Clay's Build Thread - Page 318 - JeepForum.com
post #4756 of 5442 Old 03-10-2013, 12:53 PM
Cutlass327
Cutlass327's Avatar
1978 CJ5
Have you looked at the steering shaft from the column to the box? Mine has a little slop in the "u-joint" of it - it is basically just a metal block with pins in the "yokes" of the shaft that go in holes of the block. And if you ever melted the plastic in the telescoping part, unless you somehow bolted/pinned it or secured it I had some slop in the slip part til until it rusted solid again.
Rick
Cutlass327 is offline
post #4757 of 5442 Old 03-10-2013, 02:40 PM Thread Starter
Skerr
Thanks for the thought, Rick. That's not the culprit... the U-Joint is new. Shaft was separated, cleaned, and reinstalled during the column rebuild. No slop there either. I know the gear box is causing an issue. I just don't know how much is related to it and how much may be related to caster? But I will know the answer within a week or so.
Kerrdog
Go Fish! <*////><
Skerr is online now
post #4758 of 5442 Old 03-11-2013, 09:21 PM Thread Starter
Skerr
Installed the new gear box this evening when I got home from work. Clay had it mostly ready to go. Looked great in the box. Loosely mounted up the brackets. Installed it on the Jeep. Tightened up the brackets, and one of the side bolt holes is stripped! Right out of the box! This is after connecting the lines and filling it with oil. Checked to see if Clay could drive it to school for the rest of the week, as we need 3 vehicles right now. No way. The gear box moves all over the place! Aggravated! Clay has to get up early and take me to work, then go to school, then come and get me. He will have 13.5 hours at school to accomodate me, and we are out the time and a pint of fluid. Not to mention having to do it again!
Kerrdog
Go Fish! <*////><
Skerr is online now
post #4759 of 5442 Old 03-11-2013, 09:37 PM
lucdog
lucdog's Avatar
1980 CJ5
Well that sucks, should have went to O'Reillys !
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7
1989 YJ the CJ to YJ.
lucdog is offline
post #4760 of 5442 Old 03-11-2013, 09:45 PM
Dadamsnv
1977 CJ5
Man that sucks
I'm looking for a Scout II Dana 300. Drop me a line if you have any leads. Thanks
Dadamsnv is offline
post #4761 of 5442 Old 03-11-2013, 11:13 PM
Cutlass327
Cutlass327's Avatar
1978 CJ5
Any chance to Heli-coil the hole?
Rick
post #4762 of 5442 Old 03-12-2013, 04:58 AM
243
1978 FSJ Cherokee
That sounds like a royal pain Scott! But ya'll seem to get through everything thrown your way working together and having fun at the same time.
Dave's 78 Build
243 is offline
post #4763 of 5442 Old 03-12-2013, 05:31 AM
WNC-84CJ7
Good extra time for Clayton to study!!
"No free man shall ever be debarred the use of arms. The strongest reason for the people to retain the right to keep and bear arms is, as a last resort, to protect themselves against tyranny in government"
-- Thomas Jefferson, 1 Thomas Jefferson Papers, 334
WNC-84CJ7 is offline
post #4764 of 5442 Old 03-12-2013, 06:32 AM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
I think Mr. Murphy has taken up permanent residence at the Kerrdog household.
Matt
Matt1981CJ7 is offline
post #4765 of 5442 Old 03-12-2013, 08:04 PM Thread Starter
Skerr
Don't know who makes the reman gear boxes. I didn't pay attention to the brand. I'm guessing these would be available to all the parts houses?? At any rate, I have another one coming... be here Thursday.
Then I'm going to need a lesson on how to center the pitman arm on the gear box! And does this affect the alignment?
Kerrdog
Go Fish! <*////><
Skerr is online now
post #4766 of 5442 Old 03-12-2013, 08:09 PM
lucdog
lucdog's Avatar
1980 CJ5
Doesn't affect alignment.
Do you want the lesson now or later?
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1983 CJ7
lucdog is offline
post #4767 of 5442 Old 03-12-2013, 08:22 PM Thread Starter
Skerr
Not now... no way I could pay attention! I'll probably call you when I am under the stoopid Heep!
Crap! You gonna be around?
Kerrdog
Go Fish! <*////><
Skerr is online now
post #4768 of 5442 Old 03-12-2013, 08:26 PM
lucdog
lucdog's Avatar
1980 CJ5
Home Wednesday ,Thursday and Friday, Indiana with the Jeep on Saturday, work on Sunday.
Not much to it. Mount the box first, then connect the steering shaft, then call me. Make sure all the holes have good threads. :-)
Bill. And check out my thread!
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1983 CJ7
lucdog is offline
post #4769 of 5442 Old 03-12-2013, 09:49 PM
cjdogtoy
1976 CJ5
got to get that thing up and running so the blond can do more tracks in the grass ha ha. sorry to hear about your troubles.
cjdogtoy is offline
post #4770 of 5442 Old 03-12-2013, 10:49 PM
MoC
Man thats some bad luck on the box Scott.
MoC is offline
1979 , cj5 , fiberglass , rollcage , tailgate
rixcj
19?? CJ7 build thread biker250 Jeep CJ Forum 96 12-27-2010 06:10 AM
Looking for a CJ Build Thread. jsc7002 Jeep CJ Forum 6 08-22-2009 10:47 AM
High 5 Build Thread... 1Rustycj5 Jeep CJ Forum 7 03-22-2009 09:28 PM
Build Thread for my '84 CJ erik5387 Jeep CJ Forum 19 05-29-2008 01:05 PM
