Clay's Build Thread - Page 331 - JeepForum.com
 48Likes
post #4951 of 5466 Old 06-01-2013, 10:19 AM Thread Starter
Skerr
[QUOTE=243;15505516]Dude, my cousin-out-law had a WRX and I rode with him from my Mom's place over the causeway to Galveston to pick up some odds and ends, I have to say that son-of-a-bisquit was blindingly fast; in fact, I think that flat-four WRX pulled harder than any street car I have been in in my life.[/QUOTE]
nuff said...
Kerrdog
Go Fish! <*////><
Skerr is offline
post #4952 of 5466 Old 06-01-2013, 10:37 AM Thread Starter
Skerr
After ALL THESE YEARS OF READING. Reading things that didn't make ANY sense at all! Thinking, "I need to understand", but never really getting it. IT HAS ALL COME CRASHING TOGETHER IN A CULMINATION OF JEEP KNOWLEDGE NEVER BEFORE EXPERIENCED BY ANY HUMAN! Yep. It's true. I wouldn't lie. You KNOW me! Sooo, you wanna know what happened this morning?? C'mon... guess. Yep. I GOT IT!
PILOT BUSHING REMOVAL
Pilot bushing, you say? You want to know what a pilot bushing is, and what it does?? I don't have any idea! I just know you need it, AND I know WHERE IT GOES, and HOW TO GET IT OUT! Thanks to the members of this heer forim.
You can see, in the pics that follow, the 258 block sitting quietly, although without grace, in the trailer.
Then, you can see the pilot bushing with my indispensible can of Sili-Kroil... compliments of a friend in Illinois.
Then some bread. Yeah, yeah, I was a might peckish.
Fill the hole with bread.
Drive in a large bolt. Add more bread, if needed.
And, DEWD! IT COMES RIGHT OUT!
That is the coolest thing I have ever experienced. Even better than a WRX gittin it over a causeway!
Too bad the pilot bushing for a T18 DOES NOT FIT A 4.0L! Going to have to get it turned down. The new one is aluminum? Why is the brass one so chewed up? Which one should I use? Delays, delays...
Kerrdog
Go Fish! <*////><
Skerr is offline
post #4953 of 5466 Old 06-01-2013, 10:47 AM
Jim1611
Jim1611's Avatar
I've used grease in place of the bread. Amazing that an old way of doing things is still around. You'd think the obd1 would be able to take that out for you, even though it is in the 258. Computers.....well let me just say they can't replace the human brain. Did you have any bread left over for a sandwhich? Aint you glad Papa Billy is so old and knows this stuff?
Jim1611 is offline
post #4954 of 5466 Old 06-01-2013, 12:16 PM
jeepwhore
Sorry Scott, I forgot all about the wiring stuff for the 4L.
Turns out I told a half truth, .
The bulkhead info I have is for a '94 XJ. But I have a pin out for the ECM connection as well and it is for '91 through '93. I can only assume the bulkhead connector will be the same through those years as far as the main terminals go......and I haven't found anything to contradict that assumption......yet.
I stole these pics from other threads but they show the cavities you need.
'79 bulkhead:
12A is your main power feed
13B is your ignition crank, and
14B is your ignition crank & run
'94 bulkhead (ignore the text regarding the YJ wiring):
12A should be spliced to E4 on the donor harness (Ignition switch feed-10G red).
13B should be spliced to H2 on the donor harness (Engine starter relay-14G yellow)
14B should be spliced to B6 on the donor harness (Ignition start/run-12G dark blue)
The only thing I haven't addressed is the fuel pump. Near as I can tell you just use cavity C4 on the donor harness to trigger the fuel pump relay.
'84 CJ-17: 17" stretch, locked Toy axles, 5.5" lift, FI, AX15, D300 w/twin sticks, boatsides & junk.
jeepwhore is offline
post #4955 of 5466 Old 06-01-2013, 12:18 PM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
Sandwich?!? Are you kidding me? Did you see the feed-bag Scooter put on this morning?
Now I'm getting hungry....
Matt
Matt1981CJ7 is offline
post #4956 of 5466 Old 06-01-2013, 12:40 PM
lucdog
lucdog's Avatar
1980 CJ5
Matt
Tape worm, probably see its head when he yawns.
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7
1989 YJ the CJ to YJ.
lucdog is offline
post #4957 of 5466 Old 06-01-2013, 01:05 PM
Matt1981CJ7
1981 CJ7
Bill, dude, you've been tearing it up, lately.
Matt
post #4958 of 5466 Old 06-01-2013, 02:00 PM Thread Starter
Skerr
If you use grease you end up getting... greasy. And you know how I like to stay clean when I work!
'79 bulkhead:
Beautiful! Just what I needed. Thanks so much, JW.
Matt
Matt
Yeeeeesssssss, he has, hasn't he!? But you just wait... he'll post up pizza and beer within the next 2 days. Betcha...
I can't help it. This comment made me laugh until I had snot running down my chin! And you captured your one intellectual thought on the world wide web. Freakin' miracle.
Kerrdog
Go Fish! <*////><
Skerr is offline
post #4959 of 5466 Old 06-01-2013, 04:00 PM
lucdog
lucdog's Avatar
1980 CJ5
Matt
Keep feeding me,
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1983 CJ7
lucdog is offline
post #4960 of 5466 Old 06-01-2013, 04:08 PM
Matt1981CJ7
1981 CJ7
Keep feeding me,
From shooting blanks, to Peep shows, to tape worms....ahhh, I love the JF.
Matt
post #4961 of 5466 Old 06-01-2013, 05:13 PM Thread Starter
Skerr
I was installing the new 258 water pump on the 4.0 block. Clay had it painted up. The vanes on the pump hit the cylinder sleeve! The old 258 pump doesn't hit. The 4.0 pump doesn't hit. The new pump hits!
Kerrdog
Go Fish! <*////><
Skerr is offline
post #4962 of 5466 Old 06-01-2013, 05:37 PM
jeepwhore
The 4L bore is .125 larger but i wouldn't think that would make the vanes hit the cyl wall.....but you made sure to get the 4.2 pump for a serp belt, right?
Actually, why use a 4.2 pump at all?
post #4963 of 5466 Old 06-01-2013, 07:10 PM Thread Starter
Skerr
Not doing the serp belt. That would be cool, but I am keepig everything 258 that I can, because I have it already. Using the 258 water pump, I keep the 258 cooling system, and I have no need for an electric fan. At least... I think!
Kerrdog
Go Fish! <*////><
Skerr is offline
post #4964 of 5466 Old 06-03-2013, 09:05 PM Thread Starter
Skerr
Ordered a pilot bushing from Novak today. $28!!! Yelp!@%#.
Still fussing with motor mounts, Crank Position Sensor, and water pump.
Will this thing EVER go into the Jeep?
Kerrdog
Go Fish! <*////><
Skerr is offline
post #4965 of 5466 Old 06-04-2013, 07:40 PM Thread Starter
Skerr
Clay's eyeball at the ER the other day...
Kerrdog
Go Fish! <*////><
Skerr is offline
1979 , cj5 , fiberglass , rollcage , tailgate
19?? CJ7 build thread biker250 Jeep CJ Forum 96 12-27-2010 06:10 AM
Looking for a CJ Build Thread. jsc7002 Jeep CJ Forum 6 08-22-2009 10:47 AM
High 5 Build Thread... 1Rustycj5 Jeep CJ Forum 7 03-22-2009 09:28 PM
Build Thread for my '84 CJ erik5387 Jeep CJ Forum 19 05-29-2008 01:05 PM
