Clay's Build Thread - Page 45 - JeepForum.com
 48Likes
post #661 of 5466 Old 11-06-2010, 03:25 PM
SonicR1
Prime and paint unless you have some spots you want to smooth out.
... I guess I'm gonna have to fix that too…….
2005 Wrangler X 4.0/6 speed, Dana 30/Ford 8.8--4.88--Eaton E-Lockers, 35" MT/R, Smittybilt bumpers/rockers/winch, SonicFab tire carrier, RE 3.5 springs, Zone 1.25 BL, FullTraction 3 link upper rear, RE super flex lower rears, UCF ultra high skid and lo/pro mount, brown dog mml.
SonicR1 is offline
post #662 of 5466 Old 11-06-2010, 03:37 PM
FamillyCJ7
1983 CJ7
Originally Posted by Skerr View Post
Clay started working on his dash today. He stripped the few gauges and started wire-wheeling it. It has a few "bumps" in it to knock out, and a little surface rust on the backside, but that's about it. He has new gauges coming for Christmas (he doesn't know about them- from Meemaw and Papa), so he needs to get it ready.
Do we need to apply a filler to the dash or just prime and paint?
Thanks
With sheet meal it could look nice and straight until you put paint on it and then the "waves" come out. I would apply a skim coat of filler once the high spots are knocked down and sand it smooth.
'83 CJ7 258I6 4-Speed Father Daughter Project - Using Monstaliner/Chassis Saver and Products from CrabTreeTool
NorthEastFL4x4.com - Local 4x4 Enthusiasts website, join up now!
FamillyCJ7 is offline
post #663 of 5466 Old 11-06-2010, 06:47 PM Thread Starter
Skerr
Clay got it finished and it was dark when i got out of the woods, I'll check it out tomorrow. We may have to go with a skim coat.
Kerrdog
Go Fish! <*////><
Skerr is offline
post #664 of 5466 Old 11-06-2010, 07:02 PM Thread Starter
Skerr
What about this? It's a little smaller than the HF, but I bet it continues to operate.
Ingersoll Rand Dual-Piston Straight-Line Sander - TP Tools & Equipment
Kerrdog
Go Fish! <*////><
Skerr is offline
post #665 of 5466 Old 11-06-2010, 07:06 PM
benullman
1981 CJ7
this ones a little cheaper:
TP Tools&#174; ProLine Straight-Line Sander - TP Tools & Equipment
TP tools makes good stuff. Its what I am going to be ordering as my 'personal' Xmas gift. A nice set of air tools.
Ben
benullman is offline
post #666 of 5466 Old 11-06-2010, 07:16 PM
FamillyCJ7
1983 CJ7
Ingersoll Rand makes quality products, you won't be disappointed.
post #667 of 5466 Old 11-06-2010, 07:26 PM
benullman
1981 CJ7
I agree completely. I just wanted to show him a little cheaper alternative. If I had the $$ i would buy IR EVERYTHING. they got good stuff!
Ben
post #668 of 5466 Old 11-06-2010, 09:24 PM Thread Starter
Skerr
TP Tools® ProLine Straight-Line Sander - TP Tools & Equipment
Ben
Man I hate to say it, but that one looks EXACTLY like the one I turned into a boat anchor! Notice the last 4 words of the description... imported for TP Tools. All the specs are identical.
Kerrdog
Go Fish! <*////><
Skerr is offline
post #669 of 5466 Old 11-07-2010, 05:11 AM
gmakra
Clay you continue to shoot yourself in the foot with a AK47 in full auto and reloading several times.Get the Ingersol Rand 8 inch gear driven DA Sander also known as a Mug Hog with 40 grit paper. That will calm your seas down quite a bit. Its much faster than a air file and is less likely to give you waves. Then hit the panel with your Dura Block sanding blocks, otherwise you are really making things much harder on yourself.
Ingersoll Rand Heavy Duty Air Geared Orbital Sander with 8 Inch Pad, Model 328
Dura-Block&#174; Sanding Blocks - TP Tools & Equipment
gmakra is offline
post #670 of 5466 Old 11-07-2010, 06:06 AM
243
1978 FSJ Cherokee
I would agree Scott, a good quality DA would be far more useful than an air file.
Dave's 78 Build
243 is offline
post #671 of 5466 Old 11-07-2010, 07:13 AM
gmakra
243 Actually my name is George but Ill answer to any pronoun or adjective.
gmakra is offline
post #672 of 5466 Old 11-07-2010, 08:31 AM
benullman
1981 CJ7
post #673 of 5466 Old 11-07-2010, 08:37 AM
243
1978 FSJ Cherokee
I will call you George except when I am agreeing with you and talking to Scott
Dave's 78 Build
243 is offline
post #674 of 5466 Old 11-07-2010, 08:52 AM Thread Starter
Skerr
Dura-Block® Sanding Blocks - TP Tools & Equipment
OWWWWWW! You would use the DA over surfaces with curves, or on flat surfaces onnly?
I already have one, but I was worried that I would remove TOO MUCH material, causing valleys. What PSI do you guys recommend?
"I will hold him and pet him and I will call him George!"
I will call you George except when I am agreeing with and talking to Scott
George... I'm Scott, the guy that does the posting. Clay is my son who actually owns the Jeep (I gave it to him), and Dave is one of my Texas connections!
Kerrdog
Go Fish! <*////><
Skerr is offline
post #675 of 5466 Old 11-07-2010, 09:08 AM
benullman
1981 CJ7
Scott, the DA is used on pretty much everywhere. I set mine at 100 PSI (8cfm) andI vary the speed with the actual lever. Just feel it out you will get used to it.
Ben
1979 , cj5 , fiberglass , rollcage , tailgate
19?? CJ7 build thread biker250 Jeep CJ Forum 96 12-27-2010 06:10 AM
Looking for a CJ Build Thread. jsc7002 Jeep CJ Forum 6 08-22-2009 10:47 AM
High 5 Build Thread... 1Rustycj5 Jeep CJ Forum 7 03-22-2009 09:28 PM
Build Thread for my '84 CJ erik5387 Jeep CJ Forum 19 05-29-2008 01:05 PM
