Clay's Build Thread - Page 346 - JeepForum.com
 48Likes
post #5176 of 5466 Old 08-05-2013, 06:57 PM
243
1978 FSJ Cherokee
Any update Scott?
Dave's 78 Build
243 is offline
post #5177 of 5466 Old 08-05-2013, 07:59 PM Thread Starter
Skerr
Warren placed the TO bearing in NAPA's hands and told him he needed a longer one (about a 1/2"). They have two coming in tomorrow from Jacksonville. Hopefully one of them will work. If not, I will buy the adjustable one from Novak. If all goes well, we'll have his Jeep back Wednesday.
Kerrdog
Go Fish! <*////><
Skerr is offline
post #5178 of 5466 Old 08-05-2013, 08:24 PM
Jim1611
Jim1611's Avatar
That sounds like good news.
Jim1611 is offline
post #5179 of 5466 Old 08-05-2013, 08:42 PM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
With all the 4.0 swaps you read about, I can't believe there is so little info on this clutch compatibility problem.
I admire your tenaciousness, Scott. I think my son would have been driving a Suburu by now.
Matt
Matt1981CJ7 is offline
post #5180 of 5466 Old 08-06-2013, 08:57 AM
mvigo
mvigo's Avatar
Matt
That is funny!
1985 CJ-7, fuel injected 258, 2.5" Rubicon Express Extreme Duty Lift, 1" Body lift, Crabtree Shackle Hangers, T-5, Dana 300 w/ 4:1 Teralow kit, Dana 30, AMC 20 w/1 piece axle, 3.73 's with Detroit Truetrac front and rear, riding on 32x11.5x15" Cooper Discoverer STT mud terrains
mvigo is offline
post #5181 of 5466 Old 08-06-2013, 03:40 PM Thread Starter
Skerr
Matt
Made me smile, Matt, and that's good today!
Neither of the TO bearings would work. Warren placed it back in my hands! I called Novak and talked with EJ again. I really like him. Unbelieveably helpful. They make an adjustable TO bearing, but they are out of stock, they are retooling, and they are at least 2 weeks away from a run. Novak sent me to Summit. So I called Summit. I had a great conversation with their tech dept. But they sent me to McCloud. McCloud listened patiently to the whole story, said "tsk, tsk... call AA." So I called AA, and I had a completely awesome conversation with Gino. Very knowledgable and friendly. He couldn't come up with anything either. He thought I had a bad flywheel. He gave me some specs, but he could offer nothing else. I couldn't think of anything left to do... total despair! So I called Bill. Bill said "adjustable pivot ball". So then I called Warren and explained about the adjustable pivot ball. He told me if I could get him the ball or a part number he would get it done. So that's where we are.
This is killing me!
Kerrdog
Go Fish! <*////><
Skerr is offline
post #5182 of 5466 Old 08-06-2013, 04:23 PM
WNC-84CJ7
Sorry Scotty. I'll call you and cheer you up tomorrow or Thursday. I can in no way, however, offer any knowledge or information regarding resolution to your CJ woes.
"No free man shall ever be debarred the use of arms. The strongest reason for the people to retain the right to keep and bear arms is, as a last resort, to protect themselves against tyranny in government"
-- Thomas Jefferson, 1 Thomas Jefferson Papers, 334
WNC-84CJ7 is offline
post #5183 of 5466 Old 08-06-2013, 04:27 PM
lucdog
lucdog's Avatar
1980 CJ5
Chevy trucks used the stud/ball pivot. I wouldn't think one would hard to find.
Take your pick, http://m.summitracing.com/search/par...rk-pivot-balls
I'll bet there are some at AZ also.
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7
1989 YJ the CJ to YJ.
lucdog is offline
post #5184 of 5466 Old 08-06-2013, 04:46 PM Thread Starter
Skerr
Checked AZ. The Boss says NO. I have to be sure and find one that will fit into the ball stud "tower". Pics on previous page. The Chevy ones I found are 13/16", too thick to be mounted in the tower.
Kerrdog
Go Fish! <*////><
Skerr is offline
post #5185 of 5466 Old 08-06-2013, 04:50 PM Thread Starter
Skerr
I'm in a similar position with your build. I'm reading it, but I don't want to confuse the issue! I really don't know anything about ignition.
Kerrdog
Go Fish! <*////><
Skerr is offline
post #5186 of 5466 Old 08-06-2013, 05:32 PM
VACJ7
VACJ7's Avatar
I bet Bill has a TF999 somewhere on his property! Although it is probably too long for a CJ5. I have faith you will get it sorted out Scott.
P
'84 CJ-7 |
VACJ7 is offline
post #5187 of 5466 Old 08-06-2013, 08:58 PM
lucdog
lucdog's Avatar
1980 CJ5
P
Nope, no 999. We could turn it into a Q-trac though. I do have a couple 1339's and TH400's. also have a 360, and 304 core. And a couple other parts.
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1983 CJ7
lucdog is offline
post #5188 of 5466 Old 08-07-2013, 04:39 AM
243
1978 FSJ Cherokee
Since you don't answer your phone I will have to throw this out in public and possibly embarrass rednecks around the world including yours truly.
That adjustable ball stud looks like a common ball bearing lincoln fused to a beheaded bolt with a nylon locknut.
Dave's 78 Build
243 is offline
post #5189 of 5466 Old 08-07-2013, 06:40 AM
lucdog
lucdog's Avatar
1980 CJ5
The stand off inside the bell housing is possibly in question, as to how stout it may be with a hole drilled and tapped. In the article I read the owner of the jeep welded in gussets to add strength.
Good idea Dave, only I would use a jam nut and loctite to prevent the stud from coming loose. Would also grind the concave out of the stand off.
It appears I need to halt my pre-trip CJ work and go look at a spare bell housing.
One of Scotty's concerns was wether or not the stand off was hollow. I don't think it would be, unless it was a casting flaw.
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1983 CJ7
lucdog is offline
post #5190 of 5466 Old 08-07-2013, 07:51 AM
Matt1981CJ7
1981 CJ7
Guys,
The stand-off is solid with a concave depression for the ball to sit in.
Has anyone considered modifying the fork, somehow?
What a PITA!
Matt
1979 , cj5 , fiberglass , rollcage , tailgate
19?? CJ7 build thread biker250 Jeep CJ Forum 96 12-27-2010 06:10 AM
Looking for a CJ Build Thread. jsc7002 Jeep CJ Forum 6 08-22-2009 10:47 AM
High 5 Build Thread... 1Rustycj5 Jeep CJ Forum 7 03-22-2009 09:28 PM
Build Thread for my '84 CJ erik5387 Jeep CJ Forum 19 05-29-2008 01:05 PM
