Clay's Build Thread - Page 314 - JeepForum.com
 48Likes
post #4696 of 5466 Old 12-30-2012, 04:36 PM
DutchJPR
Getting those soft doors the right way in the tub is a pain in the b**t. I gave up at a certain point. Wind an water tightness was enough then...
Aren't there adjusting bolts for the hinge pins at inside of doors?
A bit look alike?
Dutch builds: http://www.jeepforum.com/forum/f8/dutch-build-1231816/
Last edited by PhilipB; 01-17-2013 at 09:32 AM. Reason: had to remove image was triggering malware warnings, sorry.
DutchJPR is offline
post #4697 of 5466 Old 12-30-2012, 09:42 PM
WNC-84CJ7
In the color pic of Clay and the rig, YOUR windshield angle looks more correct than the door. Can you finagle the hinge placement, pivoting the bottom one toward the back wheel?
"No free man shall ever be debarred the use of arms. The strongest reason for the people to retain the right to keep and bear arms is, as a last resort, to protect themselves against tyranny in government"
-- Thomas Jefferson, 1 Thomas Jefferson Papers, 334
WNC-84CJ7 is offline
post #4698 of 5466 Old 12-30-2012, 09:59 PM
MrBeast
1980 CJ7
I just had an epiphany looking at this, I think they sent you the upper doors for a TJ where the windshield is laid back more. I'd contact the manufacturer because it would seem to me as though your windshield angle is right, and in order to get it to lean back that much, you are really going to be putting pressure on those hinges.
"He used to be a pretty nice feller, now he's a welder"
AMC 304 V8, NV4500, Dana 300, Dana 44, 9 inch, M.O.R.E. SRS, YJ tub.
AT3 US Navy 1999-2003
Cum catapultae proscriptae erunt tum soli proscript catapultas habebunt
(When catapults are outlawed, only outlaws will have catapults)
MrBeast is offline
post #4699 of 5466 Old 12-30-2012, 10:11 PM
8pitcher
8pitcher's Avatar
I have some cj5 soft doors I can put together and we could compare if you'd like.
8pitcher is offline
post #4700 of 5466 Old 12-30-2012, 10:28 PM
WNC-84CJ7
Me too. I got a set sittin in the garage. I could give you angles and lengths if that would help.
post #4701 of 5466 Old 12-30-2012, 10:37 PM
8pitcher
8pitcher's Avatar
No I offered first.
8pitcher is offline
post #4702 of 5466 Old 12-31-2012, 05:32 AM Thread Starter
Skerr
[quote=DutchJPR;14700924]Getting those soft doors the right way in the tub is a pain in the b**t. I gave up at a certain point. Wind an water tightness was enough then...
A bit look alike?
That's awesome Dutch!! You've done a great job on your 5. And yes, the lower hinge pins are adjustable, which we DID discover! We have a better fit now.
We did do this Chris, and it helped a LOT.
We bought the top through a classified ad from a guy in Ohio. It was an insane PITB to get it down here to Florida!! I'm pretty sure it is complete and accurate, but everybody has been suffering the NOOB top installer! After adjusting hinge pins (including cracking one) we have something we can live with. Also, part of the problem is the factory weld of the upper hinge pin on the driver's side. It was not placed correctly on the frame. We will be doing some surgery!!
Not necessary Guys, but I appreciate it immensely. Thanks for your offer.
So what d ya'll recommend for sewing/repairing the seam where the thread pulled out? Bill has suggested waxed thread, which I think would be very good. Any other/better suggestions?
Kerrdog
Go Fish! <*////><
Skerr is offline
post #4703 of 5466 Old 12-31-2012, 07:01 AM
8pitcher
8pitcher's Avatar
Magic
8pitcher is offline
post #4704 of 5466 Old 12-31-2012, 09:12 AM
WNC-84CJ7
Dental tape.
post #4705 of 5466 Old 12-31-2012, 10:38 AM
DutchJPR
You didn't knew that? They are rather hidden underneath the cloth, so overlooking is comprehensible. For getting a better fit with the windshield frame, I dit some adjustments to the pins off the upperdoors, this tilted the uppers more forward, closing the gap a bit more. Maybe you can use a position ring on the pins. Bestop uses them with other uppers also.
Have you read these? -link-
I got mine repaired at a sailmaker workshop. They where specialized in tents and boat sails, but did a great job on my loose stitches.
Have a good New Year's Eve!
DutchJPR is offline
post #4706 of 5466 Old 12-31-2012, 10:54 AM
MrBeast
1980 CJ7
Knowing that I find the sourcing on the top suspect, I'd now almost bet you have TJ upper doors. Id see if you can find someone around the way with a CJ or YJ with cloth uppers and see if they fit. It would tell the whole story.
MrBeast is offline
post #4707 of 5466 Old 12-31-2012, 11:23 AM
Dadamsnv
1977 CJ5
If you can't find waxed thread, use upholstery thread. It's a thicker, stronger thread that I use on anything that needs to be rugged.
I'm looking for a Scout II Dana 300. Drop me a line if you have any leads. Thanks
Dadamsnv is offline
post #4708 of 5466 Old 12-31-2012, 04:56 PM
243
1978 FSJ Cherokee
Team Kerr, Happy New Year
Dave's 78 Build
243 is offline
post #4709 of 5466 Old 12-31-2012, 06:10 PM Thread Starter
Skerr
Dental tape.
You mean floss??
The position rings won't help in this application. It's like the driver's door sits too far back (pins extend outward too far). It makes a good seal around the door reveal, just not as good as I would like around the windshield.
I have the Bestop site saved, and that's what I used to install the top.
A sail shop would be the right thing to do, but the torn seam is only 3 or 4" and we can do that at home.
Where you get it D??
Why don't you come over and we'll have a couple? I'm batching it until Thursday!!!
Kerrdog
Go Fish! <*////><
Skerr is offline
post #4710 of 5466 Old 12-31-2012, 06:19 PM
WNC-84CJ7
Nope. Tape is thicker and stronger.
1979 , cj5 , fiberglass , rollcage , tailgate
19?? CJ7 build thread biker250 Jeep CJ Forum 96 12-27-2010 06:10 AM
Looking for a CJ Build Thread. jsc7002 Jeep CJ Forum 6 08-22-2009 10:47 AM
High 5 Build Thread... 1Rustycj5 Jeep CJ Forum 7 03-22-2009 09:28 PM
Build Thread for my '84 CJ erik5387 Jeep CJ Forum 19 05-29-2008 01:05 PM
