Clay's Build Thread - Page 311 - JeepForum.com
post #4651 of 5422 Old 11-18-2012, 08:31 PM Thread Starter
Skerr
Real men go to the river!
Big day today. Baptism for my 13 YO. The water is COLD!! And some fun pics of Clay "wheeling"! Notice the mighty flex and the incredible hill climb!!
Kerrdog
Go Fish! <*////><
Skerr is offline
post #4652 of 5422 Old 11-18-2012, 08:42 PM
lucdog
1980 CJ5
Congrats to Fallon. We need to find Clayton se bigger hills!
And here, just for you is a river song
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7
1989 YJ the CJ to YJ.
lucdog is offline
post #4653 of 5422 Old 11-21-2012, 10:50 AM Thread Starter
Skerr
Clay's Jeep is leaking... a lot! I am keeping an eye in the oil level, but it doesn't seem to be going down. I know the oil leak is engine oil, and I believe it is coming from the pan gasket. I installed one, and I had a shop install another, but still it leaks. It seems to be coming from the front of the pan. Is there some kind of union between the timing cover and the oil pan? I did not remove the timing cover when we did this build. I can hear the timing chain inside when it is running, and I assume the engine would benefit from replacing it, but I didn't want to get into engine work if I didn't HAVE to. If I go through that hassle of changing gears/chain, can I expect to fix this leak?
Also have a rear axle seal leaking, so I have that to do too.
Kerrdog
Go Fish! <*////><
Skerr is offline
post #4654 of 5422 Old 11-21-2012, 05:22 PM Thread Starter
Skerr
Will a shifter boot for a T150, T14, T15 fit a T18?
Kerrdog
Go Fish! <*////><
Skerr is offline
post #4655 of 5422 Old 11-21-2012, 05:37 PM
gmakra
Skipper if you do replace the timing chain replace the pan gasket with a Victor Rienz one piece pan gasket its much better than a Felpro. I never had one leak Car Quest sell Victor Rienz and I would replace the timing chain at the same time cheap insurance.
gmakra is offline
post #4656 of 5422 Old 11-21-2012, 05:58 PM
Dadamsnv
1977 CJ5
Yup. I bought mine from quadratec and it was labled for a t150 I believe.
I'm looking for a Scout II Dana 300. Drop me a line if you have any leads. Thanks
Dadamsnv is offline
post #4657 of 5422 Old 11-21-2012, 07:25 PM
Turtle71
1983 CJ7
Not sure if this is the problem with the leak, but I remember reading about someone else having the same issue after replacing their oil pan gasket. I believe it was MoC but not sure. Anyway, all they did was check and tighten some of the oil pan bolts. Doesnt take much though.
My 83 CJ7 Build:
Turtle71 is offline
post #4658 of 5422 Old 11-21-2012, 07:40 PM Thread Starter
Skerr
Using a one piece gasket, but not the one George recommends. I have tightened the bolts twice, and no difference. I am wondering if I have a small hole in the pan. There is a pretty good ding there where the PO hit something.
Kerrdog
Go Fish! <*////><
Skerr is offline
post #4659 of 5422 Old 11-21-2012, 08:14 PM
VACJ7
VACJ7's Avatar
Scott, I used a felpro one-piece and have zero leaks. The one thing that comes to mind is they should have put a small dab or RTV where the pan gasket goes from the flat to curved surfaces. Four places total. Two front where it meets the timing cover and two rear where it meets the rear crank bearing. You should be able to see if they did this because it will squeeze out some when you torque the pan.
'84 CJ-7 |
VACJ7 is offline
post #4660 of 5422 Old 11-21-2012, 08:22 PM
8pitcher
8pitcher's Avatar
On mine I used non hardening gasket sealer between my felpro multi piece gasket and it doesn't leak. But then again I haven't gotten my engine on the frame yet.
8pitcher is offline
post #4661 of 5422 Old 11-21-2012, 08:26 PM
Dadamsnv
1977 CJ5
I used an 1/8" bead of RTV on both the pan and block along with a 4 piece gasket. No leaks. haha no kill like overkill
Dadamsnv is offline
post #4662 of 5422 Old 11-21-2012, 11:01 PM
8pitcher
8pitcher's Avatar
Haha exactly.
8pitcher is offline
post #4663 of 5422 Old 11-22-2012, 09:11 AM
rixcj
rixcj's Avatar
1979 CJ5
I've found that if you put silicone on both sides of a gasket, it can cause the gasket to "blouse out", or slide out sideways , in certain spots, when tightening down the bolts..
An engine builder friend of mine told me to either just use silicone, The Right One, etc. (no gasket), or just a gasket...not both.
So now, I used Permatex Hi Tack on the block, and the block side of the gasket, just to glue the gasket to the block. Then I bolt the oil pan to the bottom side of the gasket. It doesn't "blouse out" this way.
Putting the sealant at the corners IS necessary, though.
'79 CJ5, AMC 360, t-18/d20 twin stick, dana 30/amc20(Mosers), Edelbrock Performer intake, Holley 600, ps/pb, DUI HEI, 'glass tub/1pc. tilt nose, 33x12.50 BFG AT's.
There's a fine line between "hobby" and "mental illness".
rixcj is offline
post #4664 of 5422 Old 11-22-2012, 09:24 AM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
Scott,
I'd get busy with some degreaser and power-washer, and get the under-side squeaky clean. That way you'll be able to isolate the leak, easily, after a short drive.
I'd hate to see you chase the wrong problem.
If I had to guess, I'd agree with VACJ7, the 4 corners of the oil pan probably didn't get RTV'd as they should.
Matt
Matt1981CJ7 is online now
post #4665 of 5422 Old 11-22-2012, 10:56 AM
Dadamsnv
1977 CJ5
I had a couple "blouse outs" that broke the gasket. But it still sealed because of all the sealer. I felt like a meathead the whole time I was doing the pan. Next time ill be less sloppy. It's only by gods grace that it sealed so well
Dadamsnv is offline
1979 , cj5 , fiberglass , rollcage , tailgate
19?? CJ7 build thread biker250 Jeep CJ Forum 96 12-27-2010 07:10 AM
Looking for a CJ Build Thread. jsc7002 Jeep CJ Forum 6 08-22-2009 11:47 AM
High 5 Build Thread... 1Rustycj5 Jeep CJ Forum 7 03-22-2009 10:28 PM
Build Thread for my '84 CJ erik5387 Jeep CJ Forum 19 05-29-2008 02:05 PM
