Clay's Build Thread - Page 340 - JeepForum.com
 48Likes
post #5086 of 5466 Old 07-13-2013, 11:25 AM
VACJ7
VACJ7's Avatar
I just looked at a wiring diagram for a 92 Cherokee and now my head hurts. I see 4 wires out of the fuel pump relay: red, dark blue, dark blue w/yellow, dark green w/black. The green w/black goes to the ballast resistor bypass relay and the ballast resistor. You can see the dark blue is supplyinng trigger power from the ignition switch, closing the fuel pump relay and then supplyinng power to the green/black, so it is hot in start/run.
'84 CJ-7 |
VACJ7 is offline
post #5087 of 5466 Old 07-13-2013, 11:54 AM
VACJ7
VACJ7's Avatar
It looks like 13B is labeled Ignition on the CJ bulkhead. To me that means it is hot in start/run or the ignition system would not work. Given that, the two wires labeled hot in start or run at the top of the diagram would be an acceptable place to splice into 13B. But this is just conjecture. Don't burn down Clays 5!!!
What does the starter solenoid look like? Like a CJ? It is basically just a relay during crank and a source for other 12v power durinng run. Interesting on the wiring diagram, if it is the correct one, the dark green/tan wire that supplies power to the fuel pump changes color TWICE before it connects to the pump - dark green/red and then to orange.
'84 CJ-7 |
VACJ7 is offline
post #5088 of 5466 Old 07-13-2013, 12:08 PM
jeepwhore
Given the problems your having with the fuel pump relay I wonder if you should forgo the one in the PDC for now and just wire up a basic relay for it using ground, 12V supply, the other hot in crank/run wire and a feed to the pump. It might get you up and running quicker or at least allow you to move on to the spark issue.
'84 CJ-17: 17" stretch, locked Toy axles, 5.5" lift, FI, AX15, D300 w/twin sticks, boatsides & junk.
jeepwhore is offline
post #5089 of 5466 Old 07-13-2013, 04:38 PM Thread Starter
Skerr
Amen, Paul! That's been on my mind! Thanks for your effort, Paul. You have given me another idea to chase.
Ida know, JW... I really need to understand WHY I can't figure this out. I don't want to create a bandaid.
Here are some more pics...
This is the Power Distribution Center (PDC). It is part of a complete engine harness donated from a '92 XJ Cherokee 4.0. Everything that is supposed to get power has power. All the fuses are good. All the relays APPEAR to be good. The blanks in the box are not used.
This is the soft, vulnerable underbelly of the indomitable PDC. This is where I may take my knife and gut it widely, spilling its entrails all over the fender!!
This is a description of the fuel pump relay circuit. I have traced all of the wires to their sources. The labels are correct.
Fused B(+) is a hot wire fed through a fuse in the PDC.
ASD relay connects other relays in the auto shutdown circuit.
Fuel Pump Relay Output... one goes to the O2 sensor plug, the other goes to the Ballast Resistor Relay. These do not appear to feed the fuel pump.
Ignition Switch output is fed from the BH connector, hot in start/run.
Here is a diagram of the PDC from a '95 XJ FSM from Aussieoffroad. It is labeled RHD (right-hand drive?). I don't think that would have any bearing on the color or purpose of the wires.
Description of the circuits in the box.
This a brand-new coil picked up today. It is acting like the other coil... no sprak getting out. With the key "ON", I measure 12.5V in one side of the plug, and 8.4V in the other side of the plug. Should the voltage be the same, or should there be voltage to only one side?
Don't know if this will help you help me, but I surely hope so. Thanks for following along and thanks for your input.
Kerrdog
Go Fish! <*////><
Skerr is offline
post #5090 of 5466 Old 07-14-2013, 05:52 PM
VACJ7
VACJ7's Avatar
Scott, have you tried tracing this wire from the fuel pump relay?
'84 CJ-7 |
VACJ7 is offline
post #5091 of 5466 Old 07-14-2013, 05:57 PM Thread Starter
Skerr
Let. Me. Tell. You. Bout. My. Day!
Wifey has been sick all weekend. She just got back from being gone for 5 days.
Clayton took off for a school function for the weekend. No help from him.
It rained all weekend.
Bought a new coil... ~$35... for nothing. Hey! But it DOES have a lifetime warranty.
Sweated in my sweat-shop shop.
Went to work this morning.
Volunteers didn't show up. No phone call. So I gave a short service myself.
Searched the Net for answers to my no-spark condition, took two memo pages of notes. Couldn't wait to get home!
I told a guy I work with that I hoped God helped me fix the no-spark issue on Clay's Jeep. He said God doesn't work that way! Maybe He does... maybe He doesn't, but I'll give Him the credit if I get it figured out.
I get home and Clay is home. YAY! I have help.
Number one problem with no-spark is bad/disconnected CPS... I'm thinking I never plugged it up. But I did.
Checked my notes. I see ground. Ground!? What's a ground? I don't need no stinkin' ground... it's SITTING on the ground. It says "Check PCM ground". So I did. There are three of them. NONE of them was connected. So I connected them. Guess what? I HAVE A SPARK AT THE PLUGS!!!!! THANK YOU, JESUS! You get the Glory.
I. AM. SO. HAPPY!!!!
Kerrdog
Go Fish! <*////><
Skerr is offline
post #5092 of 5466 Old 07-14-2013, 06:03 PM
MoC
Super super super happy for you sir!
MoC is offline
post #5093 of 5466 Old 07-14-2013, 06:05 PM Thread Starter
Skerr
I took this moment to update ya'll as Clay connects the fuel return line. I figure I had only a couple minutes for him to run the rubber line to the existing hard line. He just came in the door, asking me if I have new tubing bender. He broke the last one. I ask, "Why do you need a tubing bender?" He says, "To bend the return line." All you need to do is connect the rubber tubing!! He completely removed the hard line! (black cloud) He's my son. I love him. He's 19. I love him. I love him. I love him. I love him............
Kerrdog
Go Fish! <*////><
Skerr is offline
post #5094 of 5466 Old 07-14-2013, 06:09 PM
lukenicwalker
1982 CJ7
Yay, Scott!!!!
ldw
lukenicwalker is offline
post #5095 of 5466 Old 07-14-2013, 06:44 PM
Scott3140
Junior Member
Scott3140's Avatar
Is it running yet? Is it running yet?
Scott3140 is offline
post #5096 of 5466 Old 07-14-2013, 07:17 PM
Jim1611
Jim1611's Avatar
Hope beth feels better soon. Yep Clay is 19....remember when we were? I got a story to tell you about back then for me but it'd better never make it on here You'll like it, the guy I worked for didn't though.
Jim1611 is offline
post #5097 of 5466 Old 07-14-2013, 07:18 PM Thread Starter
Skerr
Hee hee... call me!
Kerrdog
Go Fish! <*////><
Skerr is offline
post #5098 of 5466 Old 07-14-2013, 07:23 PM Thread Starter
Skerr
Well, Guys...
Nuff said...
Now, in our joy, we tried to fire it a second time, and this is what we got. The battery could be down some, but it sounds like it has a timing issue. the hesitation sound that it makes is not Clay letting off the key. It's almost like it is locking up for a second. Low battery you think?? Or CPS position?
Kerrdog
Go Fish! <*////><
Skerr is offline
post #5099 of 5466 Old 07-14-2013, 07:27 PM Thread Starter
Skerr
Yep. Uh-Huh. Mm-Hmm. Talk to me, Baby. That's right. Oh yeah...
Kerrdog
Go Fish! <*////><
Skerr is offline
post #5100 of 5466 Old 07-14-2013, 07:28 PM Thread Starter
Skerr
Originally Posted by lukenicwalker View Post
Yay, Scott!!!!
Thanks, Luke. My multi-quote didn't work!
Kerrdog
Go Fish! <*////><
Skerr is offline
1979 , cj5 , fiberglass , rollcage , tailgate
19?? CJ7 build thread biker250 Jeep CJ Forum 96 12-27-2010 06:10 AM
Looking for a CJ Build Thread. jsc7002 Jeep CJ Forum 6 08-22-2009 10:47 AM
High 5 Build Thread... 1Rustycj5 Jeep CJ Forum 7 03-22-2009 09:28 PM
Build Thread for my '84 CJ erik5387 Jeep CJ Forum 19 05-29-2008 01:05 PM
