Clay's Build Thread - Page 356 - JeepForum.com
 48Likes
post #5326 of 5466 Old 02-27-2014, 05:52 AM
Mike Romain
Not reading 500+ pages....
That said, air in the oil line will make the gauge bounce. I bleed mine at the back of the gauge by loosening the fitting while running.
Hotter temps = thinner oil normally.
Is the engine head grounded to the firewall by a steel mesh cable like the stock setup is? A bad ground path can affect the temp gauge readings. Even Teflon tape on the threads can mess with it. If you need a thread lubricant to get it in tight, think liquid plumbing 'dope'. (Teflon tape is just a lubricant so things can tighten easier, not a sealant)
The readings for #1 likely mean worn rings. To check, add a tablespoon of oil to the spark plug hole and check again. If the compression comes up, it is rings, if not, then valves or head gasket.
Oh, the PCV controls engine sludge, it will fill up with crud fast without one. It is also part of the fuel mix equation because it is a needed controlled vacuum leak.
Mike
Mike Romain is offline
post #5327 of 5466 Old 02-27-2014, 06:20 AM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
Scott,
Does Clay have breathers on his valve cover, at least? The crankcase pressure has to go somewhere. It's not necessary to suck those vapors back thru the intake, but doing so keeps the engine compartment much cleaner.
I agree with John, it sounds like there's air in the oil gauge's line.
Matt
Matt1981CJ7 is offline
post #5328 of 5466 Old 02-27-2014, 07:21 AM
lucdog
lucdog's Avatar
1980 CJ5
At what point is the engine appear to be running hot? While stopped at a stop light, or while driving down the road? What does the temp gauge show when the IR shows 200*?
I agree with bleeding the air from the oil gauge line.
No fan shroud, correct?
I don't have a lot of faith in cheap gauges.
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7
1989 YJ the CJ to YJ.
lucdog is offline
post #5329 of 5466 Old 02-27-2014, 07:56 AM
Matt1981CJ7
1981 CJ7
Mechanical fan with clutch? If so, you might check the clutch.
A shroud made a 10-15* difference on my 360, according to my IR thermometer.
Matt
post #5330 of 5466 Old 02-27-2014, 01:24 PM
mikeyboat
1979 CJ7
Glad to see this active again. Can't offer any suggestions on your current problems, but I'm pretty confident yall will get it figured out. Keep it up gentlemen, you've done a great job!
mikeyboat is offline
post #5331 of 5466 Old 02-27-2014, 06:13 PM Thread Starter
Skerr
HOLY CRAP!! MIKE ROMAIN!!! Good to hear from you Mike.
This is a glass tub, so I will provide a ground from the head to the dash/frame/batt. There is not one to the head presently. Also, will do the wet test on CYL 1. Thanks for the input.
Originally Posted by Matt1981CJ7 View Post
Scott,
Matt
No breather, per se, just an open hole, basically. It has the nipple that would attach to the tubing that went to the air filter in the factory air box. Keep in mind it is the 4.0. It is able to vent, but nothing pulling on the crankcase.
Bill
Clay called me twice on his way home from school last night. He said he was having issues while driving at 45 MPH... oil pressure changing and temps almost pegged on the temp gauge. I told him to pull off at a lighted area and shoot some temps with the IR reader. It was 200 at the Tstat. I told him as long as the engine sounded good to bring it on home.
I drove it to work today. True, the temp gauge is pegging (second gauge, first one did the same thing). Pegging is around 280*.
Oil pressure at 50 MPH was 50 PSI. That's very good. Pressure dropped when I slowed, as you would expect. Oil pressure never exceeded 60 PSI and pretty much stayed at 50. I think I need to educate Clay a little more! There was no eradic fluctuation.
Matt
We don't have a shroud for the mechanical fan, and it is offset as on a 4.0. But he also has the electric fan. Turning on the electric fan with the manual switch does not cause temps to decrease. I need to give this more attention over the weekend. Clay is out of town, so I can bang on his Jeep for a couple days!!
Glad to have you aboard!! I know we'll figure it out. I'm thinking it isn't as serious as my son makes it sound. I'm more concerned with low pressure on cylinder 1.
Kerrdog
Go Fish! <*////><
Skerr is offline
post #5332 of 5466 Old 03-01-2014, 06:04 PM Thread Starter
Skerr
I think temps are okay. It is backfiring however. That should be a timing indicator??
Kerrdog
Go Fish! <*////><
Skerr is offline
post #5333 of 5466 Old 03-04-2014, 09:44 AM
Cutlass327
1978 CJ5
Mike! Glad to see you returned!! How are thing your way? Been many times I've wondered how you've been, hated hearing you signed off..
OK, back on topic
I was originally thinking how higher temps would mean lower oil psi, but now it seems you have figured out they are 2 separate issues. That is also a reason most gauges on newer cars are "idiot gauges", where they are basically like a light, on or off, no actual variation.
Have you considered a mechanical temp gauge? Maybe not for permanent use but just to run while sorting things out.
Rick
Cutlass327 is offline
post #5334 of 5466 Old 03-04-2014, 12:14 PM
Mike Romain
OK, back on topic
I moved out to the bush with no internet connection. Have to use a cell phone and finally got one I could type on. Lol. Got stuck with a 3 year contract and itty bitty keys.
Mike
post #5335 of 5466 Old 03-04-2014, 06:03 PM Thread Starter
Skerr
OK, back on topic
This block and head have no port for a mechanical temp gauge. It was done by the computer, originally. There is a boss on the head I can drill and tap, but I'm intimidated by it... although SLO-ken shows how to do it on his thread.
Since you a have 3 year contract, and you're done splitting wood, I guess you have nothing better to do!?!?
I have been reading up on backfiring through the TB. Since you can't adjust timing with the dizzy what are other causes that would cause this? I have read low fuel pressure, dirty TB, bad knock sensor (but we don't have one), bad EGR (again, don't have one), and maybe dirt injectors???
I DO have positive ventilation at the crankcase. There is a direct vacuum from the intake to the valve cover, just no PCV in place.
Kerrdog
Go Fish! <*////><
Skerr is offline
post #5336 of 5466 Old 03-04-2014, 07:26 PM
243
1978 FSJ Cherokee
Scott, if you are talking about a location for a temp sensor on the 4.0, you can put a water neck on it with a port for the sender. I did this for my TBI conversion, I posted photos on my build thread.....wait, nevermind
Like this...
243 is offline
post #5337 of 5466 Old 03-04-2014, 07:26 PM
EgulAye
1980 CJ5
Is the temp sensor in the thermostat housing on the 4.0L?
2012 JK
Do you wave at night when they can't see you?
EgulAye is offline
post #5338 of 5466 Old 03-04-2014, 07:27 PM
SLO_Ken
It's nothing to be intimidated by... although it is a lot easier to get at when the engine's on a stand.
California 4.0 OBDII Engine Swap
http://www.jeepforum.com/forum/f8/california-4-0-obdii-swap-1530716/
SLO_Ken is offline
post #5339 of 5466 Old 03-04-2014, 07:37 PM
243
1978 FSJ Cherokee
If you need two sensors...
243 is offline
post #5340 of 5466 Old 03-04-2014, 08:43 PM Thread Starter
Skerr
Like this...
Was that a standard 4.0 housing, Dave? Now that you mention it, I DO seem to remember reading about that conversion on your ghost thread! Have to re-look at it to see if it has the same two bosses as yours does.
There were two on some 4.0s. Try-i-n-g t-o re-mem-ber! I think the OBDII had 2 sensors, and the OBDI had only 1, in the T housing.
You are much inspiration Ken, but if I drill too deep, or off to the side, then my son needs a new head! Well... THAT being said, I don't want to have to fix his engine too!!
Hmmm... now you got me wondering... Thanks, Dave.
Kerrdog
Go Fish! <*////><
Skerr is offline
1979 , cj5 , fiberglass , rollcage , tailgate
19?? CJ7 build thread biker250 Jeep CJ Forum 96 12-27-2010 06:10 AM
Looking for a CJ Build Thread. jsc7002 Jeep CJ Forum 6 08-22-2009 10:47 AM
High 5 Build Thread... 1Rustycj5 Jeep CJ Forum 7 03-22-2009 09:28 PM
Build Thread for my '84 CJ erik5387 Jeep CJ Forum 19 05-29-2008 01:05 PM
