Clay's Build Thread - Page 151 - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Clay's Build Thread
Ruffstuff 10 year saleBDS 4-1/2" Suspension Lift Kit - Jeep Wrangler YJRough Country Lift Kits and Parts!
Unread 01-05-2012, 10:33 PM   #2251
lucdog
lucdog's Avatar
1980 CJ5
MoC is right, cool pictures. If it ever gets below freezing here. I'll hose down the front yard, so me and the grandson can do some donuts.
Watch my build thread for my UP, MI. Adventure.
Darn young police officers.
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7
1989 YJ the CJ to YJ.
lucdog is online now   Reply With Quote Quick reply to this message
Unread 01-06-2012, 08:51 PM   #2252
Skerr
Here's another historic picture of Clay's Jeep. Showing where the PO wore away the inner fender with the tire, and nearly got his solenoid!
Kerrdog
Go Fish! <*////><
Skerr is offline   Reply With Quote Quick reply to this message
Unread 01-06-2012, 09:07 PM   #2253
lucdog
lucdog's Avatar
1980 CJ5
Wow!. You've come a long way Scott.
And I see the birthday Girl made Jeepforums again.
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1983 CJ7
Unread 01-06-2012, 09:23 PM   #2254
Skerr
Bill
Yeah... couldn't help it!
Kerrdog
Go Fish! <*////><
Unread 01-12-2012, 11:34 AM   #2255
scoutboater
1974 CJ5
C'mon Skerr! I'm getting withdrawls here....
When is the next update?
[URL="http://www.jeepforum.com/forum/f8/d-i-n-k-build-1974-cj5-2361921/"]The D.I.N.K Build - 1974 CJ5[/URL]
scoutboater is offline   Reply With Quote Quick reply to this message
Unread 01-12-2012, 11:53 AM   #2256
Ken4444
Corripe Cervisiam
Ken4444's Avatar
Originally Posted by Skerr View Post
...Here's a pic of the HF chop saw that I bought. It cut alright, but it's not speedy. Comes with an extra set of brushes. Okay purchase for the money:
I'm catching up on some old posts. I have the same saw and agree with you: It's not fast. I my experience, this saw has these problems:
1) Not great at cutting anything over 1/8" thick.
2) Heats the metal up (orange hot) while cutting slow.
3) Vibrates, especially when the cutting disk gets a gouge. The vibration causes the work piece to move out of position even if it's clamped in tight.
For quick and dirty cuts, it will work, but I've had better luck getting clean and accurate cuts with my HF angle ginder with an abrasive cutting disk. It's the kind of thing where you really start to appreciate the high priced saws used commercially.
"I give you a republic, if you can keep it." - Benjamin Franklin
Last edited by Ken4444; 01-12-2012 at 02:01 PM.. Reason: Corrected a spelling error.
Ken4444 is offline   Reply With Quote Quick reply to this message
Unread 01-12-2012, 12:47 PM   #2257
Cutlass327
Cutlass327's Avatar
1978 CJ5
We have an older DeWalt chop saw at work, and it sounds just like you are describing. I was going to use it to cut the metal when I made my side steps, but the blade kept going off and cutting odd angles. It actually cut into the deck of the saw, the blade flexed so much. I don't know what kind of blades everyone else is using, but we get ours from Home Depot, figuring they'd be better than from HF..
Rick
http://www.jeepforum.com/forum/f8/ri...8-cj5-1223197/
Cutlass327 is offline   Reply With Quote Quick reply to this message
Unread 01-12-2012, 04:53 PM   #2258
Skerr
Hopefully, we'll have a pipe bender here this weekend, and we can start "experimenting" with "shapes"! I expect to make yard ornaments and wind chimes to begin with!!
The HF saw touts 2 HP, but I think it is lacking in amperage. Some of you electrical dudes can explain that (I can't!). My concept of amperage is what gives a piece of electrical equipment its "oomph! when it starts. You can have high HP but low amps, as in the case of the HF saw. The trick with this saw is to NOT push too hard. You have to listen to the motor and cut slow. When it starts to bog, ease up. This saw will overheat if you push too hard, and then you'll burn it out. I think the Chinese knew that, hence the extra set of brushes. Also, there are certain clamping positions that work better when cutting. For example, I like to clamp angle iron with both edges down and begin cutting on the backside of the "V". I have not had any issues with the saw vibrating or pieces coming loose when cutting.
Is it a chop saw (for wood) or a metal cutting saw? My Delta (compound miter) has lots of trouble when I use it to cut metal, that's why I bought the HF saw. I would definitely go to a different blade if it is wandering in the cut. I have never seen a DeWalt do that.
Kerrdog
Go Fish! <*////><
Unread 01-12-2012, 09:47 PM   #2259
lucdog
lucdog's Avatar
1980 CJ5
Are you sure it not 12 amps instead of 2. Mine is 15 amps. I use the dewalt blades.
Mine vibrates a little, my SWAG is its the blade not the saw. If the disk that holds the blade were bigger, it would cut down the vibration.
I believe amps is like torque.
I should have multi quoted.
Who ever described the way to cut angle is the way I do it. If you notice when cutting flat stock ( 1/4" x2" lets say) , the saw will cut better with the piece upright and not flat.
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1983 CJ7
Unread 01-12-2012, 11:22 PM   #2260
Skerr
Bill
My saw is 2 Horsepower. Don't know the amperage, but it is unimpressive! I'll have to check it out
I'm looking for some 4 1/2" ID steel pipe. I need about 6" of it. Anybody have any ideas??
Kerrdog
Go Fish! <*////><
Unread 01-13-2012, 05:21 AM   #2261
lucdog
lucdog's Avatar
1980 CJ5
Whoops, I missed the reading comprehension 101 class. Haha, most of spelling also.
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1983 CJ7
Unread 01-13-2012, 07:40 AM   #2262
gmakra
Ok all you electrical neophites. Electricity has three basic measurements volts, amps and resistance.Most of the other terms you hear are combinations of these three. (there is more to it, but I am trying to keep it simple)
Volts is the velocity of the electricity think of it as water pressure.
Amps is the volume of electrons think of gallons per minute.
Resistance is friction.
Power (watts)is the total comsumption of electricity. To give you an idea of what I am talking about lets use a gallon of water. What we are going to do is fill a one gallon container. Now you can use tea spoons of water or pints, quarts any any size measuring device or combination of measuring devices as long as you fill this container to one gallon.
So power (watts) is overall consumption. One horsepower of electricty is 746 watts. It does not matter what voltage nor anything else. Its like a gallon of water its a contsant and to show you this I will show you a couple of simple formulas.
Power
divide
Current(amps) multiply volts
This is how you work the formula to find a missing value. If you multiply amps X volts it will give you power. If you know the power but are missing the amps you then divide volts into power.
Take a 1400 watt blow drier and you want to know how mamy amps it draws you would divide 120 volts into 1400 watts and you will come up with 11.66666 Amps. And if you take that 1400 watt blow drier and divide it by 746 watts you will see that it comes up with 1.8766 horsepower.
Now wire size can create resitance. You would not fight a forest fire with a garden hose since you wont get enough pressure or volume to really be effective. This also holds true with an extension cord, a long thin cord will create alot of resistance cutting down on voltage and amperage making your power tool sluggish it can also make your tool run hot which leads to insulation break down. A electric motor requires 7 time the run amperage to start. So if your toll runs at 10 amps it takes 70 amps to start.
So Scotty the up shot of all this is use a thicker extension cord your saw will probably run better. Also change the blade it sounds like a cheap one thats not balanced.
gmakra is offline   Reply With Quote Quick reply to this message
Unread 01-13-2012, 08:42 AM   #2263
rixcj
rixcj's Avatar
1979 CJ5
I have bought several metal cutting chopsaws over the years. Two of mine actually got stolen during the same burgulary. They were both Makitas, from the 80's-90's. Good saws.
There's a company called Enco Mfg. That sells tools, etc. Some of their stuff is just OK, some is just junk. They had a sale once, and they had 14" Enco brand chopsaws on sale for cheap money (like $79.00...). So, I bought one. It was SO BAD, that I went out and bought new brushes (right away), just to see if that made a difference. It didn't. That thing was so bad, it would just about cut a metal coathanger. It would just die as soon as the wheel touched the metal. I have no time for this. I threw it out.
When I bought my current chop saw, about 10 years ago, I really shopped around. I settled on another Makita that has a special feature that the others (back then, anyway) didn't have.
It had a spring loaded wheel/handle (the upper assembly). You can lock in piece of metal , hit the start trigger, then the whole upper assembly can be pulled toward the operator (it's under spring tension). As the wheel is lowered vertically onto the metal, the spring action also pulls the upper assembly (the wheel) horizontally into the metal.
I don't use this feature every time, but after a while, you learn when it's advantageous to do so. Good saw.
Rich
'79 CJ5, AMC 360, t-18/d20 twin stick, dana 30/amc20(Mosers), Edelbrock Performer intake, Holley 600, ps/pb, DUI HEI, 'glass tub/1pc. tilt nose, 33x12.50 BFG AT's.
There's a fine line between "hobby" and "mental illness".
rixcj is offline   Reply With Quote Quick reply to this message
Unread 01-13-2012, 10:58 AM   #2264
jatepper
I have the DeWalt metal cutting chop saw. Pretty good, but pricey! It is good for quick cuts. But in all honesty, I use my HF band saw the most. It amazingly cuts perfectly straight, every time. Bought it on sale and then used a 20% coupon, so I think I spent about $120. Best $120 I have spent in a while.
1985 Jeep CJ-7
Automatic-258 I6- Detroit lockers front/rear - Superior 1-piece axles, Ramsey Pro 9000 Winch, Quick Disconnects, 33 BFG AT's, 4.10 gears, Howell TBI, DUI HEI Ignition, Ground Pounder Rear Bumper / Tire Carrier Combo, Handen Fab integrated winch plate front bumper w/hoop, ORF weld-in front sport cage.
USMC 1999-2004 Semper Fi!
Hood Hi-Lift Jack Mounts for CJ/YJ/TJ/JK
Torchmate CNC Plasma Table Build / Projects
The Target Man, LLC - AR500 Shooting Targets
jatepper is offline   Reply With Quote Quick reply to this message
Unread 01-13-2012, 01:06 PM   #2265
rixcj
rixcj's Avatar
1979 CJ5
I agree...a decent horizontal metal cutting bandsaw is much better than a chop saw. I have a pretty nice bandsaw, and cut most of my metal on that, if I want a nice "cut edge". If it's too critical, I'll use my ironworker. It'll shear 5/8" thick plate 14" wide, and can cut 4" x 4" x 3/8" angle iron.
Rich
1979 , cj5 , fiberglass , rollcage , tailgate
