Clay's Build Thread - Page 22 - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Clay's Build Thread
FS: Jeep Fog Light LED Bulbs! Several Brightness Options! The Original 3/8" Ruffstuff Diff Cover!The Cure for your Tie Rod Roll!
Unread 08-27-2010, 11:04 PM   #316
Coiz
1979 CJ7
Originally Posted by Skerr View Post
Was just reviewing your torque arm build... may have to do the same thing. Glad you take great pictures!!
My arm was 5/16" thick and fits pretty snug between the bushings with minimal play. I would try to stick with 1/4" thick to give the bushings just a little more room between the arm. Yours is so short, I don't even know if it would matter.
Mike
My build thread
Coiz is offline   Reply With Quote Quick reply to this message
Unread 08-27-2010, 11:06 PM   #317
bbc
Finally, I need the "hold downs" for the U-Joint/Yoke for the 20 rearend. I thought it used the U-Bolt style, but it doesn't... it uses the thru-bolt, hold down style. Does anyone have any laying around or a "best" place to get them?
Thanks[/QUOTE]
You need the 1310 strap style, but it may be a good time to think about converting to a u-bolt style.
JEEP CJ 72-86 DANA 30 U-BOLT PINION YOKE CONVERSION KIT: eBay Motors (item 280544842633 end time Sep-04-10 11:06:28 PDT)
bbc is offline   Reply With Quote Quick reply to this message
Unread 08-27-2010, 11:12 PM   #318
Skerr
Thanks
JEEP CJ 72-86 DANA 30 U-BOLT PINION YOKE CONVERSION KIT: eBay Motors (item 280544842633 end time Sep-04-10 11:06:28 PDT)[/QUOTE]
OUCH! That's for a 30... I assume a 20 would be about the same. I do need a new seal installed, and I do want the U-bolt style... dang! Thanks for the link.
Kerrdog
Go Fish! <*////><
Skerr is offline   Reply With Quote Quick reply to this message
Unread 08-27-2010, 11:15 PM   #319
bbc
AMC 20 it is then
20 U-BOLT PINION YOKE CONVERSION - Google Product Search
Unread 08-27-2010, 11:21 PM   #320
Coiz
1979 CJ7
If it is a standard 1310 yoke, I might have some straps and bolts for you. I converted my last strap style to the U-bolts during the build.
Mike
My build thread
Unread 08-27-2010, 11:22 PM   #321
Skerr
WOW! Thank You!! It's funny... I have an extra 30 and a 44 laying on the floor of my shop. I wish one of them would fit!
Kerrdog
Go Fish! <*////><
Unread 08-27-2010, 11:24 PM   #322
Skerr
If you have straps they'll get the DS attached. Clay won't be hammering this thing... at least not for awhile. He still needs to learn how to drive a clutch!!
Kerrdog
Go Fish! <*////><
Unread 08-27-2010, 11:26 PM   #323
Coiz
1979 CJ7
It might. If I remember correctly from my search the D44, D30 and D300 all share the same yoke. Not sure about the 20 as I have never had one of those.
Double check for yourself but I think one off your D30 or D44 would work. This shows them to be the same.
Mike
My build thread
Unread 08-28-2010, 08:31 AM   #324
Jim1611
Jim1611's Avatar
Hey Scott here's what Adavance sends in the adapter kit. It's 1 1/2" x 3" x .12 tubing and the bushing hole is 3 1/4" from the center of the closest tranny mount hole. If you still need the u-bolt straps let me know, I have the 30 and 20.
www.crabtreetool.com (Crabtree Shackle Hangers)
My build thread
http://www.jeepforum.com/forum/f8/ji...build-1093702/
Jim1611 is offline   Reply With Quote Quick reply to this message
Unread 08-28-2010, 08:48 AM   #325
Skerr
That looks pretty substantial but thinner walled than I would expect. So I have a broad range of materials to choose from...
I will get back to you on the straps. I solicited Mike already, and if a current yoke fits, then I may not need them at all. Gotta check it out...
Thanks, Jim
Kerrdog
Go Fish! <*////><
Unread 08-28-2010, 09:08 AM   #326
Jim1611
Jim1611's Avatar
I thought it was a bit thin too. I may build something myself later on. Straps aren't going anywhere. Just let me know if you need them.
Hey Scott check these 2 places out, not far from Waverly.
Heartland Creamery
Heartland Ministries
The fellow that owns this place has a huge dairy and I think poultry business going. I mean it's mega agriculture stuff. Anyway I thought it might be something of interest to you.
My build thread
Unread 08-28-2010, 10:51 AM   #327
243
1978 FSJ Cherokee
Time for some overall update pictures
1978 Cherokee, 360/T400/QT...5.3/4L60E/NP241C in the works...
243 is online now   Reply With Quote Quick reply to this message
Unread 08-28-2010, 01:56 PM   #328
Skerr
Update, huh? You realize that this is the absolute highlight of my life right now!? My wife calls it Jeep Gossip! If I stare at the Jeep long enough it fixes itself!
We're at a slow part again. We have several small things that need to be done so we can move along. Clay is removing the factory shock mounts from the axle tube. I want to try and save them in case someone smashes one on the trail and needs a replacement. But the cutoff wheel doesn't fit in there too well. So we may have to cut what we can and whack it with a hammer to get it off. Then we can finish the shocks. I need some metal screws to attach the holders for the brake lines and Prop valve... does anyone know what size they are, or have another recommendations for screws?
We have the front backing plates to install, calipers, but first new ball joints. I remember, before I tore it down, the Jeep would try to kill you by diving off the road at slow speeds... so we're gonna concentrate on the front end a bit. Of course, I no longer have that axle up there... we're running WT axles now.
Still researching fuel tanks. I found one on Ebait, a 15 gallon poly tank, for .99 with 2 hours to go. It had a $45 shipping fee on top of whatever it sold for. Another seller had a brand new 15 gal steel tank for $99 with free shipping. Hmmm... the poly tank sold for $47 (IIRC). I don't think that buyer was very wise, but beauty is in the eye of the beholder... right? So we're probably going to buy new stuff.
The wheels and tires on Clay's Jeep will have to go. They are 16", which I like, but we're going 15" instead. The tires are 33" and we're going 31". Just a little more safety mindedness on Dad's part... so we gotta find someone to swap out.
Also want to try and swap yokes from the D30 or D44 onto the AMC20 so I can have the U-Bolt style yoke. I monkeyed around with that for a little while with no progress. It's clear I'm gonna have to get tuff with the pinion nuts!
The weather has cooled a good bit today... it's really nice outside. Think me'n the boys will go bust a few caps!
Kerrdog
Go Fish! <*////><
Unread 08-28-2010, 02:04 PM   #329
Skerr
Heartland Creamery
Thank You, Jim. I will drop them a resume and see what happens! Thanks for looking after me!
Kerrdog
Go Fish! <*////><
Unread 08-28-2010, 02:11 PM   #330
Jim1611
Jim1611's Avatar
You're welcome Scott. I think you'd be impressed with the place. They give tours and people I know that have went there say it's like nothing they've ever seen. They say they also have a greatttttttt place to eat there, it's like it's own city way out in the sticks. By the way, it's in some the best deer huting country is Missouri, thought that would be of special interest to you.
My build thread
1979 , cj5 , fiberglass , rollcage , tailgate
