Clay's Build Thread - Page 278 - JeepForum.com
 48Likes
post #4156 of 5466 Old 09-09-2012, 11:29 AM
jacques25150
1982 CJ7
Originally Posted by Skerr View Post
I love BMWs... always have. I had a similar experience on my GS1100G. ALMOST went down. ALMOST went off the mountain. Rode slow the rest of the time we were in the Blue Ridge. Glad you're okay.
Tomorrow... High-Build Primer!
There's that ad again!
HA!!! Iam not alone: I have A FJR1300 and i AM get down also in june 2009 on a thick graver layer: 2 broken ribs and the FJR limit unripairable: my speed? 45 km/h
jacques25150 is offline
post #4157 of 5466 Old 09-09-2012, 11:35 AM Thread Starter
Skerr
Bon Jour, Jacques! Glad you were going slow, and I am glad you walked away! Broken ribs sure do HURT!
Kerrdog
Go Fish! <*////><
Skerr is offline
post #4158 of 5466 Old 09-09-2012, 11:46 AM Thread Starter
Skerr
Clayton with the "Jeep Slave" mark on his forehead! He is very agitated in this pic.
And the cowl seal. The gap between the WS frame and the cowl is not even. I don't think the drilled holes in the cowl are in the right places. The seal does not sit flat/flush when the WS is raised. Typical cowl seal installation problems here. Debating using the 3M tape, but I don't see how that is going to solve my issue. I think it is differences in tub mfg, and making the seal bend against itself is short term using tape. I will bolt the hinges to the frame, raise the WS, and check the hole positions on the cowl. Maybe that will work.
Kerrdog
Go Fish! <*////><
Skerr is offline
post #4159 of 5466 Old 09-09-2012, 02:54 PM
rixcj
rixcj's Avatar
1979 CJ5
Scott...I know that you are in Fl., but don't you need to ever use the defrosters? I noticed that you didn't cut the defroster holes in the top of the cowl.
I am going to do something that you guys did, though...on the 'glass tub that I'm working on, I'm NOT going to cut out the fresh air opening in the cowl. I really won't use that feature, and it's just another place for rain to leak in from.
Rich
'79 CJ5, AMC 360, t-18/d20 twin stick, dana 30/amc20(Mosers), Edelbrock Performer intake, Holley 600, ps/pb, DUI HEI, 'glass tub/1pc. tilt nose, 33x12.50 BFG AT's.
There's a fine line between "hobby" and "mental illness".
rixcj is offline
post #4160 of 5466 Old 09-09-2012, 04:04 PM Thread Starter
Skerr
Rich
He doesn't have a fan so defroster, for now, is a moot point. I expect to have to install all that at some date, but for now we are just trying to get it OUT of the shop! I do not think we will install a factory air box just because of the room it takes up. That being said, I have no idea how large a Mojave, etc, is... wiping with a towel is his defrost for awhile! Seeing as how this thing is going to be SO NOT airtight, is a defroster going to be necessary?
Kerrdog
Go Fish! <*////><
Skerr is offline
post #4161 of 5466 Old 09-09-2012, 04:14 PM Thread Starter
Skerr
Questions, commentary, and disillusionment (is that a word?)
Clay's Jeep has Superwinch 6-bolt lockouts. I was checking stuff over and I discovered that all 6 bolts were super loose, and one is missing. These are the long, skinny screws that hold the actual locking portion of the hub. Where can I find one of these screws, or should I swap them out for the 6 bolt Warns I have on the shelf? NOTE* I went through the hubs, cleaned and greased, so they are good to go. A Gremlin came behind me and loosened the screws!
The WS is nearly done. I can't believe it is giving me so much trouble! After tightening up the two dash brackets the seal is bulging outward. Clay was able to push the seal back into position with a paint stick. It might work for you too.
Tightening down the bolts that hold the WS hinge to the cowl, the cowl cracked. It was cracked here before, and I had repaired it. Not good enough! Clay added some stout glass (biaxial, and 1 1/2 ounce mat) to the inside of the cowl, reinforcing it. Maybe it will stop cracking. I can tell you this windshield will not be lowered!
Kerrdog
Go Fish! <*////><
Skerr is offline
post #4162 of 5466 Old 09-09-2012, 04:20 PM
8pitcher
8pitcher's Avatar
I have a bolt like that.
8pitcher is offline
post #4163 of 5466 Old 09-09-2012, 05:21 PM
rixcj
rixcj's Avatar
1979 CJ5
He doesn't have a fan so defroster, for now, is a moot point. Seeing as how this thing is going to be SO NOT airtight, is a defroster going to be necessary?
I have no idea. In a pinch, I guess a roll of paper towels will work.
Rich
rixcj is offline
post #4164 of 5466 Old 09-09-2012, 06:09 PM
243
1978 FSJ Cherokee
Rain-X Anti-Fog works reasonably well, but I bet those hot, muggy north Florida days are going to steam it up.
Dave's 78 Build
243 is online now
post #4165 of 5466 Old 09-10-2012, 02:52 AM
Cutlass327
Cutlass327's Avatar
1978 CJ5
I lost a couple of ny lockout bolts too. I just used regular bolts the same size as the originals. They are held in with lick washers, since those tab locks didn't work at all..
Rick
Cutlass327 is offline
post #4166 of 5466 Old 09-10-2012, 05:20 AM
gmakra
Skipper on the lower windshield bolt holes that are cracked, I dont thing you need to worry just use some fender washers on the back side.
Defroster is nice but I am pretty sure you can live with out it.
gmakra is offline
post #4167 of 5466 Old 09-10-2012, 07:54 AM
mvigo
mvigo's Avatar
I use this as well and it does help out but you have to apply it more then you think...
1985 CJ-7, fuel injected 258, 2.5" Rubicon Express Extreme Duty Lift, 1" Body lift, Crabtree Shackle Hangers, T-5, Dana 300 w/ 4:1 Teralow kit, Dana 30, AMC 20 w/1 piece axle, 3.73 's with Detroit Truetrac front and rear, riding on 32x11.5x15" Cooper Discoverer STT mud terrains
mvigo is offline
post #4168 of 5466 Old 09-10-2012, 08:02 PM
lucdog
lucdog's Avatar
1980 CJ5
When needed I use a squeegee, rags and towels don't soak up all the moisture.
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7
1989 YJ the CJ to YJ.
lucdog is offline
post #4169 of 5466 Old 09-11-2012, 01:40 PM
DutchJPR
Had some issues with them Superwinch locking hubs and bolts myself recently. I had to re-tighten them after every 4x4 ride.
Used new (half thread) 3/8" x 1 3/4" grade 5 bolts to replace them. Also cleaned the thread in the hub, applied blue loctite on the bolts and added a (external)star locking washer. No loosy bolts anymore.....
Dutch builds: http://www.jeepforum.com/forum/f8/dutch-build-1231816/
DutchJPR is offline
post #4170 of 5466 Old 09-11-2012, 04:50 PM
243
1978 FSJ Cherokee
Thanks for the peppers and tomatoes! My mouth started watering as soon as I unwrapped the peppers so naturally, I had to pop the top and garnish the baked chicken this afternoon....well, garnish the peppers with a baked chicken may be more accurate
Dave's 78 Build
243 is online now
1979 , cj5 , fiberglass , rollcage , tailgate
19?? CJ7 build thread biker250 Jeep CJ Forum 96 12-27-2010 06:10 AM
Looking for a CJ Build Thread. jsc7002 Jeep CJ Forum 6 08-22-2009 10:47 AM
High 5 Build Thread... 1Rustycj5 Jeep CJ Forum 7 03-22-2009 09:28 PM
Build Thread for my '84 CJ erik5387 Jeep CJ Forum 19 05-29-2008 01:05 PM
