Clay's Build Thread - Page 327 - JeepForum.com
post #4891 of 5422 Old 05-18-2013, 12:15 PM
243
1978 FSJ Cherokee
Originally Posted by lucdog View Post
Clean with brake clean before install.
Bill
^^^ flywheel surface, both sides of pressure plate and clutch surface...grease and oil no bueno!
And how the hell would I know
Dave's 78 Build
243 is offline
post #4892 of 5422 Old 05-18-2013, 12:53 PM Thread Starter
Skerr
Bill, Dave... thanks for the tip on cleaning. Would not have thought to do it.
I have been cleaning up my shop, out of pure frustration. I feel like I am so stagnant! Like in a HUGE rut. I have so much to do, and I know you just have to chip away, but I have been feeling overwhelmed. So with my cold in hand I went out to the shop and started cleaning. I am sweating like a wild pig on an August day in south Florida! It is actually making me feel a little better physically. I can't believe the crap I have thrown out of the shop. Now I have to pick it up, again, and toss it in the trash! But I can see my shop floor. I moved my 7 over so I can get to it easier, and I have wifey tracking down some carb bolts. Maybe I will fire her up later today.
Attaching some pics of Clay's OH console he is building. It will house his stereo and a storage compartment. he's pretty pumped about it. I marvel at his welding skills. He has really done well.
Gotta go cut some grass...
Kerrdog
Go Fish! <*////><
Skerr is offline
post #4893 of 5422 Old 05-18-2013, 12:53 PM Thread Starter
Skerr
So what's up with the picture posting???
Kerrdog
Go Fish! <*////><
Skerr is offline
post #4894 of 5422 Old 05-18-2013, 01:42 PM
243
1978 FSJ Cherokee
I moved my 7 over so I can get to it easier, and I have wifey tracking down some carb bolts. Maybe I will fire her up late today.
No problem buddy, I know how it is to be up to your eyeballs, brain box foggy and the overwhelming feeling that something needs to be done but the nagging question is what needs to be done first; the answer of course, is everything
On the other hand, firing up wifey this evening sounds like fun but I would suggest taking the batteries outta the camera
Dave's 78 Build
243 is offline
post #4895 of 5422 Old 05-18-2013, 02:11 PM Thread Starter
Skerr
Originally Posted by 243 View Post
...firing up wifey this evening sounds like fun but I would suggest taking the batteries outta the camera
It's that time of year again...
Kerrdog
Go Fish! <*////><
Skerr is offline
post #4896 of 5422 Old 05-18-2013, 07:56 PM Thread Starter
Skerr
After cleaning up the Neon injectors, Clay installed them onto the fuel rail. He bypassed ordering a rebuild kit that provides new screens, pintles, and O-rings. He blasted them all out with carb cleaner and Blaster. He also filled the fuel rail with Blaster. Then he connected the fuel rail to the block. He connected all the injector wiring, but he never labeled it. He was muttering something like, "this looks like it goes here, this looks like it goes there..." I have no idea if he got lucky or not! Worse case scenario he will be tracing wiring. So the OBDI engine harness is in place. The OBDI injectors are in place. All the OBDI sensors are nearly finished.
Still need to get...
OBDI distributor (JY)
OBDI coil (JY)
XJ air box (JY)
Flywheel bolts (new)
Kerrdog
Go Fish! <*////><
Skerr is offline
post #4897 of 5422 Old 05-19-2013, 07:10 AM
gmakra
Outa da way you Knuckleheads!
Skipper looks like your moving in the right direction, however I have a question is the ECM from the auto transmission? If so I would source a ECM from a manual trans the programs are different and will cause you fits.
The dirt in the fuel line, rail and other can be over come. Install a large pre-filter on your pump so you don't suck any thing into the pump. The tolerances are so fine you don't want trash it. Also install a filter on your return line just after the fuel regulator so you dont send CRUD back to the tank. After a few fill ups you can ditch the return filter. Also run the original injectors for a few tank cycles so that if you get any CRUD in the injector you can easily switch to the Neon's
Dont quote me on this but I think the OBD1 is a batch fire system and not sequential meaning all the injectors fire at once and not per cylinder. So I dont think you will have any issues with mixed up wiring, also the harness is pretty hard to get the injectors out of order.
The rest is pretty straight forward O2 Sensor, MAP Sensor, Throttle Position Sensor, Coolant Sensor, VSS and idle air I may have missed some thing but thats all I can think of till I have had my third pot of coffee.
The crank position sensor is very crucial that it be located correctly.
Also if you have yanked the dizzy you will need to index the dizzy you can Google it and its so easy even a cave man can do it.
gmakra is offline
post #4898 of 5422 Old 05-19-2013, 02:10 PM
cjdogtoy
1976 CJ5
just keep plugging away
cjdogtoy is offline
post #4899 of 5422 Old 05-19-2013, 04:57 PM Thread Starter
Skerr
What is the manual tranny ECM going to give me? I thought I could just ground the wire from the tranny control module??
I will definitely provide the filters. Good suggestion on using the stock injectors before the Neon injectors. I really hate to tell Clay to pull them back out!
After reading the FSM it looks like it fires the injectors sequentially, using the cam position sensor and the crank position sensor. All the injector wires are different colors, and it won't be hard to trace them.
I am having TONS of trouble finding/confirming the "5 wires to fire". You can Google it all day and read everythig posted, but it is primarily for YJs, and nobody says "this wire, and this wire, and this wire...". Everybody talks like everybody already knows!!!
And I'm a slug!
So I have been looking for a pinout of the bulkhead connector for the '92 XJ so I can figure out which wires to splice into the CJ bulkhead.
That's all I have left!
Kerrdog
Go Fish! <*////><
Skerr is offline
post #4900 of 5422 Old 05-19-2013, 06:24 PM
gmakra
Skipper ask and you shall receive the early XJ are the same.
Do Do Do Lokking out my back door!
gmakra is offline
post #4901 of 5422 Old 05-19-2013, 07:15 PM Thread Starter
Skerr
Jorge... isn't this the PCM plug? Don't I need the bulkhead plug?? So I know what is power for PCM, fuel pump, etcetera, etcetera....
Oh yeah... Thank You! I do need this diagram. It's better than the one I had.
Kerrdog
Go Fish! <*////><
Skerr is offline
post #4902 of 5422 Old 05-19-2013, 08:54 PM
gmakra
Skipper does the bulkhead connector feed into this plug?
gmakra is offline
post #4903 of 5422 Old 05-19-2013, 10:27 PM
Turtle71
1983 CJ7
Looks like you are making good steady progress! Just cleaning up alone will help you think better. Keep going and it will have a domino effect.
My 83 CJ7 Build:
Turtle71 is offline
post #4904 of 5422 Old 05-20-2013, 09:32 PM Thread Starter
Skerr
Well, Professor... from the key switch to the bulkhead to the PCM, yes, it feeds the PCM. I know there's something to do with start/run, run, and I don't know what else. I guess start/run should feed the fuel pump? I don't even want to think about it!
The domino effect is a good analogy, but everybody stays so far away from me that when I fall over I can't hit anyone! So it's a short run!
Thinking about taking my Jeep to my favorite mechanic to get it in running condition. That would be a huge heap off my plate.
Kerrdog
Go Fish! <*////><
Skerr is offline
post #4905 of 5422 Old 05-21-2013, 06:23 AM
gmakra
Skipper the ECM has one plug on it only?
If thats the case then the pin out I posted should be the ticket.
If this is not the case take pictures of the ECM and harness where is goes to the bulkhead connector.
gmakra is offline
1979 , cj5 , fiberglass , rollcage , tailgate
19?? CJ7 build thread biker250 Jeep CJ Forum 96 12-27-2010 07:10 AM
Looking for a CJ Build Thread. jsc7002 Jeep CJ Forum 6 08-22-2009 11:47 AM
High 5 Build Thread... 1Rustycj5 Jeep CJ Forum 7 03-22-2009 10:28 PM
Build Thread for my '84 CJ erik5387 Jeep CJ Forum 19 05-29-2008 02:05 PM
