Clay's Build Thread - Page 225 - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Clay's Build Thread
IRON CROSS Jeep JK Front and Rear STUBBY BUMPERS IN STOCK Rockridge 4WD IS Taking Zone Offroad Suspension Lift Kits Jeep speedometer gears at rockridge4wd
Unread 06-29-2012, 12:09 PM   #3361
Skerr
Skerr's Avatar
Originally Posted by DutchJPR View Post
Trow the harness in, then connect the things you know. I think thats the easiest way....
Dutch... you did see where I mention I completely blank out!?!?!?
Kerrdog
Go Fish! <*////><
Skerr is offline   Reply With Quote Quick reply to this message
Unread 06-29-2012, 12:25 PM   #3362
DutchJPR
Lol...... I'll throw in some more.....
1th pic. right to left: starter,starter relay, battery, alternator(red wire, two connectors), oil pressure sender.
2th pic right to left: oil pressure sender, ignition coil(half moon shapeped thing),? and ? then distributor.
3th pic left under: right side marker, right headlamp and flasher. left midlle: water temp sensor (angeled connector)
4th pic left to right: left side marker, left headlight and flasher, horn, windshieldwasher? ingnition module motorcraft(two rond connectors), fusebox.
Dutch builds: http://www.jeepforum.com/forum/f8/dutch-build-1231816/
DutchJPR is offline   Reply With Quote Quick reply to this message
Unread 06-29-2012, 12:31 PM   #3363
Moogs
In the 2nd pic the half moon thingy I believe is for the coil.
Moogs is offline   Reply With Quote Quick reply to this message
Unread 06-29-2012, 12:45 PM   #3364
DutchJPR
Basicaly the wiring harness has two sides.
One for the engine, it goes roughly from fusebox, ignition module, then to the carb, across the engine over the firewall, tranny's, heater fan then coil and distributor, alternator, and ends at the starter.
Second for the lightning and accesoiry, it goes on the left inner fender to windscreenwasher, horn, left lightning, across the radiator to the right lightning.
Together with the above you should be able to re-connect it.
For referece you could use this scedule. Do print it out, large sized, put it on the wall of the shed. All connectors are on it!
Left under (CDE/1234) is the 6cil enginebay wiring.
I missed the brake safety light, don't know exacly where it's located in the harness.
Unread 06-29-2012, 02:06 PM   #3365
Skerr
Skerr's Avatar
I will come back to the wiring... don't want to break the momentum we have going today. Ordered parts from Morris day before yesterday. Fedex arrived a bit ago, bringing most of the order, including this brand new, unopened, still in the package headlight switch knob. What's wrong widit? Already had to call about new parts quality.
Kerrdog
Go Fish! <*////><
Unread 06-29-2012, 03:09 PM   #3366
lucdog
lucdog's Avatar
1980 CJ5
Yea, where is the insert for the knob.
1957 WILLYS pickup, needs work.
1973 J 4000,
1978 CJ7 DD.
1979 CJ7 360, TH400/Quadratrac trail Jeep.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7 pretty weekend and sometimes to work Driver in the summer, My first rebuild, if the Q-trac and 5 are broke, this one is the one to take. its just as capable as the other 2, except nice paint.
1984 Grand Wagoneer, 1 ton axles, great 360/727, and a big a$& tree fell on it .
1989 YJ the CJ to YJ conversion.
2005 TJ Rubicon.
2011 Grand Cherokee Laredo 4x4, Mrs. LUCDOG's DD.
Lots of parts not for sale, i'm a hoarder.
lucdog is online now   Reply With Quote Quick reply to this message
Unread 06-29-2012, 03:11 PM   #3367
Skerr
Skerr's Avatar
Well, shoot! Momentum busted. Clay says he needs a rest! He is laying on the beanbag watching Dick Van Dyke Show (DVD). I have a pretty significant list for him to pick up in town. I don't HAVE to have those things today, but it is things I could be doing, like the vent nipples for the axle housings. I also need nipples for the MC2100 bases (mine needs one too) for PCV vacuum. Gotta drill and tap holes for them as well. Oh well. When they're 2 years old they want to help Dad. When they're 18, they have to have some say-so.
Things DONE today...
Re-installed the intake/exhaust manifolds. Clay's TIG job is beautiful. Wore out my rotary file and a stone making the bolt hole round again!
Installed other spring plates in the front. PO had welded bolts on for shocks. That is changed now, and I have a place for sway bar (which we have) if we choose to install it.
Wire-wheeled areas of the frame where we had done some welding, applied self-etch primer. Need to brush on some black.
CJ3B said "NO, we can't have Clay's wheel back!" Gonna be a fight!
Went back out to the shop (while Clay was resting!) and discovered one of my big JBLs fell! The bracket went on break! The whole thing came crashing down, and it ended up on my Workmate. But it bounced off Clay's dash first!!!!!!!! Can't use it for sure, now. Bent beyond recognition! Glad MoC is sending us another.
Kerrdog
Go Fish! <*////><
Unread 06-29-2012, 03:17 PM   #3368
Skerr
Skerr's Avatar
Morris is sending out a new one today. YAY! Keeping the bad one I guess, but why?
Kerrdog
Go Fish! <*////><
Unread 06-29-2012, 03:18 PM   #3369
Skerr
Skerr's Avatar
Dang, you are so sharp!!
Kerrdog
Go Fish! <*////><
Unread 06-29-2012, 03:28 PM   #3370
2girlsAndaGuy
1979 CJ5
that dash sure had a bad omen around it, guess it was letting you know one last time that is was a lost cause.
[COLOR="Blue"][URL="http://www.jeepforum.com/forum/f8/project-ioh-79-cj5-refresh-1360217/"]My 79 CJ5 Build Thread[/URL][/COLOR]
David
2girlsAndaGuy is offline   Reply With Quote Quick reply to this message
Unread 06-29-2012, 03:29 PM   #3371
Skerr
Skerr's Avatar
zzzooonnniiinnnggg ooouuuttt... III ssseee llliiinnneeesss aaannnddd bbblllooobbbsss! must make it to the sun. only sun's rays can save me. must... get... outside... feeeeeling weeeaaak! unnmmmph...
Working on it Dutch. Gonna be tough. Thank you.
Kerrdog
Go Fish! <*////><
Unread 06-29-2012, 03:31 PM   #3372
Skerr
Skerr's Avatar
No Kidding! Thinking about turning it into a grill.
Kerrdog
Go Fish! <*////><
Unread 06-29-2012, 03:31 PM   #3373
lucdog
lucdog's Avatar
1980 CJ5
In case some one needs one, that's why. The insert is just glued on. What if the knob pulls off the shaft on your 7.
1973 J 4000,
1978 CJ7 DD.
1979 J20
2005 TJ Rubicon.
Unread 06-29-2012, 03:42 PM   #3374
2girlsAndaGuy
1979 CJ5
na, just hang it above your shop.
David
Unread 06-29-2012, 03:44 PM   #3375
DutchJPR
Makes a nice skewer for the dash grill
1979 , cj5 , fiberglass , rollcage , tailgate
