Clay's Build Thread - Page 111 - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Clay's Build Thread
Only 2 Days left to win $3,800 Jeep Parts!Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineAttention seahawks fans!!! Want to save some $$$ ??!!
Unread 09-05-2011, 07:40 AM   #1651
rixcj
rixcj's Avatar
1979 CJ5
Originally Posted by Skerr View Post
The tub mount locations (the factory holes for the body bushings) on our crossmember are flat along with the surface of the Xmember. The protrusions on the tub are probably there for reinforcement, and not for body mounts, when it comes down to it. But the holes in the Xmember are not located beneath the protrusions, they are off to the side by several inches. The 2X4 would solve that if I was convinced it would be strong and durable. I just have to make a decision about it. The steel straps would be the simplest thing to do, but I'm more comforatble with the glass. Are the protrusions on your tub large enough to completely support a bushing?
You're right...they probably aren't meant to be used as mounts. I looked at mine, again, and they definitely are not in the stock mount locations. The rubber mounts that were made by the PO were carved to fit the on the surface of the protrusions. Seeing that they've been this way for years, I'll leave them there.
Rich
'79 CJ5, AMC 360, t-18/d20 twin stick, dana 30/amc20(Mosers), Edelbrock Performer intake, Holley 600, ps/pb, DUI HEI, 'glass tub/1pc. tilt nose, 33x12.50 BFG AT's.
There's a fine line between "hobby" and "mental illness".
rixcj is offline   Reply With Quote Quick reply to this message
Unread 09-05-2011, 01:33 PM   #1652
Skerr
Skerr's Avatar
Rich
Praise God... you're a WISE MAN Rich!!
"If it ain't broke... don't fix it..."
Kerrdog
Go Fish! <*////><
Skerr is offline   Reply With Quote Quick reply to this message
Unread 09-05-2011, 01:42 PM   #1653
Skerr
Skerr's Avatar
Must............ have........... energy............ transfusion........... ugghhhh
Dang, I'm tired! Been working all day on the tub. Got some blocks glassed in yesterday evening for the rear Xmember tub mounts.
So far today, I have DuraGlassed holes, spots, and ugly! Sanded the underside down with some 80 grit, washed it down with Castrol Super Clean and a stiff brush, let it dry in the sun (between rain squalls!), shot it with HB primer, and finished it with Valspar Satin Black Implement paint. I don't ever, ever, ever, ever, ever, ever, ever, ever, EVER want to see the underside of that tub again! We'll mount it up tonight so Paw-in-Law can see what it's going to look like, and we'll (me and Clay) finish the rest of the body work with it on the frame.
Do you really understand just how good this feels?
Of course you do!
Kerrdog
Go Fish! <*////><
Unread 09-05-2011, 02:38 PM   #1654
rixcj
rixcj's Avatar
1979 CJ5
That looks awsome! I think that anyone who restores a jeep, with any amount of passion , can appreciate this momentious occasion that you're celebrating. It's another long, painful step of the restoration that is behind you. That has got to be the beefiest tub on the planet!
Rich
Unread 09-05-2011, 03:38 PM   #1655
Jim1611
Jim1611's Avatar
I like it....allot!! Very well done.
www.crabtreetool.com (Crabtree Shackle Hangers)
My build thread
http://www.jeepforum.com/forum/f8/ji...build-1093702/
Jim1611 is offline   Reply With Quote Quick reply to this message
Unread 09-05-2011, 07:57 PM   #1656
Skerr
Skerr's Avatar
Rich
Thanks Rich and Jim.
I wanted to get the tub on the frame tonight and bolt it down, but it ain't happenin'! I forgot about installing the gas tank (idiot!). So, I mocked up the tank, drilled the holes in the extended bracket that Clay welded, wire-wheeled it, Marine Cleaned it, primed it, and... I'm out of black rattle-can!! And Wifey stopped at WallyWorld to pick up some more Lacquer Thinner for me. Communication, communication, communication! It's important at work AND IT'S IMPORTANT AT HOME!! So the tub doesn't go on until I get the black paint. Maybe tomorrow...
Kerrdog
Go Fish! <*////><
Unread 09-05-2011, 08:10 PM   #1657
Jim1611
Jim1611's Avatar
Even if you didn't get the tub on today you still made some mega progress.
My build thread
Unread 09-18-2011, 10:16 PM   #1658
Splinter
1980 CJ5
Splinter is offline   Reply With Quote Quick reply to this message
Unread 09-18-2011, 11:37 PM   #1659
Skerr
Skerr's Avatar
Originally Posted by Splinter View Post
Thanks for snooping around, Don! I'm off through Wednesday so I hope to get SOMETHING done. Working on lowering the tranny right now... making some spacers to go between the tranny skid and frame. Should have them painted tomorow... BUT, bow season opened this past Saturday, and I obviously don't have my priorities right!!
Kerrdog
Go Fish! <*////><
Unread 09-19-2011, 05:35 AM   #1660
243
1978 FSJ Cherokee
Looking good guys, when do you hope to have it on the road?
1978 Cherokee, 360/T400/QT...5.3/4L60E/NP241C in the works...
243 is offline   Reply With Quote Quick reply to this message
Unread 09-19-2011, 08:14 AM   #1661
Skerr
Skerr's Avatar
If everything goes according to plan, we should have it on the road last year!
IDK, Dave... Clay says 6 mos, I think 2 mos. I don't know what would stop us. My mind says it should go together fast now, and I can't figure any reason why it shouldn't, BUT... you know how it goes!
I'm going to pick up some bulk tubing and bend my own brake lines and fuel return. AJ says he'll help and he has the flaring tool. That's the only thing keeping the tub off right now. Should be able to send Wifey out for a Jeep run today. Here's hoping...
Kerrdog
Go Fish! <*////><
Unread 09-19-2011, 12:28 PM   #1662
SonicR1
Lovin it!!! There should be some amazing progress since you are off till wednesday!!! No pressure…
[COLOR="Red"]... I guess I'm gonna have to fix that too…….[/COLOR]
[URL="http://www.jeepforum.com/forum/f9/sonics-05-tj-build-1168663/#post10985489"][COLOR="yellow"]The TJ[/COLOR][/URL]
2005 Wrangler X 4.0/6 speed, Dana 30/Ford 8.8--4.88--Eaton E-Lockers, 35" MT/R, Smittybilt bumpers/rockers/winch, SonicFab tire carrier, RE 3.5 springs, Zone 1.25 BL, FullTraction 3 link upper rear, RE super flex lower rears, UCF ultra high skid and lo/pro mount, brown dog mml.
[URL="http://www.jeepforum.com/forum/f8/sonics-74-cj5-build-1106795/"][COLOR="DarkOrange"]1974 CJ5 BUILD THREAD[/COLOR][/URL]
SonicR1 is offline   Reply With Quote Quick reply to this message
Unread 09-19-2011, 12:54 PM   #1663
Skerr
Skerr's Avatar
GEEEEZ! I was thinking about you, and you SHOW UP! That's awesome!! How ya doing Bill??
Wifey is on the way home right now... has all my goodies. I learnt that bulk brake line is a 6' stick. I thought it was a spool!? Auto Zone had the sticks I need with the fittings, so no flaring. I got the rear brake line from prop valve to axle, and one short one to fit along the rear axle (an 18" piece instead of the 30" piece that was on there). I also got a 1/4" stick for a return line with the rubber fuel line to make the connection to the tank, and a 3/8(?) for the supply, also with the rubber fuel line. Everything for about $50. Now, if my wife was accurate (and she's done this enough over the years that I believe she is), and this goes as expected, it beats the heck out of $100 for a single, factory return line!
Should I go to the deer stand, or should I work on the Jeep!? Hmmmm...
Kerrdog
Go Fish! <*////><
Unread 09-19-2011, 02:06 PM   #1664
Jim1611
Jim1611's Avatar
Sounds like you're going to the deer stand to me. Since you're over 50 be careful sittin out there and don't fall aspleep, you might fall over and hurt yourself. Oh yea don't choke on anymore sody either, man there's allot to be careful of for you old guys.
My build thread
Unread 09-19-2011, 03:37 PM   #1665
Skerr
Skerr's Avatar
With friends like you who needs enemies!? Talk about old... now that you're 50 you're probably going to fall asleep while wheeling!! You'd better have a 6 point harness so you don't fall out of the Jeep!!
Wifey showed up with all of the parts! She is s-o-o-o-o good! My only problem is.... me! I didn't get ENOUGH parts! She is going back tomorrow to get the balance of stuff I need to complete the installation. Here's a couple of pics showing what I am doing. The new line is very easy to bend by hand. You DON'T need a bender, just don't get in a hurry! Parts are from AZ, ranging from $4 to $8. I need to go a little longer on the fuel supply and return lines, and I need a little longer piece on the brake line. The sticks are 6' lengths. I'll give some more details as I go tomorrow afternoon.
Part numbers are blurry because I basically stink at photography! Also, I tore off the part number for the 6' long 3/16" stick without thinking about posting part numbers. Sorry about that!
Kerrdog
Go Fish! <*////><
1979 , cj5 , fiberglass , rollcage , tailgate
