Clay's Build Thread - Page 338 - JeepForum.com
 48Likes
post #5056 of 5466 Old 07-07-2013, 05:36 PM Thread Starter
Skerr
Originally Posted by MoC View Post
Valves look pretty nasty. Keep at the 4.0 Scott, you are so close!
I wouldn't know a good valve from a bad one! I really want to rebuild an engine, though. I have never done it. Just not convinced I'm going to do Clay's... keep thinking 4.3 and GL60!
I got home from work today and found Clay at the shop. The holiday weekend is over, and Big Brother went back to Savannah. Clay has been working on bending the fuel line for the external pump and FI. We are resuing the XJ SS fuel line as it is several feet long. I bought a hand bender, which, I have read, are not very good. But you know me... I had to try it. Or, rather, CLAY had to try it. (hee hee) So I put Clay to bending the line, him under the Jeep. As it should be! He commented how hard it was to bend. I told him "Go slow", he brought the bender to me a bit ago... in pieces! But he got it done sufficiently, and the fuel lines are installed.
So... what is done?
Fuel lines
PDC installed and powered (all fuses/relays check out)
All sensors installed
Injectors cleaned and installed (not rebuilt though)
Wiring is bundled up and in a *general* arrangement
Some wires have been removed from the XJ harness (this is based on the experience of another JF member who is currently completing his swap)
3 wires have been spliced to the CJ bulkhead connector, but I get absolutely nothing! I was hoping to spin the starter.
What is left?
Figure out the stoopid wires!!
Clay is building a super-heavy-duty bracket for the electric fan. (It will be a perk in the event of a head-on collision!)
Connect the fuel pump.
Install plug wires.
Fill with coolant.
Change the oil.
New serp belt.
I'll follow up with pics later. I need help with wiring!!!!
Kerrdog
Go Fish! <*////><
Skerr is online now
post #5057 of 5466 Old 07-07-2013, 08:48 PM
lucdog
lucdog's Avatar
1980 CJ5
If I were wanting to spin the engine with the starter, I'd start with...
Checking the battery.
Checking grounds and supply lines. This also means checking for 12v+ at the starter ( old solenoid not being used.) reguardless of key position.
Checking for 12v+ at the blue wire that energized the old solenoid, with the key in the start position.
If you don't have power to the blue wire, you either don't have power to the fuse block, or, are using the wrong wire.
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7
1989 YJ the CJ to YJ.
lucdog is offline
post #5058 of 5466 Old 07-08-2013, 04:21 AM Thread Starter
Skerr
I'm not using the blue wire. Do I need to use the blue wire?? There is a blue wire... actually 2 blue wires... at cavity 13B in the CJ BH connector. I have that connected. But I don't think it is the same blue wire...
Kerrdog
Go Fish! <*////><
Skerr is online now
post #5059 of 5466 Old 07-08-2013, 09:31 AM
SLO_Ken
Have it connected to what? It should be the same blue wire... On the diagram shown earlier, cavity 13B was labeled as the "ignition crank." The two blue wires should have been the blue wire that went to the "S" terminal on the starter solenoid, and the blue wire that went to the power connector on the old ignition module. Only one of these two leads is needed to be spliced into the 4.0 harness. It should be spliced to the yellow wire that goes to the starter relay in the PDC.
SLO_Ken is online now
post #5060 of 5466 Old 07-09-2013, 06:54 PM Thread Starter
Skerr
Hey Ken! Glad to hear from you. I have spliced one of those blue wires to the yellow that goes to the starter relay in the PDC. But Nix! I obviously cut something out that I shouldn't have, AND/OR- I'm wondering if the park/neutral switch wire needs to be grounded?? I have not done that... just had that brainstorm this evening. Also, I have a fairly long, heavy brown wire with a ring terminal that comes out of the alternator plug that I ASSUME goes to the small terminal on the starter solenoid. Not sure about that one. Guess I'd better get some pics up!
edit* I should mention that I can confirm power in the blue wire/s with the key in the start position.
I did test the starter (Thank you, Bill), and it is good. Didn't think to take the Jeep out of gear!! Nobody died...
Kerrdog
Go Fish! <*////><
Skerr is online now
post #5061 of 5466 Old 07-09-2013, 06:59 PM
lucdog
lucdog's Avatar
1980 CJ5
Well it's a plus the clutch worked
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1983 CJ7
lucdog is offline
post #5062 of 5466 Old 07-09-2013, 07:13 PM Thread Starter
Skerr
Bill
well... ummm... I don't know! Clay was standing outside, and I was making the battery connection when it started to go backwards! I removed the battery connection before Clay let go of the key! It sounds like a Chrysler starter!!
Kerrdog
Go Fish! <*////><
Skerr is online now
post #5063 of 5466 Old 07-09-2013, 09:14 PM
SLO_Ken
Yes, the NSS wire should be grounded. This will complete the actuation circuit for the starter motor relay in the PDC. The output from this relay actuates the starter motor solenoid (on the starter).
post #5064 of 5466 Old 07-09-2013, 10:04 PM
SLO_Ken
Actually, there are two leads that ground through the NSS. One is the bk/wt wire from cavity D11 in the PDC. The other is pin 30 on the ECM. Both of these should be grounded.
post #5065 of 5466 Old 07-10-2013, 05:51 PM Thread Starter
Skerr
Thanks, Ken. I grounded the NSS wire/s from the PDC. There are two coming from the starter motor relay, which is labeled "F" in the PDC. One of the wires goes to the ECM, but I didn't take note of the pin number. The other went to a large, black plug... possible tranny control module? I cut them both and twisted them together at the PDC. SHAZZAM! The Jeep cranked with the key! However, it would begin cranking before fully engaging the key in the start position, and it would not stop cranking when the key was released... you have to go back to off to make the starter stop.
Variations I tried... I rejoined the ECM wire so it made a complete circuit from the ECM to the PDC, and I twisted the "black plug" wire together with it, then grounded that connection. I have the same result.
I left the "black plug" wire out of it altogether. Same result.
Going back out to stare at it!
Kerrdog
Go Fish! <*////><
Skerr is online now
post #5066 of 5466 Old 07-10-2013, 06:11 PM Thread Starter
Skerr
I really should go play Lotto or something! I haven't had this kind of luck in awhile. I went back to look at the wiring at the BH connector. I had the CJ BH start wire (14B) connected to the XJ blue wire (A21) from the PDC. A21 is a 12GA Dark Blue wire which is labeled "ignition switch output (start/run)". Holy Mackeral... I'm starting to sound like "Them"! I moved 14B to XJ PDC wire A41, 14GA Yellow wire, labeled "ignition switch output (start)". Now it cranks with the key as it should. Now I just have to figure out where everything else goes!
Thanks Jeepwhore, Professor, and Ken!
Should the A21, 12GA Dark Blue wire from the Fuel Pump Relay be attached to the other start/run 14B wire?
Kerrdog
Go Fish! <*////><
Skerr is online now
post #5067 of 5466 Old 07-10-2013, 07:52 PM
jcal73
jcal73's Avatar
2015 JK Wrangler
Keep on truckin!
I can't wait to see you get it running!
Jeff
Jeff
Our Jeep Links
jcal73 is offline
post #5068 of 5466 Old 07-10-2013, 08:03 PM
lukenicwalker
1982 CJ7
Originally Posted by jcal73
Keep on truckin!
Jeff
Me too! Go, Skipper, go!!!!
ldw
lukenicwalker is offline
post #5069 of 5466 Old 07-10-2013, 08:05 PM
pman
Woot! Woot! Raise the Roof! Great news, Scott!!!!
88 Wrangler Laredo 258-999-NP231
81/76 CJ5 304-t150-Spicer 20
82 Wagoneer 360-727-NP208
82 CJ8 Scrambler 258-t5-Dana 300
pman is online now
post #5070 of 5466 Old 07-10-2013, 09:02 PM
jeepwhore
No thanks needed, not like I contributed much. As for the fuel pump relay wire, which terminal on the relay does it come from? If its the terminal for the switched relay power supply then yes, connect it to a start/run
'84 CJ-17: 17" stretch, locked Toy axles, 5.5" lift, FI, AX15, D300 w/twin sticks, boatsides & junk.
jeepwhore is offline
1979 , cj5 , fiberglass , rollcage , tailgate
19?? CJ7 build thread biker250 Jeep CJ Forum 96 12-27-2010 06:10 AM
Looking for a CJ Build Thread. jsc7002 Jeep CJ Forum 6 08-22-2009 10:47 AM
High 5 Build Thread... 1Rustycj5 Jeep CJ Forum 7 03-22-2009 09:28 PM
Build Thread for my '84 CJ erik5387 Jeep CJ Forum 19 05-29-2008 01:05 PM
