I want. Haven't figured that out yet, so dash ain't done.
I felt buoyed all day, despite the lousy attitude I had. It must have been you having YOUR lousy day. THANKS, Bro. You're Special!
And now you made me smile...
If you had been here today, I would have COMPETED with you at manifold launching. You know how it is when you get in a work mode. I hate to stop!
-Need trim ring around speedo. Somebody find me something to use!
-Switch panel will cover Clay's original idea for factory switch cutouts (area between speedo and gauges). The area I need to cover is 3.5" - 4.5" W by 6.5" - 8.0" high. Can be one panel or two. Can be lighted toggles instead of rockers. I need 3-6 illuminated rockers, 20-25 amps, on-off, with 12V accessory plug (preferrable). I DON'T want to spend $75 for one, so DON'T show me one for $147!
Kerrdog
Go Fish! <*////><
Skerr is offline   Reply With Quote Quick reply to this message
Unread 07-08-2012, 07:36 PM   #3486
Skerr
Oh yeah... Clay has officially ordered his new wheels and tires from Summit (Thank You Paul for providing the footwork). Cragar Soft 8 (15X8), BFG AT 33x10.5x15, black center caps, black lug nuts, tires mounted and balanced, delivered $1038. I thought that PDG, and I thought the salesperson (William) was excellent. William is extension 5724. BTW- we called Summit Thursday evening about 9:30 PM. We could not order at that time. We hadn't transferred the money yet. And William was going home for his weekend. He would be back to work Sunday. I called him back this afternoon. He had saved the list of parts I wanted, and he had it ready for my phone call today! I was impressed.
Kerrdog
Go Fish! <*////><
Unread 07-08-2012, 08:05 PM   #3487
gator4ever
1978 CJ7
I want to urge you guys on. I am a new member and read your thread. I think it is wonderful that your doing this with your son.
Memories last a life time. This is more about building a young mans character than building a Jeep. I am sure both will turn out super.
Keep going and Go Gators!!!!!!!!!!!
gator4ever is offline   Reply With Quote Quick reply to this message
Unread 07-08-2012, 08:29 PM   #3488
scoutboater
In Over My Head
scoutboater's Avatar
1974 CJ5
...Cragar Soft 8 (15X8), BFG AT 33x10.5x15, black center caps, black lug nuts, tires mounted and balanced, delivered $1038...
Hey Scott, I'm interested in seeing how this turns out! I've always kinda liked the black rims look, and this is just taking that as far as you can go!
The D.I.N.K Build - 1974 CJ5
scoutboater is offline   Reply With Quote Quick reply to this message
Unread 07-09-2012, 01:22 AM   #3489
Skerr
Originally Posted by Matt1981CJ7 View Post
Scott
Matt
Thanks, Matt, and I agree with you. At some point all the troubles will be gone, and we'll enjoy the Jeeps. It has been an amazing learning curve, full of excitement and successes. There have been no let downs at all, only stumbling blocks It's all about overcoming, fortitude, perserverance, dedication, etc, etc, etc! Glad you had a laugh!
Amen, Brother. I appreciate it, and welcome to the forum. Lots to "do" here and plenty of saavy. Thanks for following along. My oldest son starts at Gatorland in about 6 weeks!!
I like the black rim look too, but for the life of me I don't know why! They are so boring. But SO DANG TOUGH!! Nothing shiny on this Jeep, but I think polished wheels would have looked good too. I'm not especially fond of the Soft 8s, but Clay likes them, and it's his money, his Jeep.
I have been working "overtime" on this brain-warping contraption! I discovered that Clay's PO welded the draglink. It looks like one of those things you see in a picture and say something like, "What was the dude thinking?" I need to order a draglink. I installed WT axles on his rig. Which one do I order?
This one,
http://www.quadratec.com/products/56117_00.htm
Or this one?
http://www.quadratec.com/products/56117_01.htm
Thank you
Kerrdog
Go Fish! <*////><
Unread 07-09-2012, 05:57 AM   #3490
lucdog
lucdog's Avatar
1980 CJ5
Compare the prices at the local auto store for the drag link. They should have the sleeve, bolts, and both ends. And get the Moog parts.
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1983 CJ7
Unread 07-09-2012, 06:18 AM   #3491
VACJ7
Hockey Rules!
VACJ7's Avatar
I may have a spare WT drag link on a shelf in the garage. I replaced mine with Moog. If I have it... and you want it, it's yours.
Unread 07-09-2012, 06:47 AM   #3492
Jim1611
Jim1611's Avatar
You need to hang a punching bag in the shop Scott. Better than throwing stuff.
Well reading your mishaps I gotta tell you about mine. I was cutting shackle hangers the other day and broke a cutter. It had allot of use so I didn't feel too bad. Ordered a new one, $328.27. Got that going, for about 20 minutes and was doing something else while it was cutting and heard it snap! Mistake on my part. So I ordered another one. Same price. I got that running and everything was working great and all of a sudden it was destroyed, another mistake on my part. I was readY to cuss by this time but didn't. I held what was left in my hand and really wanted to throw it but this is solid carbide and it's heavy enough to really damage something so I didn't. Now I've ordered another one, a somewhat cheaper one. So far I've got almost $900.00 in a cutter. Hope it don't break soon! That would have finished the 9" front end on my CJ!
Yep I understand your pain my friend. But I'm grinning while writing this. We'll have these days again if we keep living.
www.crabtreetool.com (Crabtree Shackle Hangers)
My build thread
http://www.jeepforum.com/forum/f8/ji...build-1093702/
Jim1611 is offline   Reply With Quote Quick reply to this message
Unread 07-09-2012, 07:07 AM   #3493
Skerr
Bill
Thanks, Paul. Let me check local prices at AZ. They're fairly inexpensive. I'll get back to you.
You are so right. Thank you for your wisdom, Jim. At least I can go back and fix our scratches. Not like you're going to join the bits back together. You're a GOOD man!
Kerrdog
Go Fish! <*////><
Unread 07-09-2012, 07:08 AM   #3494
Skerr
So... confirming I need a WT draglink?????????
Kerrdog
Go Fish! <*////><
Unread 07-09-2012, 08:21 AM   #3495
gmakra
Skipper you can catch those nasty lil elfs/gremlins that cut your bolts to short with no pest strips! But it sounds like you will need a lot since you probably have a colony of them.
gmakra is offline   Reply With Quote Quick reply to this message
1979 , cj5 , fiberglass , rollcage , tailgate
