Clay's Build Thread - Page 336 - JeepForum.com
 48Likes
post #5026 of 5466 Old 06-29-2013, 08:58 AM
gmakra
Skipper yes you have the TPS and Idle Air controller hooked up and everything on the engine looks like its hooked up.
Skipper I'm assuming that you have heard of the kiss theory. (Keep it simple stupid)
For you I've come up with the kisses theory. Keep it super simple especially for Southerners,
Now you know bill has kissed you a lot I on the other hand am going to make this very easy for you to do.
First mount your ECM.
Two plug in your loom into your ECM.
Three reconnect your diagnostic connector and mounted in the cab some place You will need this later.
Four tape or wire tie the ECM loom wires every six or so inches from the ECM to the first point where the wires start to branch out.
This will get rid of a lot of wires that are in the way currently and you will find that you have a few connections left over. We will address these after everything else is been done.
In the meantime don't worry about all the technical aspects we are just trying to get the bulk of the wiring out of the way.
gmakra is offline
post #5027 of 5466 Old 06-29-2013, 09:55 AM Thread Starter
Skerr
I had a fabulously enlightening conversation with George, aka The Professor, aka Holy Makra, early this morning. Which in itself is surprising, cause you know this ol farmboy gets up early, and The Professor needs his beauty sleep. I mean... he really needs it! But, he did call me, and some of my amassing density diffused with the radiance of our soggily rising sun.
So I ran out to a couple places and bought some Jeep ammo to combat the problems I have been dealing with. Namely, those unseen things that make a Jeep change during the night! I bought a hand tubing bender to bend the SS XJ fuel line. I bought a different fuel filter to install after the fuel pump. I bought a new pressure regulator ($60 freakin dollars... holy makra!) Some zipties, some sheet metal screws (cause I realy like em), a new soldering gun (because my old Craftsman makes me tired when I hold it up for a long period of time), some 3/16X3" bolts (to mount the ECM on the cool, custom bracket made by Clay), 10' of 5/16 injector line and... and... dad-gum... it's raining again!
Wifey and kids gone. Guess I'll watch Conan. Wow! Did my priorities just change, or what!?
Thank you, George.
Kerrdog
Go Fish! <*////><
Skerr is offline
post #5028 of 5466 Old 06-29-2013, 01:03 PM
Jim1611
Jim1611's Avatar
So no pictures of this stuff you bought? No big breakfast today either? Man you'd think there's something screwed up with the forum with this lack of pictures.
Jim1611 is offline
post #5029 of 5466 Old 06-29-2013, 02:00 PM
243
1978 FSJ Cherokee
Easy with the stick Big Jim, ole' Scott do sound motivated and might take it away and whip ya
Dave's 78 Build
243 is online now
post #5030 of 5466 Old 06-29-2013, 02:18 PM
Jim1611
Jim1611's Avatar
Yep he might and he might be gettin cranky with the wife and kids gone.
Jim1611 is offline
post #5031 of 5466 Old 06-29-2013, 02:27 PM Thread Starter
Skerr
ONE THING I want to say, and you'd BETTER PAY ATTENTION cause I'm only going to say this once...
...ice-cold watermelon is hard to beat!
Kerrdog
Go Fish! <*////><
Skerr is offline
post #5032 of 5466 Old 06-29-2013, 03:44 PM Thread Starter
Skerr
Guess I need a solder lesson... the solder is not melting into the wire. I have a hefty Craftsman that will melt the wire casing, and I just bought this smaller Weller (130A). Using the 1/4" spade tip, I can heat the wire until the solder melts, but it is not going into the wire mass. I stripped the wire... it's new and shiny. I moderately twisted the ends together - inline- and I placed the gun tip in the middle of the splice. I hold the solder at one end away from the tip. I wriggle it around and it finally melts. But it doesn't flow into the wires. It just blobs up and ends up on my work surface. I have tried wood and metal work surfaces. What am I doing wrong?
Kerrdog
Go Fish! <*////><
Skerr is offline
post #5033 of 5466 Old 06-29-2013, 05:23 PM Thread Starter
Skerr
Okay... got another fabulous call from The Professor. I am now solder-capable! Thanks, Prof.
Kerrdog
Go Fish! <*////><
Skerr is offline
post #5034 of 5466 Old 06-29-2013, 06:13 PM
Jim1611
Jim1611's Avatar
Well what were you doing wrong?
Jim1611 is offline
post #5035 of 5466 Old 06-29-2013, 06:25 PM
mvigo
mvigo's Avatar
I'm afraid to hear that answer!
1985 CJ-7, fuel injected 258, 2.5" Rubicon Express Extreme Duty Lift, 1" Body lift, Crabtree Shackle Hangers, T-5, Dana 300 w/ 4:1 Teralow kit, Dana 30, AMC 20 w/1 piece axle, 3.73 's with Detroit Truetrac front and rear, riding on 32x11.5x15" Cooper Discoverer STT mud terrains
mvigo is offline
post #5036 of 5466 Old 06-29-2013, 07:13 PM
243
1978 FSJ Cherokee
I want to know because I suck at soldering, even with the expert Andy coaching me along!
Dave's 78 Build
243 is online now
post #5037 of 5466 Old 06-29-2013, 08:09 PM
lucdog
lucdog's Avatar
1980 CJ5
So Beth didnt leave you anything else to eat for a week, I hope she didn't take the coffee pot!
Do I need to call you in the am to make sure your not late for work.
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7
1989 YJ the CJ to YJ.
lucdog is offline
post #5038 of 5466 Old 06-29-2013, 08:31 PM Thread Starter
Skerr
I wasn't holding my mouth right.
I do NOT want to wake up to your voice first thing in the morning!
Kerrdog
Go Fish! <*////><
Skerr is offline
post #5039 of 5466 Old 06-30-2013, 12:09 AM
Dadamsnv
1977 CJ5
Did the prof say to use flux?? That usually does the trick for me.
I'm looking for a Scout II Dana 300. Drop me a line if you have any leads. Thanks
Dadamsnv is online now
post #5040 of 5466 Old 06-30-2013, 07:27 AM
gmakra
Remember skippers old signature if you can't fix it with a hammer you got anelectrical problem! While he was trying to fuse two pieces of copper wire with a hammer.
Soldering is very simple 243 all you need is a soldering iron some rosin core solder. If you are using a new soldering iron or tip you will need to sand the tip till its shiny. Heat up the soldering iron and touch the solder to the tip. It should flow around the tip and up the tip a bit. This is called tinning the tip.
Now all you need to do this strip both ends of the wire about half an inch. Twist the wires together now lightly touch the joint with the tip of the soldering iron that has been tinned.The tip of the soldering iron will have a coating of molten solder on it as the wire heats up in this will only take a few seconds you will see the solder starting to wick up into the wires. You may elect to add a little more solder to the joint you can do this by either touching the solder to the tip or to the wires itself.
When the soldering is done that joint itself should be shiny without any access solder on it. I tried to upload a picture of different solder joints but the forum wont let me do it.
gmakra is offline
1979 , cj5 , fiberglass , rollcage , tailgate
19?? CJ7 build thread biker250 Jeep CJ Forum 96 12-27-2010 06:10 AM
Looking for a CJ Build Thread. jsc7002 Jeep CJ Forum 6 08-22-2009 10:47 AM
High 5 Build Thread... 1Rustycj5 Jeep CJ Forum 7 03-22-2009 09:28 PM
Build Thread for my '84 CJ erik5387 Jeep CJ Forum 19 05-29-2008 01:05 PM
