Clay's Build Thread - Page 10 - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Clay's Build Thread
Rancho rockGEAR promotion gear from January 1-February 29,Zone Offroad Body and Suspension Lift Kits, Brackets, DiscJeep Wrangler Framless, Bowless, Trektops 92-95 YJ, 97-06
Unread 07-18-2010, 09:30 PM   #136
Coiz
1979 CJ7
The frame does look good. Shouldn't have to worry about that again.
Mike
My build thread
Coiz is offline   Reply With Quote Quick reply to this message
Unread 07-18-2010, 09:51 PM   #137
Skerr
Originally Posted by Ken4444 View Post
Looking great! Can you summarize all the steps you did on the frame from start to finish, with a one sentence explanation for each step (if needed)? Also include the inside of the frame.
Start to finish for the frame... hmmm. When I think about it now it was/should of been easy! The one thing that seems to be common amongst everybody is the wirewheel. Some method of stripping the rust. After that, there are several ways to do it, depending on what material you use.
With a "clean" frame (rust free) you can apply the POR15 kit, including the Marine Clean, Metal Ready, then POR. Too many guys have used it with success to ignore it. -OR-
With a clean frame (rust free), apply Ospho (which I think is inherrently the same thing as Metal Ready) and let cure. Wipe down with a prepaint solvent (degreaser/dewaxer), scuff with Scotch-Brite, blow it off with air, apply Lacquer Primer. Let dry. Wipe down with solvent again, scuff again, and paint with finish coat.
The main thing AJ pointed out to me was keeping the wet edge, which I have read from others as well. So I held the gun closer and moved slower. The lacquer primer is very thin, but it didn't run because it dries very quickly. He also emphasized about scuffing between coats. When I failed the first time with the bedliner I can tell you now where I screwed up. I didn't scuff between coats, and the bedliner went on dry.
Sorry... wasn't exactly one-liners!
Originally Posted by 243 View Post
Sure did, and I wasn't planning to bring it up but since you asked, it was hotter in Texas today
The frame looks great and I have heard very good comments about the Valspar implement paint.
EVERYTHING's bigger in Texas!! I have painted two stock trailers with Valspar. It covers really well and makes a good coating. It is $12 a QT, but $30 a gallon, so I bought a gallon. I cut it 20% with Naphtha (per the label)... really went on smooth. Took about 24 ounces to paint the frame.
Kerrdog
Go Fish! <*////><
Skerr is offline   Reply With Quote Quick reply to this message
Unread 07-18-2010, 09:58 PM   #138
Skerr
Oh Thank God! I can't believe how long it has been waiting for repair, and I can't believe how much trouble I personally had with it. Supposed to start bolting suff together tomorrow, but I forgot about the inside of the frame. I will probably do as Dave has done, tape off holes and dump some Rustoleum inside. To top it off, my son turns 11 tomorrow and Mom has reminded me that I have BD to attend! So probably no Jeep tomorrow.
Thanks for the nice words Mike.
Kerrdog
Go Fish! <*////><
Unread 07-18-2010, 10:16 PM   #139
243
1978 FSJ Cherokee
Scott, I would not do that now, the primer will find a way out of the frame rails and spoil a nice looking black paint job. There are a ton of holes to tape, there are cracks where the factory welds were not complete, and even if you completely sealed it, you would see the primer coating the edges of all the holes.
1978 Cherokee, 360/T400/QT...5.3/4L60E/NP241C in the works...
243 is offline   Reply With Quote Quick reply to this message
Unread 07-19-2010, 04:53 AM   #140
Exposed
Exposed's Avatar
1981 CJ5
Skerr, frame is looking great..... Now the fun starts putting it all back together....
Calvin
Follow My CJ5 Build
81 CJ5, Ford 331 EFI, AX15, D-300, Dana 44 (Detroit Locker)....
When there are more people voting for a living than working for a living,
We are DONE as a Country!!!!!!
Newly Acquired 2014 Grand Cherokee Summit
Exposed is offline   Reply With Quote Quick reply to this message
Unread 07-19-2010, 05:52 AM   #141
Skerr
Story of my life... a day late and a dollar short!
Thanks Calvin. I am defnitely looking forward to that and the sensation of moving forward, ALSO some new floor space in the shop!
Kerrdog
Go Fish! <*////><
Unread 07-20-2010, 09:11 AM   #142
Jim1611
Jim1611's Avatar
Very good job on painting the frame Scott!! I'm not sure I'd try priming the inside either. It ought to last a long time with what you have. Besides I've noticed that striving for perfection can tend to drive you nuts.
www.crabtreetool.com (Crabtree Shackle Hangers)
My build thread
http://www.jeepforum.com/forum/f8/ji...build-1093702/
Jim1611 is offline   Reply With Quote Quick reply to this message
Unread 07-20-2010, 09:55 AM   #143
Trimble1
1983 CJ5
Great job, keep up the nice photo diary for us.
'83 CJ5 4.2L D30 AMC20 D300
Stinking 2.73's 31" BFG's MC2100
Trimble1 is offline   Reply With Quote Quick reply to this message
Unread 07-20-2010, 12:58 PM   #144
243
1978 FSJ Cherokee
Originally Posted by Skerr View Post
Today is not going as planned. I am aggravated! Clay won't focus. Mom is cranky. And I'm not on schedule. It is so hot and humid. My water separator won't keep up with the compressor. I can't shoot paint when the air is not dry. It's fixin' to rain and I have to paint what has been sandblasted. My break is over. Why didn't I use the dadgonfriggindurnblasted POR-15 like I planned!? Pray for me!
Scott,
I added a 50' 3/4" copper pipe cooling loop in the garage and I am sandblasting and spraying paint and primer without a water separater. I do have a filter but I have had "0" issues with water and will definitely add a separator before spraying the color coats.
I used these infomation on the linked websites below and the diagram as a guide:
http://www.sharpe1.com/sharpe/sharpe.nsf/Page/Air+Piping+Layout
http://www.tptools.com/StaticText/airline-piping-diagram.pdf
Unread 07-22-2010, 03:54 PM   #145
Skerr
FAIL!!!!
Details after I feel better! Too much woe...
Kerrdog
Go Fish! <*////><
Unread 07-22-2010, 04:07 PM   #146
Exposed
Exposed's Avatar
1981 CJ5
THis does not sound good without explanation....
Calvin
Follow My CJ5 Build
Unread 07-22-2010, 05:09 PM   #147
VACJ7
Hockey Rules!
VACJ7's Avatar
Oh no! I was enjoying the progress to date. Hopefully it is just a minor setback.
VACJ7 is offline   Reply With Quote Quick reply to this message
Unread 07-22-2010, 09:31 PM   #148
Ken4444
Corripe Cervisiam
Ken4444's Avatar
FAIL!!!!
What doesn't kill us only makes us stronger, right? If rebuilding a CJ was so easy then the reward would be much less
"I give you a republic, if you can keep it." - Benjamin Franklin
Ken4444 is offline   Reply With Quote Quick reply to this message
Unread 07-22-2010, 09:37 PM   #149
Skerr
Scott,
That looks like a good layout. AJ gave me some input when I was plumbing mine. It's not the same, but it's pretty close. My water separator may not be large enough. I can actually see the water running into it. I have my tank cracked so water can drip out steadily. It cuits down some on the amount that accumulates in the lines. I also have a drain/catch leg at the end of the line, and when you crack the valve to drain it, it blows water across the shop! Temp today was 96* with 93% humidity! A miserable day.
Kerrdog
Go Fish! <*////><
Unread 07-22-2010, 10:05 PM   #150
Skerr
Hey Calvin... it wasn't good and my mental state plummeted! It still isn't great, but it has stabilized!
I'm sure there are plenty that have greater problems than I am facing. I am just so ready to MOVE ON! And my problems have changed!
Ken, Thanks for the inspiration. I needed that. It helps...
My paint has not cured. It is still "soft". Soft enough to scrape it off with my fingernail. AJ made it clear that I had to scuff the primer coat before I painted the finish coat. I did that, but I was concerned that maybe I didn't do it well enough. AJ came over today to check it out. He said the humidity is causing the problem and not to worry about it. He scraped off a spot and said it had adhered to the primer just fine. So I sanded down the test spot and painted that area again. But he did give me a lecture about using tractor paint on an automobile! He is definitely old school! Which I happen to like, but I get impatient, and that is not the way to be with this kind of detail. AJ said I could go ahead and start reassembling carefully. So Clay and I got out there tonight and started putting the rear springs and axle back on. I fought with the shackles (aftermarket) and bushings, got "never seize" all over me (which I just hate), and finally got the spring plates bolted up. Once we finished it was obvious that the axle is not straight in the frame. The left side is kicked forward a bit, causing the left rear wheel to be at an angle to the frame. Hownthhell can that happen!? I studied it and studied it, but I'm not smart enough to figure it out. I measured from different reference points and the measurements are the same... so what gives? I am disgusted! BTW, the the spring perches, plates, and springs are aligned properly, and the bolt is in the hole. Gonna have to get AJ back. Side note- Clay and I had this all assembled once (with no issues) and he took it all apart to paint the axle. Kudos for the initiative of my son. He placed all the nuts, bolts, and washers in a magnetic parts tray, and then he placed the tray under the axle on the floor. When I went to get them to bolt things together, I noticed the tray was full of oil... 90 weight! So I asked Clay why he filled the tray with oil, and he told me that he didn't! He had left the axle with the diff hanging down, and the oil drained around the pinion seal!! Just by luck it went into the pan and not all over the floor. I'm so glad my pinion seal leaks like a sieve... I was afraid I was running out of things to do!
Today was my 21st anniversary. I spent the day at work and the evening on the Jeep. Gonna have to get my priorities straight!
Kerrdog
Go Fish! <*////><
1979 , cj5 , fiberglass , rollcage , tailgate
