Clay's Build Thread - Page 154 - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Clay's Build Thread
FS: Wranger BRIGHT License Plate LED! Just $3! Great valueIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFS: Jeep Fog Light LED Bulbs! Several Brightness Options!
Unread 01-18-2012, 07:11 PM   #2296
243
1978 FSJ Cherokee
73-87
1978 Cherokee, 360/T400/QT...5.3/4L60E/NP241C in the works...
243 is offline   Reply With Quote Quick reply to this message
Unread 01-18-2012, 08:29 PM   #2297
lucdog
lucdog's Avatar
1980 CJ5
Originally Posted by 243 View Post
73-87
Nice looking truck Dave, was it yours?
pickups changed in 88, the others in 91. There ought to be a bunch in non salt states.
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7
1989 YJ the CJ to YJ.
lucdog is offline   Reply With Quote Quick reply to this message
Unread 01-18-2012, 11:37 PM   #2298
rixcj
rixcj's Avatar
1979 CJ5
Originally Posted by Skerr View Post
IIIIIIIIII haaaaaaad toooooooooo reeeeeaaaaad thiiiiiiiiiiiiiiiiiiissssss sloooooooooooooow. Nowwwwwwwwww IIIIIIIIIIIIII geeeeeeeet iiiiiiiiiiiittttttttt!
That's good, 'cause I typed it real slow, too...
Rich
'79 CJ5, AMC 360, t-18/d20 twin stick, dana 30/amc20(Mosers), Edelbrock Performer intake, Holley 600, ps/pb, DUI HEI, 'glass tub/1pc. tilt nose, 33x12.50 BFG AT's.
There's a fine line between "hobby" and "mental illness".
rixcj is offline   Reply With Quote Quick reply to this message
Unread 01-19-2012, 12:18 AM   #2299
Skerr
Dang, now I gotta look at Chevy lights for MY Jeep! That would look so cool. Why don't you mean old guys leave me alone!?
Kerrdog
Go Fish! <*////><
Skerr is offline   Reply With Quote Quick reply to this message
Unread 01-23-2012, 06:13 PM   #2300
Skerr
Crushing pipe today. Not even good enough for a wind chime!
Kerrdog
Go Fish! <*////><
Unread 01-23-2012, 07:03 PM   #2301
lucdog
lucdog's Avatar
1980 CJ5
Ok what happend.
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1983 CJ7
Unread 01-23-2012, 09:57 PM   #2302
Skerr
Originally Posted by lucdog View Post
Ok what happend.
Bill
http://www.jeepforum.com/forum/f37/n...d-cat-1317952/
Kerrdog
Go Fish! <*////><
Unread 01-23-2012, 10:11 PM   #2303
lucdog
lucdog's Avatar
1980 CJ5
The only thing I can think of is, be it standard black or galvanized, is its a different makeup. Not designed to bend like that, at least not that much of a radius.
I'm guessing this is a practice piece, and if that's the case, pick up a 1.5" or 2" emt. And work with that for practice.
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1983 CJ7
Unread 01-23-2012, 10:27 PM   #2304
cjdogtoy
1976 CJ5
Just get AJ to show you a bend or two and see what the secret of that bender is. hang in there.
cjdogtoy is offline   Reply With Quote Quick reply to this message
Unread 01-23-2012, 10:29 PM   #2305
Skerr
Bill
The tightest bend I'll need to make is a 90*. I didn't even get to that! Guess I'll try packing it with sand and see how that works. What a PITA!
I was expecting some screw ups, but more like bending at the wrong place. Not kinking. The die is a 1 1/2" die, and I'm using 1 1/2" pipe. Should work!
AJ used this thing to build the cages in his race cars over the years. He said it'd been so long since he used it there wasn't a lot he could tell me... I would have to figure it out. He DID help me with figuring out the radius, adding and subtracting. The piece I ruined was intended to be used!! I was going to go slow... measure twice, cut once... you know? I was questioning my skill, not the machine. I learned my unknown skill is greater than the machine!
Kerrdog
Go Fish! <*////><
Unread 01-23-2012, 10:36 PM   #2306
VACJ7
Hockey Rules!
VACJ7's Avatar
Scott, have you seen this modification? Makes sense to me, but not sure AJ would want you drilling a hole in his die.
'84 CJ-7 | REBUILD IN PROGRESS
VACJ7 is offline   Reply With Quote Quick reply to this message
Unread 01-23-2012, 11:00 PM   #2307
Skerr
http://www.youtube.com/watch?v=ZlSnVSrWg0M
NEW HOPE!! Thanks, Paul. I'll get with AJ this week and see what he says.
Kerrdog
Go Fish! <*////><
Unread 01-24-2012, 05:24 AM   #2308
gmakra
Skipper the problem is that you are using a HF pipe bender to bend tubing. Pipe is measured ID or inside diameter and tubing is measured in OD or outside diameter. The reason for this is pipe conveys a fluid, gas or semi soild and the diameter is a constant for flow. Pipe wall thickness will grow on the outside but the ID will remain constant. Tubing on the other hand is a structural member and is measure in OD and if you get thicker tubing it will grow on the inside the OD will remain constant.
Bending requires that your bending shoe (die) is a tight fit other wise it will always kink. And if you have ever tried bending conduit you will know what I mean. Using a 3/4 inch bender to bend 1/2 pipe rarely works and results in kinked or folded tubing which is frustrating and can get expensive.
Now I see what the guy in the video is doing and all I can say is that it is hit or miss. So you will kink some pipe.
I do like the idea of a shim for the die and that might work. What size tubing are you trying to bend Skipper?
What you could try is measure the outside diameter of your tubing and then see what the diffence is. Divide the difference in half and try to find anything that is close to the difference. I would look at EMT first and then make a trip down to your metal guy and see what he has. Cut the tubing in half and slip that over the tubing your gonna bend and see if that makes a difference. Also a lite coat of grease on the dies does help a bit.
gmakra is offline   Reply With Quote Quick reply to this message
Unread 01-24-2012, 01:41 PM   #2309
gmakra
Scotty OK i did some checking and IMC (intermidate conduit can be gotten from a electrical supply house not Lowes or Home Depot) will work as a shim in your bending shoes. The OD of IMC is the same OD as the moninal pipe size you are using. The ID will be the same as your tubing so cut the IMC in half and slip it over the first piece of tubing your going to bend. Make the bend with the IMC as a shim with your tubing once the IMC is bent leave it in the die for future bends.
FYI the 11/2 and 2 inch should be pretty close.
Unread 01-24-2012, 04:36 PM   #2310
Skerr
George- You blew past me so fast I couldn't hear what you said!!
Slow down please and talk like I am impaired! I am using 1 1/2" PIPE, not tubing. I know it is pipe because the owner of the steel yard told me so. He does not stock DOM. This pipe is what all the race car drivers use (roundy round drivers) for their cages. It has a welded seam right down the middle. I am also using the 1 1/2" shoe. I know this because it says so on the side of the shoe. It DOES seem large, however. Maybe I should try a smaller shoe??
I will measure ID and OD so you have something to compare. Been waiting for your input, Geo. Don't be so slow next time! I could have had this DONE by now...
Kerrdog
Go Fish! <*////><
1979 , cj5 , fiberglass , rollcage , tailgate
