Clay's Build Thread - Page 205 - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Clay's Build Thread
Unread 04-25-2012, 11:41 PM   #3061
Bojon
1981 CJ5
I'm sure you guys will get it figured out. Out of curiosity, whats wrong with the weld, not enough penetration?
Since that landscape job is in a "richie" neighborhood I hope you guys are getting paid handsomely
[URL="http://www.jeepforum.com/forum/f8/1981-cj5-frame-up-1141648/"]My CJ5 Build[/URL]
Jered
Bojon is offline   Reply With Quote Quick reply to this message
Unread 04-25-2012, 11:49 PM   #3062
Skerr
Clay is getting porosity, which is like a million little airbubbles that appear in the finish weld. This effects the weld strength. It would be fine welding your kickstand back on your dirtbike, but not for a cage.
We are charging $10 per person per hour. You can surely get more, but I enjoy the word of mouth, and I like the service industry. I like making people happy with good service. It guarantees that they will call you back.
Kerrdog
Go Fish! <*////><
Skerr is offline   Reply With Quote Quick reply to this message
Unread 04-25-2012, 11:54 PM   #3063
Bojon
1981 CJ5
O, gotcha. On the bright side, the cage isn't holding you back from working on the rest of it.
Jered
Unread 04-26-2012, 12:08 AM   #3064
rixcj
rixcj's Avatar
1979 CJ5
By any chance, did the tubing have any oily residue on, or INSIDE it, perhaps to help prevent rusting? If there's oil anywhere near a weld joint, as soon as the metal starts getting hot from welding, the oil will travel towards the weld joint. With mig, that almost always results in porosity.
What do you mean by "the finish weld". Do you mean the weld that he's putting over the ground out weld? That reminds me....typically, if you have porosity in a mig or tig weld, and you grind it out to re-weld the joint, but you don't get ALL of the original porosity out, it can re-appear in the new weld.
Rich
'79 CJ5, AMC 360, t-18/d20 twin stick, dana 30/amc20(Mosers), Edelbrock Performer intake, Holley 600, ps/pb, DUI HEI, 'glass tub/1pc. tilt nose, 33x12.50 BFG AT's.
There's a fine line between "hobby" and "mental illness".
rixcj is offline   Reply With Quote Quick reply to this message
Unread 04-28-2012, 07:48 PM   #3065
Skerr
Okay. Are ya'll sitting down? You're not holding anything sharp? No open flames? Not cleaning a firearm? Okay... good.
The welding issue is solved.
Clay took his machine to school this morning.
The Instructor tried it out and couldn't get it to work.
He discovered there was no gas coming out of the gun.
He traced it back to the machine.
Clay didn't plug the lead in far enough!
The gas was escaping before it got to the piece.
It welds perfectly!!
Time to move on...
YAY.
( I AM really excited about this, actually. Clay has been moping around, thinking he blew $800. The Instructor thinks his machine ROCKS!! It is good for Clay to have it figured out)
Kerrdog
Go Fish! <*////><
Unread 04-28-2012, 07:55 PM   #3066
bbc
Sweet!
Weld On!
bbc is offline   Reply With Quote Quick reply to this message
Unread 04-28-2012, 07:56 PM   #3067
jcal73
jcal73's Avatar
1979 CJ5
Clay took his machine to school this evening.
Time to move on...
YAY.
That's Great!
Jeff
Our Jeep Links
Our SBC Swap
How We Made a Fan Shroud
jcal73 is online now   Reply With Quote Quick reply to this message
Unread 04-28-2012, 08:08 PM   #3068
mvigo
mvigo's Avatar
now go get 'em!
1985 CJ-7, fuel injected 258, 2.5" Rubicon Express Extreme Duty Lift, 1" Body lift, Crabtree Shackle Hangers, T-5, Dana 300 w/ 4:1 Teralow kit, Dana 30, AMC 20 w/1 piece axle, 3.73 's with Detroit Truetrac front and rear, riding on 32x11.5x15" Cooper Discoverer STT mud terrains
mvigo is offline   Reply With Quote Quick reply to this message
Unread 04-28-2012, 08:17 PM   #3069
pman
pman's Avatar
Great thread, Scott! Might have to take the night off and read through the whole thing! Glad your son got the issue resolved with his welder.
88 Wrangler Laredo 258-999-NP231
81/76 CJ5 304-t150-Spicer 20
82 Wagoneer 360-727-NP208
82 CJ8 Scrambler 258-t5-Dana 300
http://www.jeepforum.com/forum/f8/cj...-lulu-1350563/
pman is offline   Reply With Quote Quick reply to this message
Unread 04-28-2012, 08:17 PM   #3070
rixcj
rixcj's Avatar
1979 CJ5
That's a relief....it's nice when it's a simple fix. You guys will LOVE that machine, now.
Rich
Unread 04-29-2012, 07:30 AM   #3071
gmakra
Skipper hate to say I told you so but I did!
Originally Posted by gmakra
Skipper there sounds like there maybe two problems with Clays welder first there should be some taps in the machine to change wire polarity. Solid wire runs electrode straight polairity and flux core is DCRP. Either will give you fits if its set on the wrong taps. Next look at the gas line cause there is some problem there kinked or cracked or parialy plugged.
For this work I prefer solid wire and on a scale of 1-10 pipe welding small pipe is about a 30 so dont let it get you down.
gmakra is offline   Reply With Quote Quick reply to this message
Unread 04-29-2012, 07:35 PM   #3072
Skerr
Originally Posted by bbc View Post
Sweet!
Weld On!
Originally Posted by jcal73 View Post
That's Great!
Originally Posted by mvigo View Post
now go get 'em!
Rich
Thanks Guys. He definitely loves the machine. His start/stop points are a little rough, but his welds look awesome.
Thanks for stopping in pman! There's a lot of blah-blah in this thread, but I've had a good time putting it there! A natural TON of support too!
Well, if you'd get your butt DOWN here you could have shown us TOO!!!
Clay is halfway done with the cage. His welds look awesome. Now the pressure is back on me to get the tub painted. I made up a list of things left to do, and truthfully, I'm overwhelmed!! I had no idea there was still so much to do. I told ya'll the small parts was gonna kill us, and some of it ain't so small! I'm off the next two days, and Wifey is lining me up with non-Jeep work. And all I want to do is sleep.
Kerrdog
Go Fish! <*////><
Unread 04-29-2012, 08:22 PM   #3073
gmakra
I am a coming on down June 7 th or so
Unread 04-29-2012, 09:45 PM   #3074
mvigo
mvigo's Avatar
Scott,
This was just posted in a new thread titled "Barn find"...it has your OEM 60/40 bench seat in remarkable shape:
Unread 05-01-2012, 07:09 PM   #3075
bbc
Well?
2 days off now, What's the progress? Let's hear it. or did your better 1/2 have more important things for you to get in to? which is OK too.
1979 , cj5 , fiberglass , rollcage , tailgate
