Clay's Build Thread - Page 20 - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Clay's Build Thread
Ruffstuff 10 year saleBDS 4-1/2" Suspension Lift Kit - Jeep Wrangler YJRough Country Lift Kits and Parts!
Unread 08-23-2010, 11:35 PM   #286
FamillyCJ7
1983 CJ7
What year CJ5 do you need for interchangeable parts? There are several on craigslist from early 60's to late 70's.
'83 CJ7 258I6 4-Speed Father Daughter Project - Using Monstaliner/Chassis Saver and Products from CrabTreeTool
NorthEastFL4x4.com - Local 4x4 Enthusiasts website, join up now!
FamillyCJ7 is offline   Reply With Quote Quick reply to this message
Unread 08-24-2010, 06:03 AM   #287
Skerr
I don't need one for parts... I was looking to get another frame because I thought mine was toast, but since it was straightened we're good.
Kerrdog
Go Fish! <*////><
Skerr is offline   Reply With Quote Quick reply to this message
Unread 08-24-2010, 11:45 AM   #288
Jim1611
Jim1611's Avatar
Things are looking up! You guys are gettingn things done now. The motor and tranny and transfer case look great.
www.crabtreetool.com (Crabtree Shackle Hangers)
My build thread
http://www.jeepforum.com/forum/f8/ji...build-1093702/
Jim1611 is offline   Reply With Quote Quick reply to this message
Unread 08-24-2010, 07:59 PM   #289
Skerr
More progress today! Wow... I keep waiting for the bolt of lightning! Things are going pretty good for a change. We got the tranny xmember installed this afternoon. It didn't want to go on, though. I guess since the diamond shape was pulled out of the frame the pan was still slightly wracked. It wasn't a big deal, however, and Clay got it fixed in good time. So, following are pics of Clay working on his renewed love!
First one is Clay wallowing out a bolt hole with the Dremel.
2nd is pretty much the same thing, but DANG it looks good! And Clay bought a new socket set for himself... that means he's excited!
The next two are pics of Clay off in dream world! I just happened to catch him trying it out wearing a big smile!
Kerrdog
Go Fish! <*////><
Unread 08-24-2010, 08:14 PM   #290
Skerr
With the engine off the floor we gained a lot of space. I moved the hoist and cleaned up a lot and generally organized the shop... as much as I could to this point. I got my chains hung up and Clay put together a nifty little grinder/vise stand. It is built on a dumptruck rim using a section of bushhog drive shaft for the stand. It works better than the little one I had before.
Looking at the pic with the knuckle... how tight do I need to make those bolts? And should I replace bushings while I can get to them?
Thanks.
Kerrdog
Go Fish! <*////><
Unread 08-24-2010, 08:24 PM   #291
Ken4444
Corripe Cervisiam
Ken4444's Avatar
How many disc sanders do you have in there?
"I give you a republic, if you can keep it." - Benjamin Franklin
Ken4444 is offline   Reply With Quote Quick reply to this message
Unread 08-24-2010, 09:44 PM   #292
FamillyCJ7
1983 CJ7
You guys are making great progress! Makes me jealous. I got my Chassis Saver in today and most of the frame has been stripped and it looks great. I'm pretty sure I got the air compressor rebuilt and working properly now, I forgot to order the bottom O-ring for the Valve plate assembly so I did a hack fix and used some blue RTV sealant that's made for holding pressure. It should be fully cured tomorrow and I'll switch her on and see if it worked, if not I'll shell out the $30 for the O-ring. If it work's I'll be spraying the frame, leaf springs, brackets, axles and other misc stuff with the Chassis Saver even though I could just brush it on.
Unread 08-25-2010, 07:32 AM   #293
Eaglekeeper
Looking good. I like the colors of the drivetrain and the red fan . Are you going to keep working on the chassis or take a break from it and work on the body?
86 CJ7, 258 Engine, T-177, Dana 300.
[url]http://www.jeepforum.com/forum/f8/let-games-begin-new-build-86-cj7-1046943/[/url]
A ton more pics here.
[URL="http://s1038.photobucket.com/albums/a462/E9Eaglekeeper/"]http://s1038.photobucket.com/albums/a462/E9Eaglekeeper/[/URL]
Eaglekeeper is offline   Reply With Quote Quick reply to this message
Unread 08-25-2010, 08:01 AM   #294
Jim1611
Jim1611's Avatar
Scott I assume when you ask about how tight to make the bolts you're talking about the upper and lower ball joints?
From what I found the other day the bottom ball joint nut is 80 ft/lbs. The top nut and tapered ball joint sleeve should be 50 ft/lbs. Now would be a very good time to replace them if you think you need to. Get the Moog brand joints as they will last longer. Don't make the mistake I did on the bottom ball joint nut either. I decided after getting it torqued down that they needed anti-sieze so I started to back it off. Big mistake because in doing so the nut galled on the threads and ruined the joint, had to buy another. Those nuts are made with indentations in the top of them to act as a lock nut.
You guys have things looking great. I'm glad to see Clay back at it. Just wait till it's done and he's driving it. That'll really make him smile!!
My build thread
Unread 08-25-2010, 06:34 PM   #295
Skerr
Just two... one for a table top, and one floor-type.
Good luck on the compressor. I'm lookng forward to seeing your frame repair pics.
We're going to go as far as we can on the frame. We still have the steering box, front shocks, calipers, brake lines, etc to do. I have to track down a gas tank and hardware too. Once we get hung up on the frame we'll start on the hood. Clay wants to do his own painting so I figure the hood is a great starting point.
Yes... the ball joints. I will probably go with a cheaper brand. Although it will be Clay's DD, he won't DDing everyday, so a less expensive brand should suffice for quite awhile.
Got the rear shocks mounted up today, which was no big deal. It was so hot that I didn't want to do anything outside. We also had a crowd of people over today for a 4-H party... Clay ate too much sa-weet stuff and got a tummy ache, so he didn't feel like doing anything either! Another day burns down...
Kerrdog
Go Fish! <*////><
Unread 08-25-2010, 08:04 PM   #296
Jim1611
Jim1611's Avatar
I almost got the cheaper ball joints too Scott. The way things are made today it's hard to know whether to spend the extra money thinking you're getting better stuff or go less expensive. One thing I do know, from experience, is that a new driver is hard on anything you put them in. I do well remember those days.
My build thread
Unread 08-25-2010, 08:27 PM   #297
243
1978 FSJ Cherokee
I used a cheaper brand and when the knuckles went back together the last time they were rotating on Moog balljoints.
1978 Cherokee, 360/T400/QT...5.3/4L60E/NP241C in the works...
243 is offline   Reply With Quote Quick reply to this message
Unread 08-25-2010, 09:45 PM   #298
bbc
Try these, or at least check them out. I just picked some up for that D44 build i was working on.
XRF Chassis | Automotive and Heavy Duty Chassis Parts | Canada and Unites States
they are only about $20 each, call the place direct for ordering, as you will not find them locally.
Looking good though!
Now if I could ever get all the parts together for this D44, I might get to start on that rear 9",
and have a rolling chassis like SUPER CLAY does!!!!
bbc is offline   Reply With Quote Quick reply to this message
Unread 08-25-2010, 10:32 PM   #299
Skerr
Jim and Dave... you guys have like minds! I checked out the Moog joints. They certainly SOUND better in the description.
Thanks for the link. I'll give them a look. I'm looking forward to your rolling chassis... your work is top-notch!
Checked out the link.... XRF sounds awesome! Thanks...
Kerrdog
Go Fish! <*////><
Unread 08-27-2010, 10:10 PM   #300
Skerr
Comments and Questions
I discovered my Raccoon! My 18 YO thought he'd play a gag on me. He said my shop is always so messy he didn't think I would notice if I was missing tools! So he grabbed a few sockets and hid them. I ended up buying a new 1/2" deep well because I needed it. By the time this was all discovered he had forgotten what he had done, and the joke went longer than planned. I didn't get angry, but he reimbursed me for the socket. You wanna make a teenager feel remorse?? Hit them in the pocket!
After installing the torque arm (thanks to all you guys who posted questions about torque arms over the last few months) I discovered that when I let the tranny down onto the pan, it [tranny] was sitting on top of the torque arm bolt head. I can't see anyway to move it around so that it doesn't hit. I could maybe shave off part of the transmission housing but I don't like that idea. Anybody have any suggestions?? I assume the bend at the end of the torque arm is factory... is it designed that way to clear the transmission? Maybe I need to bend it more??
I have to remove the factory shock mounts from the D30 axle. They are in the way of the stock mounts on the spring plates. I will carefully cut them off with a wheel. Is this a part that anybody might need? If not, I'm going to toss them.
Finally, I need the "hold downs" for the U-Joint/Yoke for the 20 rearend. I thought it used the U-Bolt style, but it doesn't... it uses the thru-bolt, hold down style. Does anyone have any laying around or a "best" place to get them?
Thanks
Kerrdog
Go Fish! <*////><
1979 , cj5 , fiberglass , rollcage , tailgate
