Clay's Build Thread - Page 348 - JeepForum.com
 48Likes
post #5206 of 5466 Old 08-07-2013, 01:00 PM
lucdog
lucdog's Avatar
1980 CJ5
Dave, I'm just not following. The reason for moving the pivot point is for more movement of the TOB so it makes contact with the fingers of the pressure plate. I understand that. The problem I'm seeing is not enough room on the transmission bearing retainer, for the TOB to move any closer to the clutch.
Jim, a spacer might work, except for a way to keep it attached to the TOB. I couldn't be welded, that would boil all the grease out of the TOB, I wouldn't be Comfortable JB welding it on.
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7
1989 YJ the CJ to YJ.
lucdog is offline
post #5207 of 5466 Old 08-07-2013, 01:07 PM
243
1978 FSJ Cherokee
To all, this is a simple lever, why complicate the mechanism by introducing washers or spacers?
Post a picture of the backside of the fork with the TOB installed, because I am not seeing what you are.
It looks like the TOB is fully forward in this photo, did the bearing clips on the retainer come off the fork?
Dave's 78 Build
243 is offline
post #5208 of 5466 Old 08-07-2013, 01:22 PM
243
1978 FSJ Cherokee
I bet that putting the fork in a press and smashing the pocket flatter by 1/4" would move the other end of the fork close to 1", that may eliminate the need to relocate the pocket or use an adjustable ball stud.
Dave's 78 Build
243 is offline
post #5209 of 5466 Old 08-07-2013, 01:31 PM
lucdog
lucdog's Avatar
1980 CJ5
This is the Orientation.
Next picture is where the arm makes enough contact with the bell housing, where I feel enough pressure is put on the bell to cause the crack.
Also at this point the TOB isn't (Apparently) putting enough pressure on the pressure plate to Disengage the clutch.
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1983 CJ7
lucdog is offline
post #5210 of 5466 Old 08-07-2013, 01:41 PM
243
1978 FSJ Cherokee
I went to Novak's website and they list alternate TOB's with different lengths, I picked the 15/16" (1377C) for chits and giggles and it came up on Autozone's website. I am not sure if the part numbers are correct for Scott's application but it's worth talking about.
Same for 1697C at O'Reilly.
-A- Length-B- Overall LengthPart Numbers.625"1.185"N4008 -or- 614083 ($30) .750"1.216" N4068 -or- 614038 ($32) 1.235"N4109 -or- 614109 ($38) 21/32"1.246" N3068, N4172-or- 614018 ($32) 1.257"N1488 -or- CC1705C ($20) 1.410"N1451 -or- G1697C ($38) 15/16"1.609" 1377C ($26) 1-1/16"1.699" N1466 -or- G1625C ($53) 1.196"1.775"N1086 -or- 614037 ($36) 1.310"1.953"1697C ($26)
http://www.autozone.com/autozone/par...entifier=47647
http://www.oreillyauto.com/site/c/de...1330&ppt=C0015
Dave's 78 Build
243 is offline
post #5211 of 5466 Old 08-07-2013, 01:47 PM
lucdog
lucdog's Avatar
1980 CJ5
When looking at these 2 pictures, the first one, a wear pattern is seen.
This is were the TOB would be.
The arm, at this point isn't contacting the bell housing.
Between the face of the TOB, and the end of the bearing retainer it's 1/2". Wether or not that's enough, I don't know. All I have to go by is the reported bell crack, and where the arm need to be to cause one. At which point, the clutch is disengaging.
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1983 CJ7
lucdog is offline
post #5212 of 5466 Old 08-07-2013, 01:53 PM
243
1978 FSJ Cherokee
Nice coffee mug Bill
Dave's 78 Build
243 is offline
post #5213 of 5466 Old 08-07-2013, 02:01 PM
lucdog
lucdog's Avatar
1980 CJ5
Dave, the ID needs to match as well.
This is the arm and bearing not connected .
Notice the pins on the arm, and the hole on the TOB. I imagine these are to help keep the arm and TOB together.
This is the ID of the TOB.
So you can see why it's important to keep the TOB on the retainer ((tranny)
If the ID were like this, there wouldn't be a problem.
B
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1983 CJ7
lucdog is offline
post #5214 of 5466 Old 08-07-2013, 02:06 PM
243
1978 FSJ Cherokee
This points back to relocating the ball stud pocket to the location needed in both directions.
Dave's 78 Build
243 is offline
post #5215 of 5466 Old 08-07-2013, 02:34 PM
lucdog
lucdog's Avatar
1980 CJ5
If I were going to move the arm out, I would work only with the arm itself. I don't think the stand off ball area is strong enough. There are side pressures as well as pushing straight back.
Attachment 654864
I'm thinking cut the area from another arm, and weld it on top.
The hole/slot in the arm is Elongated to allow for in and out movement as the TOB slides back and forth.
B
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1983 CJ7
lucdog is offline
post #5216 of 5466 Old 08-07-2013, 02:43 PM
lucdog
lucdog's Avatar
1980 CJ5
This is real good possibility! I would try it , don't want to ruin my arm.
:-) bought the cup for a $.25 at a garage sale.
This is how pissed everyone should look....
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1983 CJ7
lucdog is offline
post #5217 of 5466 Old 08-07-2013, 03:24 PM Thread Starter
Skerr
WOW, Fellas! Thank you, Thank you, Thank you!! I don't know what to say to all of you. Please keep in mind that this is my first time getting into all of this, regardless of the fact I have done a frame-off. The mechanical aspects of Clay's Jeep were ignored (which I am now paying for), and it's VERY possible I have not done justice in my description of the problem. I have described it the best way that I understand it... up to now. I CAN tell you for fact that I made the call to Novak, and they DO, normally, carry the part I need, but they don't have it in stock at this time. I CAN tell you that I spoke to Auto Zone (my boss there- he is sharp), and he explained that AZ did NOT carry the part I needed. McLeod and Summit didn't have it, and neither did Advanced Adapters. This was all in terms of a longer TOB. Had I understood more, or had I known what to look for, or had I been sharper overall, I could possibly have come up with options rather than sending the Jeep to the shop. Dave's ideas make perfect sense to me. I just didn't think of any of it. With the breakage of the bellhousing flange I was in such a total funk I didn't even want to place my hands on the Jeep to push it back in the shop. I would have sold it for beans right there! I just wanted it fixed, and I didn't want to be the one to do it, thinking it would take hours and hours, ignoring my wife and kids, sweating in the shop after doing 9 hours at work, and further delaying the pay-off day. So I loaded it up and sent it away like the bastard child that it is. For all we have accomplished, I still don't fully understand how the clutch works. Bill called me at work today, and I wasn't able to concentrate on our call, and I had to hang up. I need a lesson on clutch operation. I understand the concept, but I don't know how all the parts interact. Bill's question of the TOB moving past the retainer is the first I've heard of this. With me looking at the clutch fork, and with me wriggling it back and forth while laying under the Jeep, I can say the TOB did not move at all, almost like there WAS NO pivot ball in place. But it was in place. Clay made a longer rod to take up that slop that suddenly appeared, and that's when the fork hit the bellhousing.
Warren found an adjustable ball stud. He will install it tomorrow. The bellhousing and ball stud tower will be TIG welded and gusseted. I don't see where the TOB is going to move out of its normal place with this method. This will simply move the fork closer to the bellcrank, allowing a stock-length rod and normal fork travel. Likely, the SAME result had I thought more about it and modified the pivot pocket on the fork.
More learning curve for me, and something to add to my eventual 4.0 swap thread that I plan to create.
Kerrdog
Go Fish! <*////><
Skerr is offline
post #5218 of 5466 Old 08-07-2013, 03:36 PM Thread Starter
Skerr
Matt- Our build has always been about doing the necessary work with the least possible expense. My labor is free, and I don't mind labor. It's also a concept that I want my children to learn. Anything worth having is worth working for. I know you already know that, so no criticism intended. That's just where I am and the lessons I am trying to teach. Through all of this there has been PLENTY of challenge and trial. It is my responsibility to keep a good frame of mind and attitude as an example to my boys. Sometimes that is very hard! The Hesco kit... here are my thoughts on Hesco. I have no idea about the company. I have no idea about the quality of their parts. Their CPS adapter is possibly worth every penny they ask. But it is over $300, and I can give a LOT of labor for $300. Since we had the bellhousing we elected to modify it. We COULD have sent it to Novak and had them modify it, and there wouldn't have been any guessing or stress. But overcoming adversity and obstacles is another important lesson for my kids. Clay modified the bellhousing on his own. And it worked! He had plenty of frustration, but he saw it through, and now he has a running engine. That is his reward. His first time, and with determination, he was successful. For thos Jeepers who simply buy what they need, well... kudos to them. Sometimes I wish I was in that position. But I also know that $300 will buy a truckload of mac-n-cheez! So the cost is too high for me, and I don't think the position of the CPS is a good one for wheeling. It is subject to debris and mud getting into that area. Hence, the REAL reason why we did our own work.
Kerrdog
Go Fish! <*////><
Skerr is offline
post #5219 of 5466 Old 08-07-2013, 03:37 PM Thread Starter
Skerr
Sorry about the phone call, Dave. Me and the boys were playing a match of Ghost Recon. We don't get to do that much anymore...
Kerrdog
Go Fish! <*////><
Skerr is offline
post #5220 of 5466 Old 08-07-2013, 03:48 PM
lucdog
lucdog's Avatar
1980 CJ5
What you said about the adjustable ball stud is correct, It will allow for more travel of the arm, and because the ball acts as a fulcrum, the TOB will move further as well.
For every action, there is a equal and opposite reaction.
All I did was raise the fulcrum.
The idea of raising the fulcrum isn't for more travel of the arm, it's to move the TOB towards the pressure plate fingers. You did say the flywheel is 1/2" thinner, that means the clutch is 1/2" further away from the TOB .
The mechanicals will only allow for so much movement of the parts, ie; bellcrank, pedal assembly.
This is why I'm concerned about the TOB coming off the bearing retainer, like in the pictures.
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1983 CJ7
lucdog is offline
1979 , cj5 , fiberglass , rollcage , tailgate
19?? CJ7 build thread biker250 Jeep CJ Forum 96 12-27-2010 06:10 AM
Looking for a CJ Build Thread. jsc7002 Jeep CJ Forum 6 08-22-2009 10:47 AM
High 5 Build Thread... 1Rustycj5 Jeep CJ Forum 7 03-22-2009 09:28 PM
Build Thread for my '84 CJ erik5387 Jeep CJ Forum 19 05-29-2008 01:05 PM
