Clay's Build Thread - Page 352 - JeepForum.com
 48Likes
post #5266 of 5466 Old 09-19-2013, 08:35 PM Thread Starter
Skerr
Originally Posted by EgulAye View Post
It's great to see you got the Jeep running well. Did you ever pull the pistons or crank out of Clay's old block? I'm kinda wondering what they look like. I've been reading the thread a few pages a day since April this year. I've finally read every post. It's quite the saga you've recorded here. Nice work!
Wow, Egul... you're a glutton for punishment! I hope you found some entertainment value in it.
Clay's Jeep is running good. I offered to trade with him, but he isn't having any! His 4.0 is runnig rich, to the point that the exhaust burns your eyes. That seems to be the biggest issue. I will get it up to the shop I use and have them pull the codes. We have several JY sensors in the system.
Clay's old pistons looked ok, but they had so much carbon on the tops that it was flaking off. Cylinders were not alarming, but there was a nice lip at the top. Cam showed some wear. Crank looked okay. Lifters/pushrods looked alright overall. Nothing jumped out that indicated any problems. I sold the block to another Jeeper (a guy I work with) and he is having it built right now. I'm trying to get him to become active on JF.
Kerrdog
Go Fish! <*////><
Skerr is offline
post #5267 of 5466 Old 09-20-2013, 05:04 AM
gmakra
Skipper are you running a cat on Clays Jeep?
The only other thing I can think of is the fuel pressure is to high and you dont have a fuel pressure regulator hooked up or its set at the wrong pressure.
gmakra is offline
post #5268 of 5466 Old 09-20-2013, 07:05 AM Thread Starter
Skerr
Professor- no cat. The pressure reg is new and factory, on the rail. I haven't tested it yet, however. I will do that and post.
Kerrdog
Go Fish! <*////><
Skerr is offline
post #5269 of 5466 Old 09-21-2013, 04:23 PM Thread Starter
Skerr
Fuel pressure is 40# pressurized by the pump. With engine running it is 30.5#. I think everything is as it should be. But the exhaust is very rich.
Kerrdog
Go Fish! <*////><
Skerr is offline
post #5270 of 5466 Old 09-22-2013, 07:34 AM
gmakra
Where is your O-2 sensor located?
And I am thinking a Cat would help alot even if you got one from a junkyard.
gmakra is offline
post #5271 of 5466 Old 09-22-2013, 02:47 PM Thread Starter
Skerr
O2 sensor is just downstream from the header. OBDI did not have a sensor downstream from the cat.
Kerrdog
Go Fish! <*////><
Skerr is offline
post #5272 of 5466 Old 09-22-2013, 05:26 PM
gmakra
Skipper I know that OBD2 have pre and post cat O-2 sensors OBD only has the pre cat.
I wonder if the O-2 sensor is too far downstream to get a good signal, it has to get to 600 degrees to read correctly.
gmakra is offline
post #5273 of 5466 Old 09-22-2013, 05:42 PM
SLO_Ken
AFAIK, the O2 sensors in both the OBDI and OBDII setups are all heated. Their position in the exhaust pipe should not have a noticeable effect on their performance.
SLO_Ken is offline
post #5274 of 5466 Old 09-22-2013, 09:16 PM
TJ-Joe
IRRC, only 4-wire O2 sensors are heated - the two-wire are not. I thought heated O2 sensors on ODBI were only used for California models ...
TJ-Joe is offline
post #5275 of 5466 Old 09-23-2013, 01:11 PM
Cutlass327
1978 CJ5
3 or 4 wire sensors are heated, 3 are rarely used though. Single wire need to be pretty close to the manifold to work properly.
Rick
Cutlass327 is offline
post #5276 of 5466 Old 09-23-2013, 08:27 PM Thread Starter
Skerr
Well, shoot... I didn't know any of this! I have no idea if it is close enough or not. You can reach it bending over the fender.
Kerrdog
Go Fish! <*////><
Skerr is offline
post #5277 of 5466 Old 09-23-2013, 09:30 PM
VACJ7
VACJ7's Avatar
Is it a 2 or 4 wire O2 sensor? Could always buy a heated sensor.
'84 CJ-7 |
VACJ7 is offline
post #5278 of 5466 Old 09-23-2013, 10:34 PM
Kastraelie
1977 CJ7
Wow that's good to know
Building out a Jeep is like trying to smother a fire with twenty-dollar bills. You just never have enough at once to put it out...
Kastraelie is offline
post #5279 of 5466 Old 09-24-2013, 02:28 PM Thread Starter
Skerr
2, I think, Paul. I'll look into this. How do you connect a power source?
Kerrdog
Go Fish! <*////><
Skerr is offline
post #5280 of 5466 Old 09-24-2013, 04:10 PM
VACJ7
VACJ7's Avatar
I will have to look at mine. Assume it is hot-in-run and a ground for the extra 2 wires.
'84 CJ-7 |
VACJ7 is offline
1979 , cj5 , fiberglass , rollcage , tailgate
19?? CJ7 build thread biker250 Jeep CJ Forum 96 12-27-2010 06:10 AM
Looking for a CJ Build Thread. jsc7002 Jeep CJ Forum 6 08-22-2009 10:47 AM
High 5 Build Thread... 1Rustycj5 Jeep CJ Forum 7 03-22-2009 09:28 PM
Build Thread for my '84 CJ erik5387 Jeep CJ Forum 19 05-29-2008 01:05 PM
