Clay's Build Thread - Page 230 - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Clay's Build Thread
BDS 4-1/2" Suspension Lift Kit - Jeep Wrangler YJRuffstuff 10 year saleRough Country Lift Kits and Parts!
Unread 07-05-2012, 12:57 PM   #3436
lucdog
lucdog's Avatar
1980 CJ5
Words not needed
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7
1989 YJ the CJ to YJ.
lucdog is offline   Reply With Quote Quick reply to this message
Unread 07-05-2012, 01:05 PM   #3437
Jim1611
Jim1611's Avatar
Well Bill he thinks he's got it worse than us up north. 100 here today too.
Nice job on tappin that hole old dude.
www.crabtreetool.com (Crabtree Shackle Hangers)
My build thread
http://www.jeepforum.com/forum/f8/ji...build-1093702/
Jim1611 is offline   Reply With Quote Quick reply to this message
Unread 07-05-2012, 03:44 PM   #3438
DutchJPR
Originally Posted by Skerr View Post
Carb mocked up and the PCV can be easily attached (once I get enough tubing).
Okay, all you experts can wake up now!
And this concludes our lessons for the day...
Nicely done!
Why don't you get one off those angled PCV's, then you tubing is long enough, and it looks way better.
Dutch builds: http://www.jeepforum.com/forum/f8/dutch-build-1231816/
DutchJPR is offline   Reply With Quote Quick reply to this message
Unread 07-05-2012, 04:32 PM   #3439
243
1978 FSJ Cherokee
Wonder how long it will be before Scott posts a HELP thread..."Clay's Jeep feels sluggish, like it's not getting enough air or fuel or something"
1978 Cherokee, 360/T400/QT...5.3/4L60E/NP241C in the works...
243 is offline   Reply With Quote Quick reply to this message
Unread 07-05-2012, 04:47 PM   #3440
lucdog
lucdog's Avatar
1980 CJ5
Check your 7, I pretty certain the PCV goes in the front of the cover. And
X2 on the 90 degree one.
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1983 CJ7
Unread 07-05-2012, 04:58 PM   #3441
lucdog
lucdog's Avatar
1980 CJ5
I'm guessing Dave means the location of the PVC nipple on the carb, unless I missed something somewhere.
Scott, post a picture of the carb showing the bottom, Like this.
My pen is pointing to where the suction should come from for the PCV valve.
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1983 CJ7
Unread 07-05-2012, 05:33 PM   #3442
Skerr
Originally Posted by lucdog View Post
The Weather Channel... Bah! Nuff said. 7/5/12 @ 6:25 PM Ambient air temp.
Attachment 427542
Bill
Kerrdog
Go Fish! <*////><
Skerr is offline   Reply With Quote Quick reply to this message
Unread 07-05-2012, 05:50 PM   #3443
lucdog
lucdog's Avatar
1980 CJ5
The reason for the picture was to make sure of full manifold vacuum. My Motorcraft carb is a little different.
You must have one of those walmart thermometers. Made in china!
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1983 CJ7
Unread 07-05-2012, 06:04 PM   #3444
Skerr
Bill
I'm thinking we have the same carb/vacuum result, don't we? Surprising the differences in the carbs. I thought yours was something different than a 2100!
No WM thermometer. It's called a Hi/Lo thermometer. It records the hottest and coldest temps over a period of time. Reading the bottom of the blue indicator tells you what the hottest/coldest temp was, but I haven't reset it since last summer. It's getting close!
Kerrdog
Go Fish! <*////><
Unread 07-05-2012, 06:05 PM   #3445
243
1978 FSJ Cherokee
Dave was talking about the restrictor towel
Unread 07-05-2012, 06:07 PM   #3446
Skerr
I was thinking I would, almost for sure, be back on here asking performance questions. The towel is designed to keep Clay from flying off the track! You got me on that one!
Kerrdog
Go Fish! <*////><
Unread 07-05-2012, 06:12 PM   #3447
Skerr
Just adding the windshield thread to Clay's build.
http://www.jeepforum.com/forum/f8/ho...glass-1389427/
Kerrdog
Go Fish! <*////><
Unread 07-05-2012, 06:21 PM   #3448
lucdog
lucdog's Avatar
1980 CJ5
I thought that was the mask that Beth and Scott should have been wearing when they painted. And Scott was confused. Or, he wanted to ensure clean air going into Clays engine, in case anyone was painting nearby.
Im at work, i'm not getting paid enough to catch everything,
Yes SCott, big difference between the 2 carbs.
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1983 CJ7
Unread 07-05-2012, 06:34 PM   #3449
VACJ7
Hockey Rules!
VACJ7's Avatar
You should get full manifold vac where you tapped that. When I ran a MC2100 I tapped the adapter plate to achieve the same thing. I think you want to plug this hole. If I remember correctly it goes to the choke and can be the source of a leak.
'84 CJ-7 | REBUILD IN PROGRESS
VACJ7 is offline   Reply With Quote Quick reply to this message
Unread 07-05-2012, 07:22 PM   #3450
Skerr
Clay's carb still has the auto choke on it... shouldn't create a leak. Mine, on the other hand, did leak cause I removed the choke. Had to plug it, but I did so from the outside. Didn't know that hole was there. Thanks, Paul.
Kerrdog
Go Fish! <*////><
1979 , cj5 , fiberglass , rollcage , tailgate
